Question about Hobart D300 Stand Mixer
Problem with Hobart D300 Mixer - Hobart D300 Stand Mixer
  • 2 more comments
  • Anonymous Dec 11, 2008
    My Hobart D300 would not engage in the 3rd gear anymore, I cannot turn the lever to that position.
    Would you be willing to give me some info or a service manual. I am mechanically inclined so I could fix it if I now what to look for.
    rtino80501@yahoo.com
  • rtino80501 Dec 14, 2008
    Thank you for reply.
    No there is no noise. The mixer works great in 1st and 2nd gear. But cannot turn the lever into the 3rd gear. The speed(gears) have been changed on the fly, without turning off the mixer. Could this have done it?
  • rtino80501 Dec 15, 2008
    So is that why I cannot engage in the 3rd gear? Any info out there on how to take it apart and repair it? Also what kind of grease do I need to buy to lube it back after repair.
    thanks.
  • fsstates Jan 17, 2009
    Oil seal leaking at motor worm gear also at seal in front where meat grinder is attached. I would like to replace all seals while I have everything apart. need to know what kind of lubrucation to use & seal numbers or sizes
    Problem Solver:
  • 6 Answers
If you shift these Hobart mixers on the fly, you will sheer a tooth or two or three, and it is done for. You will need to replace the gear with the missing teeth, which can be an expensive part. NEVER SHIFT ON THE FLY! The only mixer you can on the fly is a belt driven one, as they have internal clutch sheves. The N-50,10,12,20, 30 qt. mixers use gear grease, not 90/120w oil as I've seen in some mixers I have repaired.
Posted on Aug 06, 2009
  • 640 Answers
Sounds to me like the shifting yokes are locked up,or a broken shaft.Is there any noise?
Posted on Dec 13, 2008
  • anthony james
    anthony james Dec 14, 2008
    No doubt about it,changing gears without turning the mixer off will tear the teeth off the gear eventually.If you need help breaking down the mixer let me know.
3 Suggested Answers
SOURCE: d300 hobart mixer
i have a spare unit for dsale 1500.00 cdn
Posted on Oct 23, 2008
bigg t
  • 640 Answers
SOURCE: I HAVE A HOBART MIXER D300 ML#11627 I NEED TO
Goto hobartcorp.com,create a username and then you will be able to find out what your looking for.I know that these mixers used oil when they where new but now changed to grease.Any ? let me know as im a hobart tech a repair these often.
Posted on Nov 22, 2009
I need to buy a motor for my Hobert D300 Mixer where might i be able to get one
Your local Hobart office.
www.hobartservice.com Click on "Locate an Office" and enter your zip.
Jan 14, 2011 | Hobart D300 Stand Mixer
My d300 hobart mixer is dripping oil when I am using it. How can I stop the oil from dripping out
It uses grease which breaks down over time. The transmission has to opened up and all of the old lube removed and replaced with fresh lube and the bottom seal replaced. Contact your local Hobart office. www.hobartservice.com to locate your local office.
Nov 04, 2010 | Hobart D300-6036 Mixer
How do i put back togeather Hobart 300-d mixer
http://www.hobartservice.com/Parts/
Go to this page and click on Hobart Smartparts System. Select Food Machines, Floor Mixers, D300 and you will eventually find parts breakdowns.
Feb 25, 2010 | Hobart D300 Stand Mixer
How to remove bearings from a Hobart D300T
I have a D300 mixer and the 2nd gear kind of misses or just vibrates a little what is this?
Jan 01, 2010 | Hobart D300 Stand Mixer
Oil leaking from hobart d300 mixer
DEFINITELY contact the manufacturer (Hobart) on that one. Sounds like you're having some sort of an internal problem with it (something might be cracked), and in this situation, the best way to go is to contact the manufacturer rather than try to repair it yourself. If you're still under warranty, and you try to open the machine up to fix it yourself, you could wind up VOIDING the warranty, and if you're out of warranty, most repair places won't touch a machine that you've messed with already--too much of a liability.
Just give Hobart a call, and they should be able to help you (if you're in warranty, sometimes even for free!). Their phone number (according to their website, www.hobartcorp.com ) is 1-888-4HOBART (1-888-446-2278)
Good luck! :)
Aug 27, 2009 | Hobart D300 Stand Mixer
How to remove key from D300 Mixer to replace stripped gear
Keys are removed using a small punch and a hammer. The punch of choice is called a ***** punch
Jul 10, 2009 | Hobart D300 Stand Mixer
New bowl & hook hobart d300
There is a website called onesharpstore.com, It carries parts for the hobart 30 quart mixer. I specifically saw the bowl and hook attachments as well as others like beaters and a cheese and vegetable grater. Hope this helps. And if you sign up I think you can even request a full catalog for your machine.
Feb 25, 2009 | Hobart D300 Stand Mixer
D 300 hobart mixer
All that I could find for you is the manual
seems their website is not up and running at the momment sorry I Could be of any more assitance to you nice mixer by the way.
Aug 02, 2008 | Hobart D300 Stand Mixer
Hobart D300 Stand Mixer Logo
499 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
