Question about Refrigerators
My fridge quit cooling...lights are still on but no cooling action. was making a bad grinding noise that I thought was happening when it was making ice but now I'm not so sure. It's only one year old...HELP! Temp in freezer right now is 61 deg. F Temp in fridge right now is 66 deg. F
  • 3 Answers
May be your unit is not defrosting and the grinding noise could have been the fan tuching on the build up of frost, you need to check your timer or defrost thermostat
Posted on Dec 11, 2008
Fridge light doesn't work/makes ticking noise
Let the refrigerator cool for awhile without opening the door. 39 minutes should do. Then check to see if the bulb is warm or hot. If it is the door switch is bad and the light is staying on which will make the plastic expand and cracklel or tick. Hope this helps.
Apr 11, 2014 | Magic Chef Refrigerators
Lg Icebeam Door Cooling fridge/freezer top of freezer not freezing
is the fan not working in it..may be jammed up..we had an old unit that did this all the time.. the door seal was bad allowing house humidity inside and it wpuld frost up so bad the fan got stuck..we eventually bought another used unit..
Jan 20, 2014 | LG Refrigerators
Dryer makes horrible noise when while running, and "cooling" light is always on now,
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
djk
Sep 23, 2010 | LG DLE3777 Electric Dryer
Cherokee intermitant grinding noise in neutral
Is it when the engine first starts? It sounds like to me that the starter is getting stuck in the fly wheel. what happens is when you go to start it, the solenoid push's the gear out and spins the gear almost one full action, the grinding noise could be the starter staying engaged after the motor has starter but quickly comes out of it after driving out of it. just a thought.
Feb 11, 2010 | 2000 Jeep Cherokee
I bought the fridge in 2006. In 2008 it began making a loud vibrating noise. Repairman replaced the fan motor blade.Took 30 days to get part! It was never quite right after that. Had problems with defrost...
Could all be in the fan motor. If it's bad again, I would change the motor and blade. Then fire it back up and test for correct cycling.
That may take a week of running until you get a true picture of whats happening, but they do have a lot of trouble with the motherboard./
Jan 17, 2010 | GE Refrigerators
"water filling" noise coming
It maybe liquid nitrogen settling down after a round cooling the fridge. The nitrogen has to circulate and become gaseous while cooling. Then it has to settle down once the compressor stops pushing it. That is why the fridges and ACs are supposed to use stablizers with delay of two minutes at the least.
Dec 04, 2009 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
Fridge & Freezer not cooling
i think you have a bad compressor pull it out and take off the back panel and feel the compressor if it is hot and making a bad sound it might be an over load relay
Dec 11, 2008 | Frigidaire PHS67EHS Side by Side...
Servis frost free fridge freezer makin crackin noise afew tyms a day
this is not unusual on any make. the cracking noise is the cabinet creaking with change in temperatue. don't worry about it
Oct 18, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Noise in upper right (roof) of Frige
Replace the Maytag 61005988 Adaptive Defrost Timer Assembly. It controls the defrosting od the coils. See below what happens when it goes out.
Mar 14, 2007 | Maytag MZD2766GES Side by Side...
Refrigerators Logo
104 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
