Question about Frigidaire PHS67EHS Side by Side Refrigerator
Fridge & Freezer not cooling
Freezer temp is 61 deg F.
Fridge temp is 66 deg F.
Lights are on, just no cooling action. Guessing it quit cooling around 5pm...just noticed it around 7pm. Has been making a "rough" motor sound off and on since last Friday, only noticed it when it was making ice. My refrigerator is only ONE year old...HELP!
  • 36 Answers
I think you have a bad compressor pull it out and take off the back panel and feel the compressor if it is hot and making a bad sound it might be an over load relay
Posted on Dec 11, 2008
We recently had a power outage, now the interior light is flashing and the fridge is not cooling
Try resetting the fridge and freezer temp, fridge 4 deg C freezer -18 deg C turn the unit off at the power socket leave for a minute then turn on be fore resetting.
Mar 03, 2016 | Liebherr Refrigerators
THE FREEZER WORKS FINE THE THE FRIDGE LIGHT ITS BLINKING AND STAYS AT TEMP @ 66 WHAT CAN I DO?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 07, 2011 | Refrigerators
Westinghouse fridge thermostate replacement
Without drawing a diagram, and assuming you have the controller, you need to do two things: Power the controller by finding a wire pair in the fridge that is always hot, and finding the wire that the resident thermostat uses to interrupt the operation of the compressor. This thermostat is usually located behind a panel in the top part of the refrigerator section and has a bulb that resides in the freezer. . Your controller should have an on and off range; that is, it should cut the fridge on at, say 61, and cut back off at, say, 60. You'll need some kind of range, thereby giving the compressor some "off time" of more than a couple of minutes. If you don't do this, you will reck the compressor, or it simply won't start. (Refrigeration systems need to equalize so that the compressor motor won't have to start when the pressure is really high. At equal pressure between evaporator and condensor, the motor can start easily.) . You have quite a project ahead of you. I suggest when you get into the nitty gritty of it, enlist your neighborhood MacGyver type. It shouldn't be that hard to pull off this project.
Nov 25, 2009 | Westinghouse Refrigerators
2001 GE side by side refrigerator model TGX26KRDA WW Beginning about a month ago the refrigerator temperature rose to 60 deg. F. Freezer remained well below 0 deg F. Checked baffle which was open and...
Is the fan that moves the air from the freezer to fridge running If there is a switch in cabinet somewhere the freezer door would contract it, with door open push in switch hear the fan both are good. Don't hear fan check evaporator or freezer fan and that switch it may be a duel switch open light closed fan run. Tricky there are light switches, when out light on or when switch is in its lights out
Mar 17, 2017 | GE Refrigerators
Temp problem. freezer temp 0 deg. fresh food 46 deg.
An hour aint enough. Turn off fridge, use blow drier, thers a huge ice cube behind that sheetmetal wall back of freezer inside wall, it takes 48 hours at 75 degrees to let it do itself. Listen for inside motor, its obvious. If so, you hve a defrost problem.
Mar 12, 2009 | Refrigerators
My fridge quit cooling...lights are still on but no cooling action. was making a bad grinding noise that I thought was happening when it was making ice but now I'm not so sure. It's only one year...
may be your unit is not defrosting and the grinding noise could have been the fan tuching on the build up of frost, you need to check your timer or defrost thermostat
Dec 11, 2008 | Refrigerators
Fridge only cools to 55 deg F
check the bottom of Ref. see if it close right, sometimes the rubber near the bottom parts broken.
Jul 08, 2008 | KitchenAid KSRS25IL Side by Side...
GE PFS22MISBBB freezer not cold enough. Temp won't reset.
replace the fan as quickly as possible it may be shorting and causing damage to your control board,
Mar 30, 2008 | GE PFS22SBSSS Stainless Steel French Door...
Kenmore sidebyside
Hi! There,,,If you want help, one needs to explain the problem.. A refrig is quite simple in opertion, with time used experience. For a side by side the freezer is cooled with the same system as the refrigerator cooling system. One and only. Freezer works, do you mean it is provining design temperature of some -10 deg F??? Do you have a by-pass duct between the the two. yes, then open it up more, disconnect motor is auto, and prop vent open, set refrig temp to a low temp say 40 deg F. are we cooling??? Post your condition, if you want further info Regards,,,fmauka
Sep 05, 2007 | Kenmore 74822 / 74824 Top Freezer...
Frigidaire PHS67EHS Side by Side Refrigerator Logo
132 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
