Question about Kenmore Elite 45986 Front Load Washer
F 22 MY WASHER HAS F 22 WILL NOT POWER UP. DO I NEED A REPAIR PERSON OR CAN I FIX IT?
  • 85 Answers
F22 is dool lock failure depending on you level of mechcanical ability disconnect power remove wire spring from around door seal pull seal away from front remove 3 t20 screws from front panel that hold swt pull swt through opening of seal remove 3 electrcal connections reverse procedure to install
Posted on Dec 14, 2008
WBVH6240F trouble codes 22 & 70
WH12X10355, this is the part number you are going to need to repair the washer
May 06, 2012 | GE WBVH6240F Front Load Washer
My GE washer # WJSR2080T2WW (about 10? years old) won't drain but will agitate. I don't know if it will spin. Do I even bother to pay for a repair person to look at it?
This is more than likely a clogged or bad water pump. Most of the time it is just clogged. Check to see if the pump is clogged and if so unglog it and it should go back to work. If it is not clogged you need to see if it have power when the washer is in spin. If it has power but will not pump replace the pump. http://www.appliance-repair-it.com/clothes-washer-repair.html#GE
Oct 01, 2010 | Washing Machines
At 22 min our washer beeps and says F1, we have to stop and start it about 4 times to get it to continue. What does F1 mean and how do we fix it?
Keypad/User Interface Failure
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 09, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Have a murray model 226111X92B 22
go to this website http://www.ereplacementparts.com/murray-226111x92b-2234-lawn-mower-parts-c-17887_17944_19048.html and find the part your looking for. i went to the site and found what you are looking for..good luck
Apr 05, 2010 | Mtd 22" Yard Machine Push Mower
The machine lights are blinking and it is beeping?
First try unplugging from the wall leave unplugged for 5 mins, and plug back in, this may fix it.
Mar 26, 2010 | Frigidaire ATF6000ES Front Load Washer
My laptop turns itself off if i move it a certain way and doesnt go back on again for a couple of weeks!
http://www.laptoprepair101.com/ this is the site to look at if you are a do it your self person .most likely it is the power port .when you plug in you adapter is it lose if soo it will lead to a blown motherboard if it is not repaired.your local computer repair can fix it for about $100 .if the laptop is unpluged and it drains the battery most likely it is the power port.
Nov 13, 2009 | HP W2207H 22 Notebook
Maytag Neptune Front Loader washing machine - door won't lock
It won't spin because the door won't lock. The door won't lock because the door lock mechanism is bad. I ran into this many times with the Neptune's when I was working for Sears. It is not a very easy fix. It is a pain to get to that door lock and replace it. You will most likely need a repair person to come out and fix it. I hope this helps you, sorry to be the bearer of bad news. I hope you have a good rest of the weekend though and let me know if you have any other questions. Good luck.
Jan 25, 2009 | Maytag MAH6700AWW Neptune Front-Load...
TV repair person told me my Toshiba 50HP16 Main Power Supply Circuit Board is bad as well as a secondart board. How do I identify these boards and get part numbers? Its too expensive to have the repair...
Even if you buy the parts you may get sticker shock!!! Why did it need a power supply and another board. Will your set come on? I may be able to give you part numbers but you need to be specific about which other board you think you need such as X Y signal board or power supply Some single circuit boards for some sets are as high as 600 bucks hope not for you
Sep 19, 2008 | Televison & Video
Washer filled but does not run at all
When the unit completes its filling cycle, a relay will be activated to start the wash cycle. A 10 year old unit probably has dirty/corroded or otherwise malfunctioning relay contacts. This should be repaired by a qualified repairman as high voltages pass through these relays.
Mar 08, 2008 | Kenmore 24902 Top Load Washer
Asko front-load washing machine
if a repair person does it supposed to be new motor and be sure to get a factory authorized tech some parts a warranted for longer than the first year but you have to use an authorized tech if it says parts only then you must pay labor as to can you do it yourself pull the bottom or back panel and see haven't worked on one of thees so cant be specific but i like to help see if they have a web site then go to support to find tech in your area hope this helps
Dec 31, 2007 | Asko W6661 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
135 people viewed this question
Ron Lankford
Archaeology
Archaeology
reliableservice
