Question about AEG 24 in. Favorit 40850 Free-standing Dishwasher
How do i fix error code 30?
Hi, i got error code 30 (anti flood) on my aeg dishwasher 40850. do you know how i can reset it please? thanks for your time & help...my wife will be so happy if i can fix it!!!
  • 5 more comments
  • contremoi Dec 30, 2007
    I've got the same problem. Just wonder whether it would be the same solution for the AEG Favorit 80850.
  • dave Mar 02, 2008
    hi i had the same p[roblem it was a leak from the heater causing a puddle underneath and then cutting out out i repaired it and all seems fine now
    i did in the end had to replace the heater it cost 42 pound and was so easy to fit hope this helps you out
  • Anonymous Aug 18, 2008
    cleaned everything i can and washed up by hand
  • Anonymous Jan 18, 2009
    Great! Thank you Sara! I
    looked under the cover at the bottom of AEG Favorit Silence dishwasher and I found out, that there is polystyrene float. If the water gets into bottom tray, it rise up this float and thats the reason of error code. By tipping the machine you empty the tray and the problem is solved.
  • jarrks Jan 18, 2009
    looked under the cover at the bottom of AEG Favorit Silence dishwasherand I found out, that there is polystyrene float. If the water getsinto bottom tray, it rise up this float and thats the reason of errorcode. By tipping the machine you empty the tray and the problem issolved.
  • Marko Mrisepp
    Marko Mrisepp Apr 19, 2017
    Helped me as well. Cleaned the tray and we run again.
  • John Mercieca Dec 18, 2017
    T o whom it may concern . Please bear this mind . When you tip the machine you certainly start to remove the water level . This will de activate the float .But it will happen again and again . If it would be of intent you pease mail me at jtmercieca@yahoo.com / I will send you pictures by which should you need to get an Tech . He would see immediately the problem,
    I can also let you have the serial number of the part .
    I am an engineer but not of Dishwashers.
AEG Favorit 40850 i30 error - this is the anti-flood error. I did the tipping-over trick, great, but for me, the problem got more and more frequent until the machine would not run. So I took it apart and this is what I found: in the drainage area, next to the water drain, is a sensor. This has been described to me by a dealer as a 'temperature sensor'. I am not sure if this controls the anti-flood system, it may well do, as it is the only one in there. However, the problem is not caused by the sensor itself - around the sensor is a black rubber grommet (seal). In my machine (4 years old) this was badly perished - the rubber had become soft and oily, and about half of it had gone. The sensor itself was covered in oily goo from the grommet. I think that bits of the grommet have been coming off and jamming in the drain, and maybe causing the sensor itself not to work properly. I changed the grommet (£5 part), and it all works great. If you want to do this yourself, follow these instructions:
  • turn off power and uplug dishwasher
  • you need a screwdriver with torx bits
  • put lots of old towels on the floor
  • remove top panel using 2 screws at rear top, then push top backwards and lift off
  • remove front base fascia panel by sliding to left
  • remove right side panel - undo 2 screws at top, one at rear bottom, one at front bottom
  • front edge of side panel is wedged inside white trim - just ease it out, it isn't held in.
  • open dishwasher door and push down fully
  • remove curved front base panel - undo screws right up at the top of the panel, this is a tight fit against the door but you can get in if the door is pushed down fully
  • tip dishwasher over onto left side
  • follow the drain pipe in, this takes you to the drain pump
  • if you want to check the drain pump and pipe, twist the whole pump motor assembly to the left about 15mm - there are 3 tabs that hold it in place, you need to rotate the motor past the tabs, then you can pull it out
  • DO NOT remove the spring clips on the large drain pipe (50mm diameter) between the pump motor and the dishwasher drain - these are very difficult to get back on properly, and once you have taken the pump motor off you can feel right through to the dishwasher drain hole anyway.
  • you can take the spring clip off the white oultet hose if you want - this goes back on easily. Check the outlet pipe with a long drain-clearing spring or similar.
  • about 50mm further towards the front of the machine from the drain hose, going around the drain assembly, is the sensor described above
  • this has wires going into into it, is about 25mm diameter, and you will see the black rubber grommet around it
  • this is held in place with 2 plastic clips, ease these back and pull it out. TAKE CARE not to break these clips.
