Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Hotpoint wd63 I need to replace the heatshield on the door of the unit but can't see how to remove the old one. Need advice on how to remove the plastic cover from the outside of the door
    President:
  • 1,462 Answers
Take door off. outer porthole is just clipped into frame. gently prize out with a small screwdriver
Posted on Mar 22, 2007
How to remove a L/Front fender on a 1996 Mazda 626
Fenders are bolt on. Remove the plastic inner wheel well. Rais the hood. Remove bolts along too, in door jamb and inner wheel well. Most vehicles also require removing the front bumper cover, headlight assembly and sometimes the grill. You should be able to see the bolt hole locations on the replacement fender. Once you install it do not tighten up the bolts. You'll need to align the fender til the hood to get a narrow consistent seam then tighten the bolts.
Feb 10, 2017 | Mazda Cars & Trucks
Tip
How do I change freezer door opening side?
Hi.
Details on how to change the fridge door opening side depend on the appliance model.If this is a chest unit, you will simply need to rotate the unit. On most upright units the general procedure to change door opening orientation is more or less the one ilustrated below:
  1. Disconnect power from the appliance.
  2. Get to the top side of the unit, and remove the hinge plate. This is usually held by two Torx or Philips screws. You may need to help yourself with a putty knife to remove a protective panel covering the plate. Be careful not to damage any part.
  3. Remove top hinge and put it on one side.
  4. After removing the plate you may need to remove the plastic clip located at the top on the handle side of the door, oppositely to the old hinge side. Use the putty knife to pry up and remove the plastic clip.
  5. Open the door and lift it from the lower hinge pivot.On many fridges you will have to remove the bottom hinge too, often held by two screws, and covered with a proective pane, to free the door before removing it
  6. Carefully place the door on the floor.
  7. Remove protective panels on top and bottom on handle side of the frige cavity, reinstall the hinges on handle side position, swapping them with the protective panels.
  8. Remove the door pivot and mount it on the opposite side.
  9. On the door disassemble and refit handle or any other part if needed.
The precise and complete procedure is usually illustrated on the appliance user manual. If you need manual or schematics, try asking a new Fixya question. Ensure that you are providing full model number, as printed on service tag.
To get more detailed info you can also try calling the appliance manufacturer at the number listed on the owners manual.
Regards.
on Mar 30, 2010 | Refrigerators
How to remove the front drivers side door panel
I usually look for screws covered by plastic plugs any trim covering handle and a door panel prybar tool or use a small screw driver to locate small plugs behind panel and carefully pry away panel.
Jun 01, 2014 | 2001 Oldsmobile Silhouette
How do u. Replace a window regulator on a 01 olds aurora
Re move door panel, might have to start with window switches.The whole cluster comes out,unplug them. Any other stuff I.e. mirror switch. Some where by the door handle is self should be some plastic covers,behind them are screws. Remove those and gently lift up. Remove plastic wind paper.and you should see inside the door.Window switches may need to be plugged back in to assest.
Oct 16, 2013 | Cars & Trucks
Replace door handle on rear right hand side buick regal custom 1995
big job ,Requires a chilton manual ,take inside door panel off door handles crancks etc. cover pops off then remove inner cover window up reach in and unpin linkage to old handle .unbolt old and bolt in new one ,Caution not to break fragile plastic clips,Advance sells them in there help isle if you need them.Reverse steps and bang your done
Jun 11, 2011 | Buick Regal Cars & Trucks
Trying to replace handle on GE microwave oven #JVM1631WB. Have already removed plastic cover that trims the glass on the inside of the door. This exposes two screws on the handle of which I have removed....
You order parts and find helpful exploded view diagrams here.
I'd recommend that your bookmark this link to your favorites.
Jan 29, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I need to know how to replace the side mirror on my 2003 Chevy Tahoe. It is a heated mirror and I need to replace the whole unit. I especially need to know how to take off the door panel to unhook the old...
Well, technically you dont have to remove the door panel to remove the outside door mirror. At the top of the door panel, at the front of the door, there is a triangle shaped plastic cover. It's held in place with push clips, so pull that cover off and remove the foam insulation and you'll be able to access the 3 nuts that hold the mirror to the door. The only potential problem could be in unplugging the wiring harness. I use a hooked pick to pull up the harness to unplug it.
Dec 30, 2009 | 2003 Chevrolet Tahoe
How do you change the belt?
