Question about Ranger Communications RCI-6900F-25 CB Radio
Hi i have a ranger 6900f turbo
Hoped in the car one morning and radio wont turn on has no power what so ever could you please tell me what could be wrong and can it be fixed thanks
  • 2 more comments
  • deane houia Dec 11, 2008
    yep all fuses a good but still wont go some one told me it is a power diode but want to ask exspert first thanks deane
  • deane houia Dec 12, 2008
    thanks very much i will look at it now thank you
  • Rob Duron
    Rob Duron May 11, 2010
    Have you verified the fuse at the radio and the fuse at the fuse block are good? Basicly make sure you have power to the back of the radio.
  • 55 Answers
Http://www.rangerusa.com/downloads.html
This link will get you to the service manual and schematic. These two PDF will give you enough data to build new boards from scratch. Unfortunately radios are very complicated so it's pretty hard to nail down a problem like this without taking it apart. I don't thinkit's the power diode for a couple reasons 1st they are rated at 200v and 1kv piv (the amount of reverse bias voltage it will survive) 2nd the diodes are rated for a forward surge of 30A which is easily supplied by your battery but the fuses would have blown. If your handy I would disconnect the power and pop it open to look for burnt components. the only solution I have is re check the power connections On rare (very rare won the lottery) occasions
a bad connection will show voltage but when the radio loads it down it won't carry current.
Sorry this is much help. I'm happy to answer any more questions.
Rob
Posted on Dec 12, 2008
My rci ranger wont transmit but it receives great what is the problem
it could be several things......the rf final,bad mic,cold solder joint on the circuit board just to name a few.my suggestion is to find a good local cb shop,if no local shop find one along the interstate hwy most of the time they are located around or near some of the larger truck stops. tell the tech there what the problem is and go from there. good luck !!
Apr 04, 2013 | Ranger Communications RCI-6900F-25 CB...
More power rf
turn it down to 1 may 1.5 watts and turn modulation up 95% and add a 500 watt liner to it and you are in business.
Mar 13, 2013 | Ranger RCI-6900F-150 CB Radio
My ranger 2950 wont transmit or receive sounds like a relay problem but dont no for shour can you tell me what is wrong with that radio thank you.
could be a number of different problems causing this. I would start with your microphone make sure it is working. it is responsible for transmit & recieve. next check to see if the memory battery is dead this will also cause this problem. next check the regulators in the radio to see if they are supplying voltage.next check voltages in different parts of radio to see if all stages are recieving power follow these steps and something will show up also check your switching diodes to see if they are bad the diodes responsible for x-mit & r-mit of transceiver.
Jan 04, 2011 | Ranger Communications RCI-6900F-25 CB...
SCI 6900 F.TURBO. BUZZING NOISE, DOESN'T SEEM TO REC VERY WELL WHAVE A LOT OF STATIC
I am going to need a bit more information then that.
Does it do the same thing with other radio's?
Has any one been inside the radio?
The buzzing can be from either a rectifier in the power supply, or some times there is an issue on some 9600 boards that can cause a buzzing.
If its the power supply, then your receive will be poor because the buzzing is killing it.
Dec 14, 2010 | Ranger RCI-6900F-150 CB Radio
What will coust to have a RCI 6000 F150 REFUBICHT
Hi, my name is John. It will cost you about $150.00 to get it done,and that is cheap. ...Hope this was helpful....
Aug 26, 2010 | Ranger RCI-6900F-150 CB Radio
Need user manual for ranger rci-6900f turbo
Here is a link that goes to RCI for the complete manual for this model----let me know if you have questions.
If this helped you rate this solution as I do this here for free.
SD TECH
http://www.rangerusa.com/pdf/man6900f.pdf
Dec 17, 2009 | Ranger Communications RCI-6900F-25 CB...
Ranger rci-2950
Hopefully it's as easy as this carefully take the cover with the speaker in it off and look to make sure the speaker wire with the plug is plugged into the two prongs sticking up in the back right side corner it is a very tight fit though.Good luck Dan
Aug 28, 2009 | Ranger Communications RCI-6900F-25 CB...
RCI 2950
Hello, Just offhand I'd say you have a bad solder joint on the main circuit board. Without more info, I can not tell you where to look,,,,, Mechanic
Jul 09, 2008 | Ranger Communications RCI-6900F-25 CB...
Ranger Communications RCI-6900F-25 CB Radio Logo
342 people viewed this question
Top Ranger Radio Communications Experts
Jon Piercy
perdue40
TekkiDave
Are you a Ranger Radio Communication Expert? Answer questions, earn points and help others
