Question about GE Profile Spectra JGBP90 Gas Kitchen Range
None of my igniters on my gas ge stove no clicking no lighting
    Habit-Forming:
  • 171 Answers
The spark ignition module, needs replacing, it's call a spark module,many times is behind the stove.
Posted on Dec 11, 2008
Burners won't light
That clicking is the igniter trying to spark. Turn on the burner and attempt to light it with a match. If you know gas is comming out, you will most likely have to replace igniter.
Sep 26, 2012 | GE WB13T10045 Gas RanOven Igniter Glowbar...
Clicking sound from GE gas stove igniters
u most likely have a gas supply valve problem, the clicking will continue until that is fixed.
Jul 22, 2009 | GE Profile JGP636 Gas Cooktop
I need to ge my stove lit
Does it have electronic ignition (clicking sound when starting) if it doesnt and you have an older model you may need to re light the pilot? Also make sure your getting gas to the unit (you will hear a hissing sound when the burners are turned on) try using a match to light the burner
Jun 25, 2009 | GE Profile Spectra JGBP79 Gas Kitchen...
GE Monogram ZGU48N6D- None of the Ignitors "click"
We just had that problem - the igniter is electric - if none of the burners are "clicking" it could be a power problem. unplug the stove and check whether the outlet is working. In our case, the outlet the stove is plugged into has a "GFI outlet with a reset button. So we reset the outlet and that fixed the problem.
Apr 08, 2009 | GE Monogram ZGU48N4GHSS / ZGU48L4GHSS...
GE gas stove switch igniting though stove is off!
You have a bad ignitor switch. One or more of them (4) is stuck.
You need a volt/ohn meter to check the switches, one attached to each surface burner to find out which is bad.
Feb 19, 2009 | GE Profile Spectra JGBP79 Gas Kitchen...
GE profile gas stove igniter don't stop igniting
take a look at the igniter located in the center of two burners. clean the gap with a stiff brush between the eletrode and the upper plate. the distance is preset at the factory. you may have enough buildup to close the gap enough to trigger the igniter.
Oct 23, 2008 | GE Profile Spectra JGBP79 Gas Kitchen...
Stove top pilot light
I have a GE Gas Stove XL44 the stove top buners don't light by themselves without manual lighting. When I turn on the buner knob the buner doesn't click. Also I used my self- cleaning oven for the first time and stopped it before the time was up after that is when the stove top buners wouldn't light by theirselves.
Jan 20, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge spectra gas stove top not lighting
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
Nov 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile JGB916
LP or natural? Are the valves set correctly for such and the regulator value changed if a different gas is used than what the manufacturer set the stove up as?
Good Luck...
Sep 12, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
229 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
