-   hi my indesit dishwasher has started to trip the electric this morning when door is closed. any ideas?
-   freelady
Aug 07, 2008
-   My indesit dishwasher is tripping the electrics out when turned on. Can anyone help??-   Guest
May 04, 2008
-   DW keeps tripping the house electrics, have tried another socket, and yes does the same, have taken the unit out and the back outer black coating has melted and you can see the indentation of the ribbed waste pipe, any ideas??????
Usually time to replace the heating element. The element is sealed inside a metal tube packed with a dry powder to insulate it. If the outer tube leaks (and it only takes a pinhole), the powder gets wet and stops insulating. It only takes a tiny earth leak to take modern trips out.
If your dishwasher is one of those where the element is visible in the bottom of the compartment you load the dishes into, replacing it yourself ought to be straightforward. If it's buried in the works, whether you want to tackle it yourself or pay someone else to do it depends on how confident you are.
Either way, it shouldn't be catastrophically expensive.
A.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Sep 29, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Check the whole drain tray hasn't come away from the base - like mine has. Buy a Bosch - Indesit are a peice of shite.
number light flashing and wont reset to wash again, usually you press P and it moves onto new...
(More)
number light flashing and wont reset to wash again, usually you press P and it moves onto new setting, but that is not ahppening its an indecit DI 620
ola muito boa tarde sera que poderiam me azudar. por a caso nao me pueden forneser o esquema do...
(More)
ola muito boa tarde sera que poderiam me azudar. por a caso nao me pueden forneser o esquema do programadar como se liga? e uma indesit dv CE 61 4668 o meu indereço é pedrosilva6318@hotmail.com
