Question about 1995-1997 Chevy 3500 Truck Ignition Starter Alarm Switch
Camshaft sensor and crankshaft sensor does not corrilate,
Want to find out what timing is suppose to be se at?
  • mikehumble May 11, 2010
    What year and what motor? If it is 350 1995 is different than 1996 and up?
    Problem Solver:
  • 17 Answers
If the distributor has been pulled, it needs to be reinstalled as to fire on #1 TDC, To drop this distributor,
1) bring #1 piston to Top Dead Center (TDC) with the timing mark on the Harmonic balancer on the zero (or V groove),
2) Next the dist. will have a indentation (little dimple) at the very bottom of the shaft, while out of the motor, align that dimple with the white line on the oil pump flange (the ring that nestles on the oil pump) the white line should be vertical.
3) Now when you drop the dist. down to align with the cam, the rotor should rotate to a number stamped on the dist. base. Such as a # 8 for V8 or #6 for V6. This should now be setting correctly to fire on #1 while TDC. You'll have to be close on meshing the cam tooth because the distributor can really only fit against the back of the intake housing perpendicular.
4) Once you have this done slightly tighten the hold down clamp. The chances of it being dead on for timing are slim, so the timing will have to be adjusted with a programmable tech II scanner. Timing is not adjustable for this motor manually.
*Contrary to most people statements, There is no tan wire with a white tracer behind the glove box on this year (96-2000) This was discontinued after 1995, The only thing you accomplish by rotating the dist. is throwing the injectors out of wack because they are read by the CPS (Crank positioning sensor in reference to the Cam (Cam positioning Sensor) .Hope this helps.
Posted on Apr 25, 2009
    Sniper:
  • 124 Answers
1996 and newer 350 the computer controls the timing and it has to be set with a scan tool at +or- 2degrees
Posted on Dec 15, 2008
  • mikehumble Dec 19, 2008
    Have you fixed your problem?
My truck sonoma gmc 2001 dont past the emission test
Definition of Diagnostic Trouble Code P1345 Audi: Ignition Coil Power Output Stage 3 Short to Ground BMW: Misfire Cylinder 2 with Fuel Cut-Off Buick: Crankshaft Position (CKP)-Camshaft Position (CMP) Correlation Cadillac: Crankshaft Position (CKP)-Camshaft Position (CMP) Correlation Chevrolet: Crankshaft Position (CKP)-Camshaft Position (CMP) Correlation Ford: Cylinder Discrimination Signal (Signal From Camshaft Position Sensor) GMC: Crankshaft Position (CKP)-Camshaft Position (CMP) Correlation Isuzu: Crankshaft Position - Camshaft Position Correlation Kia: No SGC Signal (1.6L) Lexus: Variable Valve Timing / CMP Sensor Range / Performance Lincoln: Cylinder Discrimination Signal (Signal From Camshaft Position Sensor) Mazda: Cylinder Discrimination Signal (from CMP sensor) Mercury: Cylinder Discrimination Signal (Signal From Camshaft Position Sensor) Oldsmobile: Crankshaft Position (CKP)-Camshaft Position (CMP) Correlation Pontiac: Crankshaft Position (CKP)-Camshaft Position (CMP) Correlation Saturn: Crankshaft Position (CKP)-Camshaft Position (CMP) Correlation Toyota: Variable Valve Timing / CMP Sensor Range / Performance Volkswagen: Ignition Coil Power Output Stage 3 Short to Ground
Jul 19, 2015 | GMC Cars & Trucks
PO017 code on a dodge journey 2009
P0017 Dodge - Crankshaft-Camshaft Timing Misalignment Bank 1 Sensor 2Possible causes - Engine oil dirty
- Incorrect engine viscosity
- Crankshaft position sensor circuit is open or shorted
- Camshaft position sensor circuit is open or shorted
- Faulty crankshaft position sensor
- Faulty camshaft position sensor
- Timing gear misalign
Nov 13, 2013 | 2010 Dodge Journey SE
What does a crankshaft sensor do? what does a camshaft sensor do?
get a HAYNES repair manual, tells you what all sensors do ! the crankshaft sensor sends info to the SBEC, reguarding engine crankshaft position. the camshaft sensor reads camshaft position, sends a coded signal to the SBEC, which uses this info to determine whether the fuel injectors and ignition coils are correctly synchronized !
Feb 14, 2013 | Chrysler Sebring Cars & Trucks
Where is the camshaft and crankshaft sensor on 2001 Pontiac Grand Am GT 3.4 engine
camshaft sensor is going to be the sensor going to the head. and the crankshaft sensor is most likely around the area where the transmission and engine meet. if not then it would be around the area of the crankshaft pulley. the biggest pulley on your car.
Nov 24, 2012 | 2001 Pontiac Grand Am SE
What degrees t.d.c. do you set the 2000 Sephia 4 cyl?
On your model there is no distributor al the spark comes from the coil packs.So if your timing is off you can check it but you cant adjust it.If your timing is off its probably a bad camshaft position sensor ,a bad crankshaft sensor,a bad Power control module or incorrect installation of the timing belt.Check all of your alignment marks that there all where there supposed to be on the camshafts and the crankshaft.On the camshafts the dots on the camshafts line up with the arrows on the valve cover and the crankshaft line up the arrow with the notch in the pulley.If these are correct then I would recommend having the other sensors tested for proper operation at a local service station.
Mar 16, 2011 | Kia Sephia Cars & Trucks
Codep0016 what does it mean?
P0016 Chrysler
Crankshaft -camshaft timing misalignment bank 1 sensor 1
- The pcm detects that the camshaft position is out of phase with the crankshaft position
Probable Cause[s]
  1. Engine oil dirty or contaminated /Incorrect engine viscosity
  2. Open or short circuit condition
  3. Camshaft 1/1 position solenoid, camshaft phaser ,camshaft1/1 position sensor
  4. Crankshaft position sensor ,crankshaft,tone wheel or flex plate
  5. Camshaft,tone wheel or pulse ring
Mar 13, 2011 | 2006 Dodge Caravan
Need timing marks for 2001 pontiac grand am
no timing marks, timing is set at factory when new, crankshaft sensor and camshaft sensor control timing and fuel delivery to engine.
May 06, 2009 | 2001 Pontiac Grand Am SE
Need to find Camshaft position sensor and crank se
CRANKSHAFT SENSOR - Under hood, center, front engine area, rear of crankshaft pulley, mounted in timing cover assembly.
CAMSHAFT SENSOR - Under hood, passenger side, upper engine area, mounted on engine in front of camshaft.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 08, 2009 | 1995 Lincoln Town Car
1996 HONDA ACCORD CRANKSHAFT SENSOR AND CAMSHAFT SENSOR.
camshaft sensor is in distributor(requires dist. replacement) crankshaft is behind lower timing belt cover
Dec 12, 2008 | 1996 Honda Accord
1995-1997 Chevy 3500 Truck Ignition Starter Alarm Switch Logo
366 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
