Question about Optoma EP716 Multimedia Projector
EP716 Optoma Projector Fuse
Hello Sir.... I am having trouble were the fuse is inside my EP716 Optoma Projector or what it looks like... If you could help me that would be great... thank you very much...
There is no fuse. I took my EP 716 apart to find out why it died. I found a resistor had blown on the power board made by the Tiwan co. Quazarpower.
Posted on Jan 03, 2009
Optoma h79 wont power up is there a fuse to replace if so where is it thanks
hi,
All electronic equipments have fuse in the power supply section.
In your projector it is inside the unit. The fuse of projectors will blows only if there is any trouble in the power supply. Just try to replace the fuse in the power supply board. It will be near the input connector. If the fuse again blews then you have to replace the power supply board. Because the components in a projector power supply is rearly available. You will not be able to access the fuse with out oppening the projector.
OK
Oct 08, 2011 | Optoma H79 Multimedia Projector
Just purchased a refurbished optima ep716 projector won't synch-keeps rolling through search mode - I have it connected using the SCART setting.
Reduce the screen resolution of your computer monitor to 800 x 600 and check. Let us know the result.
Optoma is a SVGA projector. i.e. the maximum resolution supported by your projector is 800 x 600.
Sep 26, 2011 | Optoma EP716 Multimedia Projector
I have an Optoma EP716 projector. It has run for
either the lamp has/is going to expire, or the ballast is bad. if the lamp has bulges or black spots on the inside, replace the lamp and clean out your projector with canned air. too much dust keeps in the heat and makes a 2000 hour lamp go in 1100 hours.
Oct 22, 2009 | Optoma EP716 Multimedia Projector
Optoma ep716
Go to the onscreen menu and check lamp settings. Disable auto shut-off.
Nov 09, 2008 | Optoma EP716 Multimedia Projector
Power problems
Hi John
That's the one ! The two ends of the fuse will sit in a "lifted bracket" touching only the two ends.
May 26, 2008 | Optoma EP716 Multimedia Projector
Optoma Power Problem
Hi Jjonesiii
The fuse will be on the Powersupply Board ( the one with the AC socket in it )
I bought the fuse from our local harware shop.
May 23, 2008 | Optoma EP716 Multimedia Projector
Power problem
Hello BobSmalley,
From your post, I gather that you know your way around electronics. So, why don't you use a VOM (Volt Ohm Meter) to trace power starting at the PS and see where you lose it. You may find a blown fuse along the way as you didn't mention fuse status (and that projector surely has one). If you do have access to a meter you could also check the ballast to see if it's putting out enough voltage for the lamp. But since you stat that it doesn't power up at all, I would lean towards the Power Supply (PS) and locating the fuse (could be an AGC, etc... or a printed circuit fuse soldered in circuit right on the component side of the board near the edge where power comes in).
Keep us posted, and Good Luck.
Mar 10, 2008 | Optoma EP716 Multimedia Projector
Optoma EP 738
You can test the power source if you are getting any power input from the power cord itself. Plug in your power cord and use an eletronic meter on the other end to see if you are getting the proper voltage (110/120) reading. If not, then the power cable is bad in itself. IF you are getting power from your cord, it could also be a fuse inside the Optoma and/or where the power plug on the Optoma meets the actual power source is out of alignment or may also be not making the proper contact to the main circuit board on the Optoma. Hope it helps....JGUAM
Jan 28, 2008 | Optoma EP716 Multimedia Projector
Optoma EP716 Multimedia Projector Logo
703 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
