Question about Reddy R155D Utility Heater
Can not adjust air pressure to keep it running!!
I can get the unit fired but the pressure will not adjust. If put a clamp on the fuel line to restrict the pressure it runs fine (air pressure is still not right) , but when the top cover is placed on the unit the flame goes out!!!
  • Anonymous Jan 14, 2009
    can't adjust presure
  • 232 Answers
Provided the rotor and vanes are serviceable the pump should produce around 10 psi if you completely close off the airline tubing. If your gauge will not read with the tubing totally restricted, then I would check the relief valve to see if the ball is in first, then the spring, then the screw with the hole. These items should be in the longer of the 2 bosses. If no pressure reading at this time you either have a broken rotor or a defective gauge.
If you get some pressure with the tubing restricted, but there is not enough, then use soapy water to find the air leak. If there is a crack in the plastic end cover- replace it.
How to set the pump pressure
Posted on Dec 11, 2008
  • John Fleming Dec 07, 2011
    try replacing the air pump rotor and vanes, I had the same problem until I replaced them.
Ford E350 fires but won't continue to run. Seems to be starved for fuel.
I am assuming the engine is gas..
Have you checked base fuel pressure with a gauge ?
Does the engine use a MAF sensor in the air intake ?
Apr 09, 2013 | Ford E-150 Cars & Trucks
Evap system
The FSM is clear on this. each hose and fitting must be air tight.
or the the car vents gas fumes full time, and the EVAP ECU tests
(monitor) make sure this all works.
you can just look at the left and right side above rear tires. and see
if your hands are small enough to fit here. Id bet not.
some mech, report, the tank can be tilted down at front (drained fuel)
and gain access.
keep in mind, you get fuel siphoning at any time. do not open the system, with fuel in the tank, and then drive to autozone,
i loosen the gas cap so that pressure can not build in tank.
expanding fuel can push fuel out , during a filter change. very
dangerous in a garage, and you gone.
it's just a vent hose, you can see, it and what needs to be done is really obvious. given you arms sides and lenght.
my fsm states, " TANK pull"
Removal & Installation
  1. Relieve the fuel system pressure and disconnect the negative battery cable.
  2. Remove the fuel filler cap from the fuel tank.
  3. Have a Class B fire extinguisher near the work area. Use a hand operated pump device to drain as much fuel through the fuel filler neck as possible.
  4. Use a siphon to remove the remainder of the fuel in the tank by connecting the siphon to the fuel pump outlet fitting.
    CAUTION Never drain or store fuel in an open container because there is the possibility of a fire or an explosion.
  5. Reinstall the fuel filler cap.
  6. Remove the rear seat cushion from vehicle (if so equipped).
  7. Disconnect the fuel pump motor connector and sending unit electrical connectors.
  8. Disconnect the wire harness grommet and harness through the vehicle floor pan.
  9. Raise and safely support the vehicle.
  10. Remove the fuel filler hose clamp from the filler neck assembly.
  11. Remove the fuel breather hose clamp from the filler neck assembly.
  12. Remove the fuel filter inlet hose clamp and hose from the filter.
    NOTE A small amount of fuel may be released after the fuel hose is disconnected. In order to reduce the chance of personal injury, cover the fitting to be disconnected with a shop towel.
  13. Remove the fuel vapor clamp and hose, and fuel return hose clamps and hose from the respective fuel lines.
  14. Using a suitable transaxle jack, support the fuel tank.
  15. Remove the fuel tank retaining bolts and lower the tank.
To install:
  1. Reconnect all fuel hoses, lines and the fuel breather hose to the fuel tank.
  2. Place the fuel tank in its proper space using the transaxle jack, Install the fuel tank retaining bolts.
  3. Remove the transaxle jack.
  4. Reconnect all fuel hoses, lines and the fuel breather hose to the fuel tank.
  5. Install the fuel breather hose and hose clamp to the filler neck assembly.
  6. Install the fuel vapor hose and hose clamps. Install the fuel return hose and hose clamp to the respective fuel lines.
