Question about Plumbing
Bath tube plumbing is making vibrating sound then shutting off
The bath tube has a facet / handle shower unit mounted together. One must sit in the tub and take the hand held unit to shower. The problem is that a week ago the water would shut off soon after coming on. I would switch the water to run from the facet then back to the hand held shower unit. It seem to work. Two days ago it shut off completely. Today I turned on the water and it began to flow at low volume rate. When I increased the volume it began making a vibrating sound and the water stopped flowing. I removed the shower unit thinking that there was air in the line causing the impass. It did not work. I have turned on all of the up-stairs facets at the same time thinking that if there was air in the line it would pass. All other facets operated properly but the bathroom tub facet.
  • Anonymous Mar 23, 2014
    no water comes out of handheld once its attached to the hose
    Scholar:
  • 68 Answers
Replace the cartridge even if its new. The vibrating is from the internal workings of the stem. It also effects the volume of water.
good luck, Phil
Posted on Dec 11, 2008
We have installed a moen 82490 one handle tub & shower unit. When we turn on the water you could shower and bath at the same time. If you pull the plug for just a shower the water to the spout stops...
If you pull the silver knob on the tub spout up, the diverter located located inside will redirect water up to the shower head and when lowered it will return the water to the tub spout. It sounds as thought the diverter is not working properly. Hope this helps..
Mar 08, 2011 | Moen & One Handle Tub & Shower Faucet
I have a Perrin and Rowe Diverter valve U.5383 for a hand held shower that I need to disassemble to replace the spindle. Is the right hand side housing threaded? There is a hex nut on the housing (exposed...
Soak the unit in very hot water 50/50 with white vinegar for 2or 3 hours to loosen the lime in the threads and try it again. Keep the water hot no boiling but hot.
Feb 02, 2011 | Perrin and Rowe Rohl Bath U-5386 ; U 5386...
Leaking form shower facet also leaking from
id say your tub spout or shower pipe is leaking and running down behind remove both and replace teflon tape see if it stops
Mar 14, 2010 | Home
How to adjust anti scald valve on american standard shower faucet
Remove the handle,and all the trim rings,and the cartridge cover. take a flat head screwdriver and use it to lift
up the red ring behind everything, this is the hot limit safety stop,
this just stops the handle from turning to full hot.
Once you have the red ring lifted up, notice the numbers and the pointer
on the ring, numbers are on the fixture,
O= hottest 7=cold
See what the ring pointer is set to now, and move it half, before you put this back together, just set the handle on the unit and run the water to see if its to hot or not enough. Once you have found what is the best setting, then replace all covers and trim, handle.
Feb 10, 2010 | American Standard Bath Faucet Ceramix...
When I turn the water on for a bath only water
the water deverter that makes water come out the shower head is probably in need of repair. or replaced.
Dec 04, 2009 | Moen & One Handle Tub & Shower Faucet
Bathtub water does not get hot enough-
take off handle and you should see a nylon ring with teeth just take off and put back in the oppisite direction that you removed it its there to prevent kids from getting burnt
Feb 27, 2009 | Plumbing
Leaking faucet
Hi johnparker,
The dripping is caused by the ceramic cartridge leaking. It is a non servicable part.
Couldn't find the model number listed but here is a Talia schematic.
http://www.grohecatalog.com/product/25596/
The replacement cartridges are list as 4 and 5 in for hot and one for cold. Also consider replacing part #7 it is a seat.
Good Luck and please rate this response, Phil
Dec 29, 2008 | Grohe 25 597 Talia Tub Filler w/Personal...
I have a chip in my bath tub
This is something best handled by a tub resurfacer. It is an area of specialized repair. Results varied depending on material tub is made of. Cast iron tubs Show repair more so than fiberglass. Check for tub resurfacing in Repair Service Link.
Dec 09, 2008 | Home
Plumbing Logo
213 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
