Question about Phoenix Gold Titanium 800.1 Car Audio Amplifier
Protection mode My amplifier immediately turns on protection mode as soon as I turn my car on.
  • c7o7d7y7 Dec 11, 2008
    the amp i have is a phoenix gold titanium 800.1 and it is ran to a fosgate P3. i have 2 of each so i tried to run the second P3 to the second amp. when i did this the amp that was originally working now goes straight to protection mode. does this amp have a fuse that i could've blown and/or what else could be wrong?
  • 631 Answers
It's normal for some amps to go into protect for a few seconds when initially powered up. If it remains in protect mode, it may have shorted output transistors. To eliminate other possible causes, read through the following troubleshooting page:
Amp in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Posted on Dec 11, 2008
  • Perry Babin Dec 11, 2008
    There are probably no internal fuses. It's likely that the amp has shorted output transistors. I generally help people repair amps but this amp is complex and should be repaired by an experienced tech. Google the Phoenix Phorum. Someone there will know a tech that can repair it for you.
How to fix a Legacy LA490 amplifier
sounds like output transistors proffesional repair time sorry
Nov 20, 2011 | Legacy Audio American Legacy II LA490 Car...
My 1800 watt kenwood keeps goin into protect mode as soon as i turn it on.. why?
disconnect load (speakers), check if it still goes in to protection if so then your output stage might be faulty
Apr 17, 2010 | Kenwood KAC-9152D Car Audio Amplifier
My amp is a kenwood kac-9152d it goes in to protection mode soon as you hook up the power
In protection mode do you mean the light comes on and it plays music and stuff? If that's the case, that's what the amp is supposed to do. Protect itself from a power surge
Feb 21, 2010 | Kenwood KAC-9102D Car Audio Amplifier
Kicker amp goes into protection mode as soon as i turn it on
Have you tried powering on without speakers connected? Have you tried powering on with no input? If either senerio causes the amp to NOT go into protection mode, then there is most likely a short in wiring. Use a multi meter to isolate.
Jun 11, 2009 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
Mxa422 protection
Outputs are fried. Try disconnecting your speakers and see if it still goes into protection mode. If it does then you A thumbs up would be greatly appreciated if answer is helpful for your question. THANK you and GOD BLESS
May 24, 2009 | Lanzar MXA422 Car Audio Amplifier
RODEK AMP PROTECTION
have you checked your speaker connections and any other connection for shorts or multiple ground loops. cause that will definately cause the protection mode.
Mar 03, 2009 | PPI PCX-280 Car Audio Amplifier
Stuck in protection mode
First disconnect the subwoofer wires from the amp, turn the car off and back on...is the amp on? If so your subs are shorting it out, either from a frayed wire, or blown subs.
If it is still in protection mode, check the fuses in the side of the amp.
Mar 21, 2008 | Kenwood KAC-7251 Car Audio Amplifier
DAB2204
try turning down the volume level on the power amp.
And see if that works.
Dec 27, 2007 | Digital Audio 840 WATTS 2, CHANNEL HIGH...
Amp keeps turning itself down - cant turn off 'protection'
yes,pls.stop plugging the system,you may harm your system if you do so,the system has it's own system analysis mode,and if there's something wrong in the circuitry,it will activate,you need the authorize service center my friend,it's a technical problem.
Dec 09, 2006 | Cambridge Audio Azur 540A Amplifier
Phoenix Gold Titanium 800.1 Car Audio Amplifier Logo
1,313 people viewed this question
Top Phoenix Gold Car Audio & Video Experts
Mark Skinner
hoyzee1
Are you a Phoenix Gold Car Audio and Video Expert? Answer questions, earn points and help others
