Question about Dell Latitude D800 Notebook
I have a dell D800 it won't power on at all the battery show full
Please help
  • TrytoFix01 May 11, 2010
    Have you verified if the power cord is ok?
    New Friend:
  • 10 Answers
If you can borrow a Dell docking station, use it to see if your laptop will power up using its power button. If it does (and even if you cannot borrow a docking station), your problem could be simply a a loose connector beneath the power button.
Using a small screw drive on the left edge of the Center Control Cover (just beneath the display/cover hinge and above the F1-F12 keys), pull up the cover. Locate the cover's flat ribbon cable connector above the Page Up key. Pull it up and carefully reinstall.
Try the power button now. If it works, put everything back together. Otherwise seek profession help.
The Dell D800 service manual is presently available from Dell....
Google search = dell d800 service manual
ftp://ftp.dell.com/Manuals/all-products/esuprt_laptop/esuprt_latitude_laptop/latitude-d800_service%20manual_en-us.pdf
Posted on Sep 22, 2013
    Problem Solver:
  • 8 Answers
Try removing the battery and plugging it into the wall. then turn it on, if it turns on your battery is bad or connected improperly.
Posted on Dec 11, 2008
Dell latitude d800 not switching on ?
I may have addressed this question earlier. If your Dell shows absolutely no sign of life... no LEDs, no nothing and you know for certain the battery and/or power adapter is good then...
If you have access to a docking station (ANY Dell dock that will mate with the bottom connector on your D800), put the D800 in the dock and use the power button on the docking station.
If the laptop powers up, you may have a simply problem with the laptop "Press to turn on" button.
ABOVE THE LAPTOP KEYBOARD...
Use a small flat screwdriver blade to remove the Center Control Cover (just beneath the display/cover hinge and above the F1-F12 keys). Locate the cover's flat ribbon cable connector above the Page Up key. Pull off and carefully reinstall. Try the power button now. If it works, put everything back together. Otherwise seek profession help.
May 02, 2014 | Dell Latitude D800 Notebook
I need to unlock a bois pass word for dell latitude D800
The best way to unloc a BIOS password is to reset by removing the CMOS battery and while the mains is removed press the power button a few times and leave for about 30 seconds. Refit the battery and power up. Password should be removed.
Apr 12, 2013 | Dell Latitude D800 Notebook
Hi my Latitutude D800 has a Pentium M 1.7 GHz processor but it slows down and runs at 600 MHz. Please Help PS. Am using windows 7
whenever it use on battery power it shows it minimum speed, also it will shows full speed when the processor is processing something.
May 12, 2012 | Dell Latitude D800, PP02X Series Laptop...
Have a dell latitude d800. Battery died so replaced with new one, ran fine for a few months, now it won't run from battery. Battery shows full charge from itself and from bios, so it is charging and the...
update bios-if same issue occurs-check for another known good battery (maybe a friend may have one) try this battery and if same issue is occuring then its your motherboard....now if a kown good battery is fine on the system or one is not available then we have to beleive there is a issue with the battery...alot of dell system's in which the battery gets replaced whith in the first year..chances are you will always have this issue with the system....the board is running at a high speed which is eventually killing the battery
May 08, 2010 | Dell Latitude D800 Notebook
My Dell Latitude will not turn on. When I press the power button it will come on for 5 seconds then go off. Can anyone help ?
Plug in the AC power cord, remove the battery, and try powering up. Anything? Any lights?
Remove power cord, hold in the power button for 30 seconds, then try plugging it in again and powering up without the battery. Any change?
Mar 13, 2010 | Dell Latitude D800 Notebook
Dell Latitude D800 Wont Power Up
Check the status of the battery directly from the battery. Turn the laptop over and on the batter is an battery indicator button and lights to tell you if it's charged. If it is charged then you have an problem internally. Wiggle the tip of the power cord at the laptop connection to see if it is loose, if it is then you have an loose connection on the motherboard which can be fixed by an experienced tech that can solder or the motherboard will need to be replaced.
IF THIS HELPS PLEASE VOTE.....GOOD LUCK AND THANKS..
Nov 12, 2009 | Dell Latitude D800 Notebook
NO POWER!!!HELP
Is the voltage meter directly on the Battery?? What model Dell is it?? I have found that on the D800 models for some reason the connection from the power button to the Motherboard comes loose. You need to remove the Keyboard cover to check this.
Jun 06, 2008 | Compaq Evo N610C Notebook
Latitude D800 wont boot
ok now it sounds to me the power pack on the back has shat its self so ufourtanetly u need a new one if u still have a valid warrenty ring dell or go to their web site at www.dell.com and they will happiley help u there number is also their but if u dont have warrenty go to their website and see how much it costs for a new battery but see a friend who has a dell laptop and plug in the power cord it might be your power cord not your com or battery so give it a wirl and if u have any problems email me at mid.nightclub@hotmail.com
Dec 31, 2007 | Dell Latitude D800 Notebook
Dell Latitude D800
This may be SpeedStep slowing the processor to save battery life. It speeds up when it is needed.
Dec 13, 2007 | Dell Latitude D800 Notebook
Dell Latitude D800 Notebook Logo
140 people viewed this question
Alun Cox
