Question about Pioneer AVIC-F700BT Car GPS Receiver
Parking brake bypass
I am looking for a way to bypass the parking brake so that I can change my desitation while on the move.
  • Anonymous Feb 16, 2009
    Did connecting the handbrake wire to the ground work?? Is the green wire for the handbrake specific to the deck or the car? Can you really watch movies AND change NAV points while driving now?
  • Anonymous Mar 03, 2009
    IT THINKS THE PARKING BRAKE IS ON WHEN GREEN WIRE CONNECTS TO THE GROUND, BUT AT THE SAME TIME, GPS DETECTED THE CAR IS MOVING. IT WILL NOT LET YOU CHANGE NAV SETTING AND THE ANNOYING BRAKE WIRE TEMPERING LAWYER SCREEN WILL POP UP. THERE IS NO WAY TO OVERIDE IT.
Connect the hand break wire (light green) to the ground wire (black). It tells the system the hand break is up and even movies work :) .
Posted on Jan 09, 2009
  • 3 Answers
Http://www.avic411.com/forum/viewtopic.php?t=18977 best website for pioneer in dash units
Posted on Feb 25, 2009
Unlocked-4ever@hotmail.com
Email this address. For Ten bucks he sold me a solution that works and is easy to do.
RALPH
Posted on Dec 22, 2008
How to bypass jensen
There is a wire which grounds to your parking barke mechanism from your system. You must move this to another (fill time) ground.
Jul 15, 2014 | Jensen Car Audio & Video
Parking break bypass axxera axv820
You can try attaching the parking brake directly to ground to bypass the issue. However, some systems require a change in voltage each time system is powered down. If this is the case, you can place a toggle switch inline with the parking brake wire, attaching one side to the wire and the other side to ground, allowing you to apply the ground and remove it when necessary.
Feb 11, 2013 | Dual Car Audio & Video
How to bypass parking brake
  • The parking brake wire is a ground engaged when you have the parking brake on. So just ground the wire. Make it a very solid ground or it won't work. You basically changing the grounding location from the parking brake to a different ground. When you put it on a new ground it will be active anytime. Where as with the parking brake, the wire only gets a ground when the parking brake is engaged, follow?
  • As far as just bypassing it flat out as in not using the wire you can't, not for viewing the screen anyway. The ground wire is a safety feature and must be grounded somewhere to view the screen.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jun 24, 2011 | Pioneer AVIC-F700BT Car GPS Receiver
Putting kenwood kvt 617 dvd in rear of surburan how can i bypass parking brake so movies can play while driving
On bypasses you can either hook the parking brake wire straight to ground, if that does not work you can install a toggle switch between the parking brake wire and ground so you can mimic the parking brake on off.
Jun 04, 2009 | Kenwood KVT-617DVD Car DVD Player
How do i bypass parking brake so i can watch movies
There is a parking brake switch lead that goes to the unit. You need to permanently ground it to bypass the safety feature.
Apr 28, 2009 | Car Audio & Video
How do i bypass the parking brake switch in order for my video to play
Take the wire that they tell you to hook to your parking brake and hook it to ground instead.
Feb 27, 2009 | Pioneer Car Audio & Video
apply 12v positive to the wire to bypass the parking brake
Dec 12, 2008 | Jensen VM9510 Car DVD Player
Bypass the parking brake
forum.ecoustics.com/bbs/messages/4/338612.html
Jul 31, 2008 | Car Audio & Video
To bypass the parking brake you should connect the parking brake wire from the unit to ground. It is better to do it via a switch because is illegal to watch video while you're driving. :)
May 15, 2008 | Car Audio & Video
Bypass e-brake wire
Normally, to by-pass, you need to ground the yellow/blue wire of the Dual XDVD 8183. This would simulate the condition where the vehicle is in “Park” and the parking brake is engaged thus allowing the unit to operate even if the vehicle in reality is not in “Park” and/or the parking brake is not engaged. Some regions have restrictions on this condition.
Additionally, some versions would require a SPDT switch moving the yellow/blue wire from 12V+ to GND to be bypassed.
Hope this be of help/idea. Pls post back how things turned out or should you need additional information. A friendly reminder pls, "Drive Safe".
Good luck and Kind regards.
Jan 07, 2008 | Car Audio & Video
Pioneer AVIC-F700BT Car GPS Receiver Logo
2,335 people viewed this question
Top Pioneer GPS Experts
David Burbee
David Burbee
Are you a Pioneer GPS Expert? Answer questions, earn points and help others
