Question about Mag Innovision LT776s 17" LCD Monitor
Mag Innovision LT776s 17 in. Flat Panel LCD
Sympton: When I boot up my computer, the power light on my LCD comes on and flashes for a few minutes or more before the LCD comes on. Possible problem identification: In the upper lefthand corner of my screen there is a blue rectangle that reads: Top Left to Right: SH770 P001 Bottom Left to Right: AU M170EN05
  • 2 more comments
  • HT01 Jan 03, 2008
    I also have the same problem. I am wondering if it has to do with the Vista version of Windows. Is everyone having this problem running Vista?
  • Anonymous Feb 23, 2008
  • miksmom Mar 09, 2008
    I have a Mag In**vision LT717s purchase less than 12 months ago. Now when I turn on the desktop Windows XP tries to run and the monitor suddenly blacks out and a blue box appears that says "mode **t supported" I can hear the computer but can ** longer see anything.
    I hooked up a**ther monitor and everything is fine. Any suggestions on if the LT717s is salvagable?
  • Anonymous Oct 31, 2008
    My MAG LT776S did the same thing. blinking a while before the screen came on. I don't know for sure how I fixed it but I opened my computer blew out all of the dust. re hooked all of the connections then unplugged the power cord from the base of the monitor and plugged it back in. It started working properly after that.
Where can I download the monitor driver for Mag Product # LT776, Model # 780. Thanks a lot.
Posted on Aug 16, 2008
Reading these forums. I pressed auto and power at the same time (or was it auto, power and menu?), anyhow, the monitor turned off. then I turned it back on and the "menu" was in the center and then gone.
Also having the screen-going-black, taking a few minutes to turn on. Will see if that fixed it
Posted on Jul 23, 2008
I have the same problem except it usually happens after Ive left my computer idle for a while... i.e . Overnight, I usually turn off the monitor and I hit the button after I come back to turn it on. I get the same flashing light for several minutes. This has been a problem for several months, but only recenly have i gotten the same error message you mentioned. Each time ive booted the computer up cold or restarted it has worked fine but this time it took longer along with displaying the message: Top Left to Right: SH770 P001 Bottom Left to Right: AU M170EN05 Anyone else who can clear this up?
Posted on Apr 12, 2007
  • Steve Holmstadt Apr 12, 2007
    Just a follow up- from reading some similar entries pertaining to the green blinking light, it seems that there may be something may be wrong with the LCD monitor power supply... beyond that I cant be sure or make any good guess, because it seems with the blue message hanging out in the top left of the monitor, that we are unique or at least I havent found anything very pertainent on the internet when doing a search... Has anything else changed since you started seeing that message? Has the message gone away or remained in the monitor every time you've rebooted? Just trying to see what I'm in for.
    For what its worth... I've also had a minor, seemingly unrelated problem with a few pixels being out of place and flickering in the bottom right corner of the screen. This hasnt hindered use of my computer as its hardly noticable, but its been around since not long after I bought it in around 2004-05.
    more reasearch - AU is an electronics corporation which appears to manufacture the lcd display component of the monitor with the model # M170EN05
    I cant make anything out of the top numbers except the possiblity that they may describe electronic components.
I Can't locate power recepticle
It's on the back facing downwards.
Jan 27, 2008 | Mag Innovision LT776s 17" LCD Monitor
I have a 17 inch mag moniter and when i turn it on the green light comes on and blinks but is really hard to get the screen to turn on. usually have to click the mouse all over the screen until it his...
Sounds like an Inverter problem. I hacked mine into the case after this happened. Running it off of the Power supply now that I figured out the pin outs for the video power.
Jan 21, 2010 | Mag Innovision LT776s 17" LCD Monitor
I have a MAG INNOVISION LT765s LCD monitor. When the computer boots up, the power button on the monitor won't stay on so the display won't come on. It sometimes takes an hour of fooling around with the...
I have had similar problems with my Mag LCD monitor. I recently dicovered that the problem was with the adapter and not the monitor. Try replacing the power adapter.
Sep 21, 2009 | Mag Innovision InnoVision LT765 17" Flat...
MAG LT776s Monitor power cord
Your description is the external power supply/adapter for a Mag Innovision LT776s 17 in. Flat Panel LCD Monitor. One may be purchased here. Aftermarket/replacements may be found here, here or here. Pls verify that the plug matches the jack and the polarity is correct. Additionally, if it would be a replacement, pls check the voltage and current rating.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 10, 2008 | Mag Innovision LT776s 17" LCD Monitor
Factory mode on Mag Innovision LT776s 17 in
Sounds like one of 2 things.
  1. The internal bios of the monitor has failed and the monitor is pretty much wanting to know what to do. It is of course waiting to be programmed as it would have in the factory.
  2. Someone has knocked the front panel accidently pressing a combination of buttons to put it into factory mode. This is normally POWER + MENU held together when switching on. The only problem with this theory is after a power down, it should reset to nomal mode. It can be a different combination of buttons also, like AUTO and POWER or even all three together.
Apr 15, 2008 | Mag Innovision LT776s 17" LCD Monitor
Mag Monitor LT776s 17 flat
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Mag Innovision product # LT765s model #780
monitor is looking for the video signals--move mouse and try power on
Jan 07, 2008 | Mag Innovision LT776s 17" LCD Monitor
Mag Innovision LT776s Model 780
Good Luck!
Nov 23, 2007 | Mag Innovision LT776s 17" LCD Monitor
I need this information please
Try this site. I suspect however spares are not available. http://www.fixya.com/support/mag_innovision
Jun 02, 2007 | Mag Innovision LT776s 17" LCD Monitor
Mag Innovision LT776s 17" LCD Monitor Logo
760 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Steve Allison
Steve Allison
Damen Wong
Damen Wong
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
