Question about Phoenix Gold Titanium 800.1 Car Audio Amplifier
I had 2 rockford fosgate P3's, a phoenis gold SLP capacitor, an extra yellow top battery, and a phoenix gold titanium 800.1 monoblock amp. Earlier today I had the amp going to just one of the subs and it was working fine. Then we added another phoenix gold titanium 800.1 amp to power the second sub. When it was all rewired we went to turn it on and the original amp(that the power and ground are wired to) that was working fine ealier went straight to protection mode. I have read some things saying I may have grounded out the amp on metal from under my backseat and may have blown the fuse. Do these amps have fuses and if that's not the problem what might it be?
Professor_V
  • 92 Answers
SOURCE: Rockford Fosgate Punch End CapsEnd Caps
I TAKE IT THAT YOU ARE REQUESTING A SOURCE FOR A PAIR OF ENDCAPS FOR YOUR PUNCH-200IX. IF THIS IS THE CASE, I SUGGEST THAT YOU CHECK EBAY ON A WEEKLY BASIS AS I AM SURE AFTER SOME TIME, YOU WILL SEE A PAIR LISTED. THERE IS ALSO A SELLER ON EBAY THAT HAS MANY OF THE LOGOS FOR THE MANY DIFFERENT MODELS THAT CAN BE PLACED ON ANY OTHER MODEL ENDCAPS FROM THE SAME SERIES (DSM, IX, X2, ETC. LET ME KNOW IF I MISUNDERSTOOD YOUR REQUEST......V
Posted on Jan 06, 2010
  • 113 Answers
SOURCE: led light keeps flashing on my phoenix gold amp
if the amp went into protect you need to disconnect all power including ground for at least 20 min to discharge caps inside.
Posted on Aug 08, 2007
SOURCE: Rockford Fosgate 501bd question
that amp should work fine with those speakers,just make sure that they(speakers)are wired for 2 ohms.at 500-600watts coming from amp, you should be getting 250-300 watts per speaker,just dont crank your gain too high on the amp.
Posted on Sep 01, 2007
  • 109 Answers
SOURCE: hi..phoenix gold x600.1 went into protection
Contact Phoenix Gold at 800.950.1449
Posted on Jul 17, 2008
  • 631 Answers
SOURCE: phoenix gold ms2125 amp blown?
The following is a forum dedicated to PG amps. Someone there will be able to suggest a tech that's familiar with the amp.
http://phoenixphorum.com/
Let me know if you have any other questions.
Posted on Aug 18, 2008
What car amp should I get to power my 2 pioneer ts-sw3002s4 sub's. They are 12 shallow mounts 4 ohms each with 400rms each.
Rockford Fosgate R1200-1D Mono subwoofer amplifier - 800 watts RMS x1 at 2 ohm, 1,200 watts RMS x 1 at 1 ohm
Mar 26, 2015 | Pioneer Car Audio & Video
Where can i gt wiring diagram for phenix gold 12 dvc sub
YOU CAN GO THIS THIS SITE IVE USED FOR MANY YEARS PUT IN YOUR INFORMATION OF SUB/ SUBS AND GIVES YOU ALL WIRING POSSIBILITY'S.
Rockford Fosgate Woofer WiringWizard SORRY MY CAPS STUCK..HOPE I HELPED.
Oct 03, 2012 | Phoenix Gold Car Audio & Video
Can i use a 300 watt amp for 2, 800 watt woofers
yes, but you would not get the same performance as you would if you gave them the suggested power. I have found that it is always better to use a more powerful amp than your subs are rated for (as long as it is clean, high quality, low distortion power). I have had the best luck with name brand amps (kicker,rockford fosgate,phoenix gold,etc...). I hope this will be helpful to you.
Jul 30, 2012 | Phoenix Gold Xenon X10D4 - 10" D4...
What is the auctual watts fpr the Rockford Fosgate Punch 401S?
rockford fosgate doesnt have watts its considered monoblock it gives off watever the speakers want....it gives them the power they need
Dec 29, 2009 | Rockford Fosgate Punch 401S Car Audio...
I have two pioneer champions that are pushing 1200 wats a piece, how much wat amp do i need to push out the whole amount?
most likley they are 1200 peak if we r talking about the same ones then they are 400 rms a piece a solid 800 rms monoblock amp will poundem
Aug 16, 2009 | Rockford Fosgate Punch 401S Car Audio...
Connect rockford fosgate amplifier & speaker together
Assuming your P3 has a single voice coil (it will have only one place to plug your wires into) you will be running this in a bridged mode. You will take the left (+) coming off the amp and plug it into the (+) on the P3. Then take the right (+) from the amp and plug it into the (-) on the P3. This will make your amp push 500 watts to your sub. Now on the amp make sure your adjustments are as follows: Signal input switch is set to unbalanced for RCA input. Left Phase switch is set to 0. Right phase switch is set to 180. your X-card should be set to low pass. And adjust the gain for both R and L equally so it has equal power from both channels.
Aug 09, 2009 | Rockford Fosgate Punch 401S Car Audio...
Rockford fosgate 800 a2 amp power?
Hello desperate2le,
Watts delivered is a function of the voltage times the current. If the amp was 100 percent efficient, it would need 33 amps at 12V for 400 watts. At 14.4V, it would only need 28 amps. Of course, amplifiers are NOT 100 percent efficient, only about 50-60 percent in many cases, but somewhat higher for monoblocks, maybe 80-90 percent. So you're looking at a fuse in the 60-80A range. In the absense of a specific fuse size from the manufacturer, I'd start the primary fuse at a 60A and if the amp blows it on power up/immediately/frequently, move up to an 80A.
All of the Rockford-Fosgate 2-channel bridgeables I've ever seen show using the left positive (+) and the right negative (-) for bridging. But if it's not shown right on the amp, I'd call or email RF for the correct connection. The new amps do show it.
Hope this helps.
Apr 27, 2009 | Rockford Fosgate Punch 800a2 Car Audio...
I have been having trouble with my car stereo system
First reinspect your power and ground connections, vibration may have loosened them.
Then be sure that amp location has proper ventilation, (overheating will cause shout down)
A 2400 in a closed space will definitely need exhaust fans to help circulate cool air around the amp.
The cap should be mounted close to the amp and properly charged before use. It is connected in-line with the main power lead paying close attention to the power in and power out terminals.
Power in = from the battery
Power out = to the amp
Good luck
Aduz
Mar 15, 2009 | Rockford Fosgate Punch 801S Car Audio...
Need help with the wiring on amp to subs
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qty=3&woofer_imp=4 DON'T FORGET MY FIXYA RATING!
Mar 09, 2008 | Phoenix Gold R15.0:1 1500W Octane-R Mono...
Phoenix Gold Titanium 800.1 Car Audio Amplifier Logo
Top Phoenix Gold Car Audio & Video Experts
Mark Skinner
Jose Velazquez
Jose Velazquez
Are you a Phoenix Gold Car Audio and Video Expert? Answer questions, earn points and help others