  • If the grommet is heavily worn or perished, you need a new one. The part number is written on the surface of the grommet.
  • reassemble in reverse order. Before you put the panels back on, and with the power still OFF, tip the dishwasher back upright again, open the door, and pour 1 litre of water in (this will end up on your kitchen floor, so don't put too much in).
  • Check carefully under the machine, with a torch, around the areas where you have been working - the sensor and the drain pipes - to make sure there are no leaks.
  • If it all seems OK, dry the floor, turn the power on and run the dishwasher. MAKE SURE you are standing on dry floor when you do this. Check under the dishwasher again for leaks.
  • Let the dishwasher run a complete cycle. Check for leaks when it is pumping out.
  • If everything seems OK, turn the power off again, put the panels back on, then turn the power back on.
Good Luck!
Posted on May 01, 2009
    New Friend:
Tip it over onto it's front & then back upright again, we just did, error 30 stopped, and machine is working again.
Posted on Mar 13, 2007
  • Abdullah Abuhussein
    Abdullah Abuhussein Nov 18, 2017
    Thanks alot sara.
    Its agreat solution .
  • Carl Blewett
    Carl Blewett Apr 23, 2018
    I have just had my i30 fault on my Ikea skinade dishwasher. Kept flooding underneath and triggering the switch. My machine is only a year old! Well dishwashers being of poor design I found that the hose to the wet detector sensor was blocked with diahwash grime. That was preventing the sensor from turning of the fill line and kept filling the washer with water till it was enough to get past the door seals and flood the underneath of the dishwasher! Sadly this isn't covered under warranty for me as I have moved country with my machine!
I did like it was suggested and it functioned! Can't believe it. Actually I tipped the machine over, but not till the end (very slightly). It was a bit water on the ground. I removed it and put the machine upright. Thanks a lot!
Posted on Dec 31, 2007
Posted on Jan 18, 2009
  • 23hope
    23hope Sep 02, 2012
    Hi, have the same problem. Want to know why does the water get into bottom tray?
The solution that Sara suggested was very helpfull.
We had the code i30 after a christmas dinner for 12 people ending with the complete kitchen filled with dishes.
thanks.
Fons Smulders, Belgium
Posted on Dec 29, 2008
    Welcome Back:
    Visited the website for 2 consecutive days.
Hi everyone. I hate this troubleshoot since my problem bigger: my ikea kitchen makes the integrated machine not movable! I had this problem before when the machine was still under warranty, and didn't really pay attention when the repairman came (he didn't move the machine but press some buttons simultaneously to reset it, along with changing a little pipe as I recall). But now I wish I took notes... Another suggestions?
Posted on Jul 02, 2017
    New Friend:
For some time, we have been experiencing error code I30 as well. as suggested above, removing the water by tilting the machine helped, but it never stopped water from pooring into the bottom plate. Today, I investigated very thoroughly where the water was coming from and i was astonisched.
I found several puntures (little holes) due to what looks like corrosion inside the machine in the area under the metal filter plate at the bottom. All around the edges of the removable filter it looked like the metal had been eaten away. Waybe this is because of the agressive chemicals used? I don't know. Anyway, the metal sheet that the inner housing is made of was extremely thin. About 0.2mm thick. I feel like this is way too thin to be solid and I am going to contact AEG about this.
As for the lot of you: instead of shaking your machine every time, do check also where the water is coming from! If your machine is still under guarantee, this is clearly a fabrication flaw and your machine should be replaced!
Posted on Sep 17, 2014
Hello ,please i need help,can you tell me werw about is the misterious polystirene ball for my 40850 i am look forward you can help me please grazie carlo
Posted on Dec 21, 2009
Wow! Can hardly believe it was so simple - thank you Sara. I also had error code 30 on an AEF F3A. Saved a large puddle by pumping the water out of the salt contauiner first - but I was fortunate, I had this little pump that fits on the end of a drill sitting in my garage having only been used once in 15 years!! If you don't have a pump a couple of extra towels is probably a better alternative than buying one! Simply tipped the dishwaher fowards on to its door - held it for a couple of seconds and put it back upright. SWitched it on and away it went
Posted on Oct 25, 2008
This solution rocks.