  7. Install the fuel filter inlet hose and hose clamp to the filter.
  8. Lower the vehicle. Install the wire harness and grommet through the vehicle floor pan.
  9. Connect the fuel pump motor and the sending unit connectors.
  10. Install the rear seat cushion. Reconnect the negative battery cable.
Mar 26, 2013 | 2002 Suzuki Esteem
Where is fuel filter located on 98 sidekick 4dr auto 4wd 4cyl?
1. Raise the vehicle. Check to make sure the supports are safe and secure. Take a drain pan and several clean shop rags to mop up any spilled fuel.
2. Crawl under the right side of the vehicle between the front and back wheels. Set the drain pan under the fuel filter to catch any fuel that drains from the lines.
3. Press the fuel line clamp tabs with a pair of pliers and detach the fuel lines from the fuel filter. Slide the clamp down both fuel lines away from the fuel filter while maintaining pressure on the clamp.
4. Note the position of the fuel filter inlet and outlet nipples before removing the fuel filter. Remove the lower clamp bolt and loosen the clamp adjusting bolt. Remove the filter from the mounting clamp. Lift the fuel filter out of the mounting clamp.
Install the Fuel Filter:
1. Work under the vehicle. Slide the new filter into its mounting clamp. Tighten the adjusting bolt until it's snug. Turn the filter in the clamp so that the inlet and outlet nipples are in the same position as before removal. Tighten the adjusting bolt. Put the lower clamp bolt in position. Tighten it securely.
2. Connect the outlet hose to the top filter nipple. Connect the inlet hose to the lower nipple. Push the fuel lines up over the nipples as far as possible. Compress the fuel line clamp tabs and slide the clamp up each line until it is secure over the nipple.
3. Position the clamps at least 1/4 inch from the connected end of the fuel lines, making sure the clamps are set over the nipples. Start the engine and allow it to idle. Check for fuel leaks and make the necessary adjustments. Turn the engine off. Lower the vehicle.
Oh and if you missed it, filter is attached with a bracket to a crossmember in front of the fuel tank on the passenger side.
Thank you for using fixya and be safe.
Apr 10, 2010 | 1998 Suzuki Sidekick
My Dyna Glo heater forced air heater worked great last year. I run it on Diesel and ran it empty before putting it away for the summer. Went to fire it up and it wouldn't work. Replaced all of the cracked...
the filter in the tank line is partially clogged with gel from useing diesel fuel you should really use a anti gel agent when running a sulphur type fuel in a unit designed for white gas/ keosene
Jan 20, 2010 | Kitchen Ranges
Husqvarna 55 chainsaw won't stay running.
It has a crack in the fuel line between the body and the tank. The crack lets air in the line. Replace the line.
Jun 03, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Jan 27, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Have a 1999 nissan max,I am somewhat mechanically inclined and have checked all the fuses.I checked one of the plugs an it does have fire.I pulled the line off the fuel filter and fuel did come out when i...
That sounds like a smililar problem i had. If you pull the fuel line off of the fuel filter, gas should shoot across the parking lot. Not trickle out like a water fountain. My 99 maxima did the same thing and what I found the problem was, was that the fuel line on top of the fuel pump it's self inside the gas tank and blown off. Because nissan put a stupid squeeze clamp on it instead of a screw tight clamp. Pull your the top of your sending unit off and I guarentee you it's not connected to the fuel pump. What's happening it the engine is running off of suction from the gast tank which is why it's only comming out like a water fountain. reconnect the hose back to the fuel pump and put a screw clamp on it prime the system back up and it should start.
Jan 22, 2009 | 2002 Nissan Maxima
Reddy Heater RM60 HSI Forced Air Heater: Pump Pressure Issue!!
ground wire on the circuit board needs to be checked and these units need to have a GOOD three wire cord with a proper grounded outlet
Jan 21, 2009 | Reddy Heater-30-55,000 BTU Variable
Reddy heater will not fire.
Your problem is most likely the lack of pressure from the air pump. Your pressure is extremely low. Pressure on a 100k heater should run 5psi. At 3psi there is not enough fuel and not enough air to atomize whats there. Bump the pressure up. If it won't come up, then you have an air leak. Test w/ soapy water. Keep your fingers clear of the fan!
Dec 04, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy R155D Utility Heater Logo
67 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
