Question about Philips 37PF7320A 37 in. HD-Ready LCD Television
37 inch lcd hd tv will not power on
Around 3 monts ego when the tv was cold it was taken longer and longer time to power on.the green light willbe on for a minute and then off after a few tries it wii power on,when it was hot it will power on right away. today it is dead.
  • lukecrowley Dec 19, 2008
    I have a similar problem with my HD FlatTV. When switching it on form cold, the sound and the green light come on but the screen stays dark. Switching it off and removing the power cord for about a minute usually brings it back to life. The problem is very intermittent though, sometimes it will switch on first time with no problem, and sometimes it takes several tries before the picture comes on. Could it just be a bad capacitor somewhere, or is it something more serious?
  • 90 Answers
Power board is going bad
Posted on Feb 24, 2009
Toshiba regaza 37rv635db wont turn on
seems like capacitor problem, chack them and if thay have exploded replace them.
Aug 25, 2013 | Toshiba 37RV635DB Regza 37-inch Widescreen...
My 37 inch Olevia that is 3 or 4 years old is stuck on a very loud, so loud I have to turn it off, but I can't access the volume on the remote or on the TV, it is so weird! The remote does work to turn...
When you have strange problem like this, power supply module will be the first thing to check for steady DC. Since this company is no longer around and parts are getting hard to come by, the repair shop will not even try to do component level repair on it due to time consuming process and no schmatic available.
There may be not much you can do.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Olevia+LT37HV+
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 14, 2010 | Olevia LT37HV 37 in. HD-Ready LCD...
I have a 37" Philips (37PF9431D/37) flat panel tv. It won't power on. When you plug it in you can hear a click the green light stays on for a few seconds then goes out. I've checked the power board for bad...
i am having the same problem. My Phillips 37" 37PF9431D/37I LCD High Definition TV won;t turn on. When I press the power button i hear a click and the green light comes on for a couple of seconds and then the red light appears. I can;t figure it out. Did you find a solution?
May 20, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
LG HD 37 INCH TV GREEN LINE APPEARING ALONG THE BOTTOM
On a LX2R to remove the green bar at the bottom or the blue bars on ths side using the sky HD box go to menu and the pip menu at the bottom of the list, access input and make sure the HDMI input is on DTV and NOT PC.
Feb 19, 2010 | LG 32LG30 32 in. LCD HDTV
37 INCH LCD HD NO PICTURE GREEN LIGHT ON, BUT NO SOUND
CHECK THE FUSE ON THE INVERTER BOARD, IFHIS DOESNT IT SOLVE IT REPLACED THE CAPACITORS, IF STILL SAME PROBLEM, THEN YOUR BACKLIGHTS ARE SHOT, HAVE THEM REPLACED
May 29, 2009 | SNK Magnavox 32MD357B_37 32 in. LCD...
Have a Magnavox 37 inch lcd hd tv When I turn the power on the green light flashes for about 10 minutes or so then goes solid. Once it is solid it turns off Turn it back on its solid again then off it goes...
sounds like the audio / digital board is going bad ---- they are about 130 refurbished and 300 new ----- look for one online before you pay an overpriced service tech who really doesnt know how to fix these tv's ----
I called the service support and they gave me three companies in Nevada --- each one of them had no idea what the codes meant, but would look at the TV for 225.00 - sounds like they need new companies to do their repairs on warranty
Feb 19, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Blinking red lights
If your TV is less then a year old, i would suggest to call the vendor or manufacturer to have the LCD repair under warranty. Most electronics devices carry one year warranty.
The failure of your LCD is not related to any fuse since you're still getting some lights from it.
Good Luck.
Jul 09, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Magnavox 37" LCD HD TV 3 years old
You may need to replace the Small Signal Board of your tv.
Nov 25, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
SANYO 37 INCH TV
Check for cold or crystalized solder joints on the board that is connected to the CRT.
I would also check the solder joints around the high power resistors near or around the horizontal section.
Good Luck.
Oct 13, 2007 | Sanyo AVM-3659S 36" TV
Philips 37PF7320A 37 in. HD-Ready LCD Television Logo
116 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