We moved to Germany a few months ago and brough our 40850 with us. Tonight I had a short power failout due to some work we did. The dishwasher gave code 30 after we resetted the power. Turning the dishwasher over to almost the end released water and was somehow working again.
Thanks all,
Hans Wolters Neuenhaus
Posted on Oct 06, 2008
Thank you Sara, I  also had a code i30 and did the same and ..... it works again !!!!!
Many thanks from Nieuwegein / The Netherlands
Greets,
Marcel
Posted on Oct 17, 2007
Thank you sara! actually in my frustration i did the same & got it working but i reall appreciate you taking the time to let me know...cheers, have a good day!
Posted on Mar 15, 2007
I have an AEG F55002ViOP dishwasher. It's making a strange grinding sound and showing error code 30. Can anyone advise how to solve this please.
Error "i30" means that water remains in base because leakage or overflow. In this case, in order to prevent flooding, drain pump running continuously.
When we talk about AEG dishwasher, drain pump works even the power is turned off (must be connected to the wall outlet, otherwise anti-flooding system will not work).
The noise what you heard during operation indicates that something is blocking the drain pump.
Remedy: you should first remove the water from the bottom of the dishwasher and determine leakage then check why the drain pump makes noise.
If you work around the dishwasher, you always take care that appliance must be disconnected from the power supply.
Good luck.
Dado
Oct 11, 2014 | AEG Dishwashers
I30 message on aeg favorit 50879 u
Activated Anti-flooding system, means water leakage in the buttom of dishwasher. Could be also: faulty Anti-flooding microswitch, floating sensor (styrofoam) blocked mechanically, wiring diagram, electronic.
Dado
Jun 17, 2014 | AEG 24 in. Favorit 40850 Free-standing...
The dishwashers is coming up with an error code .30. What does this mean
its probably anti flood error and u might have a small leak somwhere
Jun 22, 2010 | AEG 24 in. Favorit 60870M Free-standing...
Got an AL4 error on my AEG 64800
al4 is tripping of anti flood float switch in base of machine. look for a leak mopping out the base resets the switch
Jun 19, 2010 | AEG 18 in. Favorit 64800 Free-standing...
No water fill
This is a typical Anti Flood system activation. This system activates when water leaks onto the floor of the machiene due to a leak fault (pipe/hose clamp/ partly blocked pipe). The machiene automatically switches to pump out mode and stops water inlet. The anti flood system is a polystireen float / micro switch at the base of the machiene floor. Dry the floor and drectify the leak and it should work.
Jan 24, 2010 | AEG 24 in. Favorit 40850 Free-standing...
Hi, I have an aeg 60870 dishwasher showing error code 30 and the pump is going all the time, even when you open the door, any suggestions of things i could try please?
Sounds like the Anti-Flood system activated (polystireen float at base of machiene coupled to a micro switch) the purpose of this system is to put the drain pump on and stops any other function on the machiene. The anti lood system activates when any amount of water appears on the bottom (caused by leaky pipe / blokked pipes / spills etc.) . Dry the water and rectify the leak. This should solve the problem.
Dec 21, 2009 | AEG 24 in. Favorit 60870M Free-standing...
AEG Fovorit 443 Dishwasher
Sounds like the Anti-Flood device at the bottom of the machiene is on. This is a polystireen float that activates a micro switch on top of the float. This is normaly activated by a water spillage / leak or their could be some debris holding the float in the up (on) position. The purpose of this device is to put the washer in pump out mode only.
Sep 06, 2009 | AEG 24 in. Favorit 40850 Free-standing...
Need to know how to re-set the anti-flood device
I managed to clean the filter inside the dishwasher and drain a little residual water. I then re-plugged in the appliance and the anti-flood device seemed to reset and I have n't had any problems since.
Jan 17, 2009 | Dishwashers
AEG Favorit 40850
yes its the flood sytem control underneath you might have a leek like i did it was the heater leaking
replaced it and now its running ok its a eay job to replace
Jul 02, 2007 | AEG 24 in. Favorit 40850 Free-standing...
AEG 24 in. Favorit 40850 Free-standing Dishwasher Logo
25,675 people viewed this question
Top AEG Dishwashers Experts
Paul Carew
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
