Question about iLO Televison & Video
Component video trouble no signal
I can not get a signal
    Genius:
  • 1,199 Answers
Hit av button on remote
Posted on Dec 11, 2008
Ping/Green Bars on TV Display
I would first check and replace the cables to make sure you have clean signal. If that all checks out then I would consider putting in an amplifier in line to boost your signal. What is the distance you have on the cables all combined? Another thing to check in troubleshooting is to remove everything (cables) except the unit you are experiencing trouble with. If after all of this I would say your connection to your component itself is suspect.
Jan 27, 2014 | Denon AVR-4308CI Receiver
No signal conecting wii with component to samsung p2370ms monitor
Remove the memory card from the wii , try again and it will work !
Oct 11, 2012 | Nintendo Wii Console
Im trying to connect my unit to my tv to record shows and i having trouble doing so please help i am hooking it up wrong
For OTA or CATV signals, you need to daisy chain the coax from the source (antenna for OTA) to the coax input on DVD recorder and then the coax out to the coax input of the TV. If you have a set-top cable box with an incoming CATV signal, it should be connected between the DVD recorder and the TV.
The unit can tune in and record 480i (SD) ATSC (OTA digital), NTSC (OTA analog), analog CATV and digital CATV channels.
A satellite receiver or a non-CATV cable box should get the incoming signal first and then have their composite video output (A/V) connected to the DVD recorder composite video input and then their coax (RF) output (if present) gets connected to the TV. For these, you would record from the IN1 or IN2 (press Select Input) instead of selecting a channel. Then connect the composite video out on the recorder to the TV's composite video in.
Digital signals are either enough to tune in or give no signal. So check that your antenna is correctly oriented for OTA.
Separately, you can connect the video signal when playing DVDs via composite (good signal) out and component out (better signal) out to the TV's matching input. For the component video, the sound is carried on a separate cable. Then set the TV to the input source.
In the case of wanting to watch a VHS tape while taping to a DVD, do not use the Component video source, set the TV to Input 1 (composite).
I hope this helps.
(you can get a copy of the manual here: http://tv.manualsonline.com/manuals/mfg/panasonic/dmrez47v_dmrez475v.html )
Nov 25, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
Contols are delayed. Using a digital tv but using component cables. Is this the cause
no, are they new remotes/ they dont have a signal to your xbox/ if not the remotes are having trouble with reading the games setting and may be warring out
Oct 18, 2010 | Microsoft Xbox 360 Console
Has trouble getting input signal
This unit has a defective hdmi board,this is a common problem with this model. The unit is to be taken to a onkyo service center for exchange of the hdmi board under warrenty, if out of warrentyit will cost you several hundards of dollars.
Apr 19, 2010 | Onkyo TX-SR606 Receiver
I just got a Denon AVR-588 7.1 Channel reciever w/ no video
Dear,
I donot think AVR588 is capable of down-converting from HDMI to component, so if you input is only HDMI and output is component, it will not work. ( see page 53 in trouble shooting as also page10 of the manual).
Therefore, you will need to match your input with your output.
If you are not too fussy, the component video signal is probably as good..You will hardly see a difference unless your AVR is capable of up-conversion, still the real difference can really be seen only on HD.
Best is to connect all the analog connections as well and enjoy.
Mar 12, 2009 | Denon AVR588 Receiver
Component input- no audio/video signal
what aiudio cable uusing with couplunt cables red white on same input ?
Oct 07, 2008 | RCA P61310 TV
No signal form DVD Player
Yes, it will support Video Component connection.
Aug 06, 2017 | RCA 20F424T 20" TV
Samsung HD Plasma - hooked up DVD to it but movies play in black & white??
anytime you connect componet signal (green red and blue)to regular video inputs (yellow) end will have same effect. make sure that if you are using component signal from DVD player you have to connected to component input in the set.
component signal will use green red and blue for video and red and white for sound.
Composite signal will be yellow (video)
red and white(audio)
Jul 10, 2008 | Televison & Video
Component Video losing sync with too much White signal
I had this exact same issue. I tried two different component AV switches, and shorter cables to prevent signal loss, but any time there was too much white on the screen, the video still lost sync. Plugging the sources directly into the TV solves this problem, but since I have a DVD player, a game console, etc, this was not acceptable. The way I resolved it was to (sadly?) buy an expensive component AV switch that can support the bandwidth without losing the signal.
I wound up spending the extra money on a Key Digital 4x1 component switch. It is much more expensive, but it works.
May 02, 2008 | Onkyo TX-SR604 Receiver
Televison & Video Logo
51 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
