Question about Uniflame 2158 Smoker
I need a replacement regulator hose assembly for a Uniflame model #NSG3902B
  • 8,197 Answers
My Uniflame grill may have a clog somewhere through the fuel delivery system, or at the the tank connection, how would I be able to find the culprit?
Hi boltbucrayfa...
I think your culprit is the gas regulator valve...
If it is not working properly then it will not deliver the proper amount of gas to the burners.
Check all your burners to make sure they are not plugged...
The when you are outside away from Flames and ignition sources.
Remove the hose from the grill...open the gas to the grill (you have the hose off the grill) and listen to the flow of gas...if it is very low then there is your problem.
You can shut off the flow of gas, then tap the gas regulator on the sides, top and bottom lightly with a hammer and then turn back on the gas to see if the gas flow increased...if it did, then shut off the gas and rehook up the gas line to the grill..and your good to go grilling again.
Some gas regulators have an adjustment under the removable cap.
If the gas flow did not increase, the replace the gas regulator
Please take time to rate me
Sep 26, 2011 | Uniflame FG2204C Grill
Burner lights but then shuts off after about a minute
What's happening is a good indication that the pilot assembly and the burner assembly may need cleaning. Insects can really clog it up. If after thoroughly cleaning the pilot and burner assemblies the burner still shuts off,check the gas tank and make sure it's at east 2/3rds full. After reconnecting the hose to the tank, open the tank valve VERY, VERY SLOWLY (Slow motion, slow) until the valve is full open. Then attempt to light the pilot and the burner. If every things works as it should, you solved the problem.
If you find you need to order a thermocouple, I have provided a link to the Blue Rhino Company, the manufacturer of Uniflame Patio Heaters and you can order it thru them.
http://www.uniflame.com/BRWEB/getdoc/3dbb047b-509e-4627-98cd-c4cdb36d82a9/Parts-and-Accessories.aspx
I hope this helped you troubleshoot & solve the problem. Thanks for choosing FixYa.
Aug 15, 2011 | Uniflame 200209 Open Flame Patio Heater
NEW Uniflame LP Model GBC1134W Gas Grill won't go over 300o in an hour? What is wrong?
The problem may lie with the grill's regulator and the way the tank was turned ON.
To solve this problem, do the following:
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank valve ON Very, Very Slowly.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling.
Jul 14, 2011 | Uniflame FG2204C Grill
I CHANGED THE PROPANE TANK AND THE GAS DOESN'T SEEM TO BE REACHING THE GRILL, i EVEN TOOK THE TANK BACK AND EXCHANGED IT FOR ANOTHER ONE, BUT IT DOESN'T SEEM TO WORK. CHECKED TO MAKE SURE THE LINES ARE...
Turn the tank valve OFF. Disconnect the hose from the tank and wait 5 minutes. Reconnect the hose to the tank and turn the tank valve On VERY, VERY SLOWLY (Slow Motion, slow). Once the tank valve is fully open, light the burner and turn it to the highest setting. Do the flames appear to be correct for the highest setting? If so, you've solved the problem. Just remember to always turn the tank ON VERY, VERY SLOWLY.
If that didn't solve your problem, the grills regulator is permanently locked up. You will need to replace the hose/regulator assembly. You can purchase one at any hardware or home center store that sells gas grills. Take the old one with you for comparison purposes.
Hope that solved your problem and Happy Grilling!!
Mar 20, 2011 | Uniflame Grilling
When we lite it, it only lites very low you can not cook any thing on it, then one time we lite the flames stayed up
Mar 20, 2011 | Uniflame FG2204C Grill
I purchased a barbeque and ended up with a natural gas instead of propane can it be converted to propane if so how? it is a UniFlame 4 burner with side burner cant find model on there web site
Yes but you need to replace the valves, burner orifices as well as the regulator the screws into the propane tank. Go to cagrills.com and search their models for the proper parts.
Jan 14, 2010 | Uniflame Heating & Cooling
Cannot adjust flame
This could be a regulator or manifold issue. If the unit has a side burner check to see if it is burning at a correct flame height. If it is then the regulator is not the problem there is an issue with the manifold. For further assistance please get the model number and call Uniflame at 1-800-732-1142 we are here 7 days a week to help.
Jun 19, 2008 | Uniflame Grilling
Uniflame bbq grill
had same problem- noticed regulator iced up. received new regulator under warranty from uniflame. still same problem. tapped on regulator and started to work better but should not have to do that. maybe regulators are defective, but not a grill doctor.
Apr 13, 2008 | Uniflame FG2204C Grill
Uniflame 2158 Smoker Logo
169 people viewed this question
Top Uniflame Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
limabeenie
Level 1 Expert
Are you an Uniflame Grilling Expert? Answer questions, earn points and help others
