Question about Procom NetFORCE 1750 (NF-1750) Hard Drive Array
Unit keeps powering down every 15 minutes
Hi, Our NF1750 keeps powering down every 15 minutes or so. The Procom software doesn't detect the fan spinning on the processor, even though the fan IS spinning. Switching to the other processor slot has been tried as well to no avail. Has anyone had an experience with this? Is it a motherboard failure or something else? thanks
Check the internal sensors. There were 2 of them that sensed the internal temp of the system. the one in front sometimes would break. Those units also had a smart card that did all the montoring. Its the only isa card in the system. It can cause these weird problems.
Posted on Sep 03, 2007
Haam air conditioning split then I switch on come to E7 what is the problem in my a c please give me answer any parson
Malfunction of Outdoor Unit Fan Motor ( E7)
Remote Controller
Display
E7 Method of
Malfunction
Detection
Abnormality of fan motor system is detected according to the fan speed detected by hall IC when the
fan motor runs.
Malfunction
Decision
Conditions
?? When the fan runs with speed less than a specified one for 15 seconds or more when the fan motor
running conditions are met
?? When connector detecting fan speed is disconnected
?? When malfunction is generated 4 times, the system shuts down.
Supposed Causes ?? Malfunction of fan motor
?? The harness connector between fan motor and PC board is left in disconnected, or faulty connector
?? Fan does not run due to foreign matters tangled
?? Clearing condition: Operate for 5 minutes (normal)
Troubleshooting
Caution
Be sure to turn off power switch before connect or disconnect connector, or parts damage may be
occurred.
Replace the outdoor unit fan motor.
Connect the connector.
Remove the foreign matter.
YES
NO
Are fan motor
connectors
disconnected?
NO
YES
Is the pulse input?
Check No. 11 Check for pulse input
for number of rotations
on the outdoor unit
PC board.
Replace the outdoor unit PC board.
YES
NO
NO
YES
Is there
any foreign matter
around the fan?
Can the fan be
easily rotated by hand?
(S2584
Jun 07, 2016 | Heating & Cooling
It keeps going through a start up process (clicking and the fan come on then off quickly) at first staying steady then getting longer in the start up process.
Hi David, thank you for your inquiry. I understand that your Frigidaire Refrigerator is cycling on and off more than you expected. Todays newer refrigerator's have to meet Dept of Energy (DOE) specifications for energy savings. Typically the fan and compressor runs to get the fresh food temp down to 34*, the compressor shuts off and the fan runs for thirty more minutes and shuts down. The fan will repeatedly cycle on and off to keep the temp down as close to 34*. Once the temp in the fresh food hits 40* for more than two minutes the compressor cycles back on again. This will cause the temps in the fresh food to dwell between 35-40 and in the freezer section between 8-15. Hope this helps! -JK
Oct 28, 2015 | Frigidaire Refrigerators
How do I resync my ProCom remote with my ProCom Vent Free Fireplace? I have an older model, SSU320RHL-GB.
I ran into this same problem yesterday while I was trying to get my used unit up and functioning.
If you don't switch from pilot to off and wait about a minute before turning it to the "electric" mode, the remote will NOT light the unit.
Oct 24, 2014 | Procom SSU320RHN-GB Heater
Ventless wall heater shuts off during operation
Sounds like thermostat may have a battery going bad as to not supply sufficient power to turn on the relays. As safety procaution when a signal is weak or no longer detected the heater shuts down.
Nov 16, 2017 | Procom Heating & Cooling
Pf keeps coming up wont run
if you haven't tried this,unplug the power or shut the circuit breaker off for 15 minutes,this may reset the defaults on the unit,if this doesn't help,then shut off power to the unit and open up unit and disconnect each and every connector to check for poor conduction,then reconnect power,if this doesn't help then replace the c.c.u. central control unit
Apr 20, 2012 | Kenmore Elite Oasis 6809 Electric Dryer
Cooling doesn't stay on
The outside and inside coils may need cleaning. Clogged coils cause excess pressures and heat of the freon that can cause safety switches to shut er down. Eveen a faulty power relay in the outside unit.Otherwise you may need a serviceman to locate the cause.
Jan 21, 2012 | LG LS-L1210CL Mini Split Air Conditioner
The 15 min timer doesn`t work anymore tried getting a new switch and still nothing. Any suggestion?
Fan or electrical wiring or power source are suspect.
Fantek RTS2 is supposed to boost HRV/ERV system into high speed for 15 minutes.
http://www.iaqsource.com/category.php/fantech-ervs-and-hrvs/?category=1494
If new RTS2 is not working, then either the wire to HRV/ERV system is suspect, unit is not getting power, or the HRV/ERV system is suspect.
If you are using RTS2 for ordinary ceiling fan, then install regular on-off switch and see it that works.
Check that you are getting power to switch and to fan. Check circuit breaker.
Jun 22, 2011 | Fantech RTS2 15-minute Pushbutton Timer w/...
Unit shuts itself off after 10 -15 minutes
Protect mode will kick in whenever a fault is detected.
You get the unit not powering up, and sometimes you hear a clicking noise, that is the protection switch that keeps shutting down the unit.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Jan 08, 2009 | Samsung HT-WX70 Theater System
Procom NetFORCE 1750 (NF-1750) Hard Drive Array Logo
90 people viewed this question
Top Procom Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Procom Computer and Internet Expert? Answer questions, earn points and help others
