Suffering with BO:STACK virus
We are using window 2003 server entreprise edition. Recentrly we receiving a message that buffer overflow and mcafee as stated it as BO:STACK. Provide the solution to remove this virus. Please send solution as quickly as possible
  • 5 more comments
  • egeseva Dec 22, 2008
    Thanks for your reply, we use protector plus for this virus.
  • ashok_jakkal Jan 03, 2009
    i have same problem in windows xp pro
  • farazali Jan 09, 2009
    my name is faraz ali, and i m bother to bo stack virus have u any solution to remove it, i will be very thankful to u.
  • Anonymous Jan 16, 2009
    i have same problem in windows xp..
  • Anonymous Jan 17, 2009
    i have same problem
  • Anonymous Jan 26, 2009
    Me too
  • Anonymous Mar 04, 2009
    BO:STACK is infected....Anyone can provide resolution?
  • 86 Answers
Trojan Hunter, Avast, BitDefender, Ad Aware, F-prot AV
All Free or at least Full Trails
Posted on Dec 11, 2008
BO:STACK is infected....windows2003 serve pls provide any solution
Posted on Oct 14, 2009
Stack over flow at line 195
This comes directly from Microsoft web page.
"If you try to open multiple modal dialog boxes in either of the following programs, you may receive a stack overflow error message:
  • Microsoft Internet Explorer 6 on a Microsoft Windows Server 2003-based computer
  • The Mshta.exe HTML program"
They say they have a hotfix so go to this page.
Jan 12, 2014 | Microsoft XP Computers & Internet
Stack overflow at line 3400
Stack overflow is created by BAD SOFTWARE. When it occurs not only does the
program crash, but depending upon other situations, special code may get called in
such a way as to literally 'take over the system'.
Stack overflow is an exploit that is used by many virus'. As most of these are
intentionally induced by buffer overflow, software updates are the typical fix to
avoid the condition.
1) make sure you have the latest fixes for your browser
2) stay current with MS Update
3) install Spywareblaster to avoid bad ActiveX *.ocx files
Jan 18, 2011 | Sierra Online, Inc. You Dont Know Jack 2
Stack overflow at line 598
Stacks are reserved memory that programs use to process hardware events. A stack overflow occurs when there is not enough space in memory to run the hardware interrupt routines. To resolve these behaviors, you can modify the "STACKS=" line in the Config.sys file, eliminate terminate-and-stay-resident program (TSRs), and eliminate hardware conflicts.
When Windows delivers an error message that is related to an internal stack overflow, there is not enough space in memory either set aside or available to handle the calls that are made to the computer hardware. There are several things to consider when you troubleshoot this behavior:
  1. The Config.sys startup file may not be properly configured for the Windows installation. Use the following values: STACKS=64,512 ;(this is the maximum allowed)
    BUFFERS=40 If you are using the dual-boot capabilities in Windows, the Config.sys and Autoexec.bat files may not contain the correct configuration to run Windows. When you are dual-booting between Windows 3.x and Windows, these files may not have been renamed back to Config.dos and Autoexec.dos.
    Examine the Config.sys file to determine if files such as Himem.sys or Emm386.exe are loaded from a folder other than the Windows folder. If so, boot Windows by using the Safe Mode Command Prompt Only option. Rename the Config.sys file to Config.dos and the Autoexec.bat file to Autoexec.dos, and then restart your computer.
  2. Some TSRs may be interfering with Windows. Disable any non-boot device drivers in the Config.sys and Autoexec.bat files. If you install from Windows 3.x and you receive a stack overflow error message, check the Win.ini and System.ini files for non-Windows-based programs or drivers that are loading.
  3. There may be an incompatible hardware configuration. Check the port and IRQ settings of the network adapter, sound card, and modem. Make sure that there are no COM2/COM4 or COM1/COM3 conflicts and that no devices are sharing IRQs. Disable or remove conflicting devices.
  4. The computer may need a BIOS upgrade. Check the BIOS version and contact the manufacturer of your computer for information about a BIOS upgrade.
Hope this helps. Please rate my response.
Have a good day
Dec 28, 2010 | Microsoft Computers & Internet
Receive duplicate emails and error messages: pop
Look for your Security Email Firewall settings (Mcafee, Norton , etc ). Got to Email protection > Disable Incoming \ Outgoing mail protection. That should do it.
Mar 31, 2010 | Microsoft Windows XP Home Edition
Computer pop up
IE: stack overflow at line: 0 Today, I noticed the following issue (IE only, of course). Running a page that does some comet (via “XHR GET” for long-polling), I got the following warning: “stack overflow at line: 0′ and the application stopped working…
I did some google-searches and found some “hints” that said I should disable my third-party tools for IE etc. That sounds strange…
In fact the problem was the odd cache behavior of the IE. The XML (from the “long-polling servlet”) was cached and its JS was executed; also the application itself started the polling too, so I (no IE) ran into this odd issue…
Changing the server-side code – that is responsible to render the XML – to have no cache rules (e.g.”Cache-Control”:”no-cache”) did the trick. It worked again. Of course, on your “comet output” you potentially don’t want cache to be present…
So fixing the cache solved the issue. There was no need to disable Norton or any other third-party tool… icon_smile.gif
Mar 28, 2010 | Microsoft Windows XP Home Edition
My computer giving on access-protection:virus
Please download Malwarebytes' Anti-Malware from the link below:
Double Click mbam-setup.exe to install the application. (If the file won't run correctly, try renaming it to something else, like "gogetup.exe", then double click it to install it. Some variants of malware will prevent the "mbam-setup.exe" file from running.)
* Make sure a checkmark is placed next to Update Malwarebytes' Anti-Malware and Launch Malwarebytes' Anti-Malware, then click Finish.
* If an update is found, it will download and install the latest version.
* Once the program has loaded, select "Perform Full System Scan", then click Scan.
* The scan may take some time to finish,so please be patient.
* When the scan is complete, click OK, then Show Results to view the results.
* Make sure that everything is checked, and click Remove Selected.
* When disinfection is completed, a log will open in Notepad and you may be prompted to Restart.
* The log is automatically saved by MBAM and can be viewed by clicking the Logs tab in MBAM.
Extra Note:
If MBAM encounters a file that is difficult to remove,you will be presented with 1 of 2 prompts,click OK to either and let MBAM proceed with the disinfection process,if asked to restart the computer,please do so immediately.
Feb 27, 2010 | Microsoft Windows Server 2003 Enterprise...
A New problem I face with mcafee Antivirus 8.5.0.i
I agree. Re imaging or reinstalling the windows operating system seems like the only fix at this point since it seems like the anti virus isn't picking up the virus. Back up the files on an external hard drive and just reinstall windows.
Mar 30, 2009 | Acer Aspire 5100 Notebook
dear sir
there is no tool to start mcafee services.
you have to start manually. please do the following
start > run > services.msc(please type this)
services window will start. from there you have to right click on mcafee antivirus & then click on start.
you problem will solve.
Dec 23, 2008 | Microsoft Windows Server Standard 2003 for...
Computers & Internet Logo
1,331 people viewed this question
David Payne
David Payne