Two methods:
1) If your vacuum has the small side door on the cover of the lower unit, can remove the screw, it will allow you to access the belt. I assume old belt is broken, so what you see will be the end of the motor shaft ( a small, round shaft about 1/4" in diameter) and the end of the brush roll, (about a 3/4" to 1" round plastic knob attached to the end of the brush roll.) Make sure each of these turns freely, otherwise you are going to burn up another belt. Slide belt over these two points, replace the access cover, and turn on.
2) If you have an older unit or maybe the commercial unit, you will need to remove the bottom cover. A bunch of screws, don't remember how many at this time. After you remove the cover, you will see the two points I described above. Replace belt then replace the bottom cover (called a baseplate on a parts diagram probably). Make sure the rubber bumper is properly seated, it can be a pain sometimes.
While inside the unit under either scenario, I always would try to clean out any excess dirt, dust, etc.
Sep 29, 2009 | Oreck XL Ultra Bagged Upright Vacuum
How to fix a new window regulator
normally on the honda models there are two screws that need to be taken out, the inside latch area (plastic cap covering it) and the door pull (normally down in the bottom covered with a plastic cap), thin small flat blade will work to remove. once the is done you will need to pull out the latch area on the passenger door or the driver window control panel, disconnect the connectors. set the aside, next you will need a thin flat blade screw driver or flat pry bay, start at the bottom of the door to pry out the panel ( will make a loud snapping or popping noise, this is normal) once you have loosened the panel, you will need to remove the plastic covering the access to the mirror (small triangle black plastic piece). this should now allow you to set the door panel aside, check to make sure you have removed all the clips. carefully remove the plastic lining cover the door, try not to tear or rip it. now you will need to remove the glass, there are two holes the allow access to the bolts for the window, connect your Power window switch and raise or lower till you can see them ( possibly a 10 mm socket) unscrew and set aside, hold the top of the window with one hand and lower the window to separate it form the brace. tilt the front side of the window down and remove glass set aside, now there are three screws for the regulator ( normally around the center of the door) and 4 crews or bolts , two on each window track, top and bottom) remove both bolts on each side. at this point everything should be loose, you will need to twist to get all the old parts out, replace your new parts and re assemble as you have taken apart, most cases this is about three to four hours, Good Luck !!!
Sep 12, 2009 | 2000 Honda Civic
Need instructions to replace drivers side rear view mirror glass.
Outside Mirrors REMOVAL & INSTALLATION The mirrors on these models can be removed from the door without disassembling the door liner or other components. Both left and right outside mirrors may be either manual, manual remote (small lever on the inside to adjust the mirror) or electric remote. If the mirror glass is damaged, replacements may be available through your dealer or a reputable glass shop in your area. If the plastic housing is damaged or cracked, the entire unit will need to be replaced. Manual
  1. Remove the set screw and the adjustment knob, if equipped.
  2. Remove the delta cover; that's the triangular black inner cover. It can be removed with a blunt plastic or wooden tool. Don't use a metal prytool; the plastic will be marred.
  3. Fig. 1: Use a tapped ended tool to pry the trim from the mirror 89550g29.gif
  4. Depending on the style of mirror, there may be concealment plugs or other minor parts under the delta cover — remove them.
  5. Support the mirror housing from the outside and remove the three bolts or nuts holding the mirror to the door.
  6. Remove the mirror assembly.
  7. Installation is the reverse of removal.
  8. Power
    1. Turn the ignition key to the OFF position. Disconnect the negative battery cable. Wait at least 90 seconds from the time the negative battery was disconnected to start work. CAUTION
      Some models covered by this manual may be equipped with a Supplemental Restraint System (SRS), which uses an air bag. Whenever working near any of the SRS components, such as the impact sensors, the air bag module, steering column and instrument panel, disable the SRS, as described in Section 6.
  9. Depending on the style of mirror, there may be concealment plugs or other minor parts under the delta cover — remove them.
  10. Depending on the type of door trim, you may need to remove the door inner panel to access the electrical wiring harness for the mirror.
  11. Support the mirror housing from the outside and remove the three bolts or nuts holding the mirror to the door.
  12. If the wiring to the electric mirror was not disconnected previously, detach it now. Some connectors can only be reached after the mirror is free of the door. Remove the mirror assembly.
  13. Installation is the reverse of removal. Cycle the mirror several times to make sure that it works properly.
Jul 23, 2009 | 1996 Toyota Camry
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
61 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
