Question about Bernina Bernette 75
My bobbin thread is making big loops
It had been working fine and then it just started looping on the underneath side.  I am using some heavier fabric.  I can't find my manual to troubleshoot.
  • scangel86 Feb 07, 2009
    My machine is doing the same thing. I have adjusted the top tension all the way up and it doesn't help.
  • ssquared46 Apr 15, 2009
    This is so frustrating. I took your advicie and got a little improvement, but the loops persist. What I'm trying to determine is whether or not the Bernette is a fundamentally reliable machine. I was drawn to its comparative simplicity, thinking that fewer amenities might mean fewer problems and complications.
    When the loops cropped up today, I had been sewing for about an hour without incident. Nothing had been changed: not the threading, nor the adjustments to the tension controls, nor the fabric, and on. Then these big ol' loops, seemingly out of nowhere.
    So frustrating. I fiddled with everything for about an hour and a half to no avail.
    Dang.
  • 202 Answers
Bottom looping says upper tension problems (too loose). Rethread it making sure the presser foot is up so the thread is inbetween the tension discs.
Posted on Dec 12, 2008
Change your needle. If you're using heavier fabric, use a denim needle.
Posted on Apr 15, 2009
  • ssquared46 Apr 17, 2009
    Actually, that was a temporary solution. Still not reliable. Talked to a shop today and learned that there could be a timing problem that needs adjusting. When a new machine comes out of the box, a reputable dealer will service it. Unfortunately, I bought it on eBay, so no adjustment. I've been flying blind.
My Bernina Artista 185 has been looping the top thread on the underneath side. Is this a tension problem? No amount of adjustment seems to correct it. What can I do to correct the looping problem?
It is a tension problem. My advice is always to double check in the manual that you are threading correctly. With loops underneath, your tension is too loose, or the bobbin is not seated properly.
Nov 18, 2015 | Bernina Sewing Machines
I have the Husqvarna Viking designer ruby. It is making huge loops on the underneath side of the fabric. This is during straight stitch on cotton and then on duck cloth. I have cleaned underneath t
Typically, when there are loops on the bottom of the fabric, there is something missed in the upper threading. Make sure when threading:
- the presser foot is in the up position to open the tension disks
- make sure the thread is well "seated" in the tension disks before continuing to the take up bar.
- using the manual follow the thread path carefully
- check to make sure the thread flows smoothly from the spool
- use the correct size spool caps to help the thread flow easily
Dec 30, 2014 | Husqvarna Sewing Machines
Upper thread looping around bobbin
make sure your needle is positioned correctly? not too high and not too low.
Jan 10, 2014 | Brother Sewing Machines
Bottom thread from theh bobbin is in big loops.
Problem with Brother CS-8150 Computerized Sewing Machine
bottom thread from theh bobbin is in big loops.
I have a CS-8150 as well -it was fine until I decided to clean the shuttlecock and I thought I had put it back correctly. However, it was after replacing the shuttlecock in place that my bobbin thread was making big loops and no matter what tension it kept doing it. So I removed everything out of the bobbin area. Cleaned and made sure that the shuttlecock was exactly in place as per the manual. Guess what it does not make big loops any more.
Just a suggestion.
Sep 09, 2011 | Brother CS-8150 Computerized Sewing...
Looping thread bottom side of fabric
That means you have not routed the bobbin thread properly, or bobbin has not been filled properly. Could also mean your tension is incorrect.
Feb 14, 2010 | Brother Sewing Machines
My Pfaff sewing machine has started to loop the top thread underneath. Tried fixing the tension on the bobbin thread as they state in the manual, but the problem still persists. Any suggestions?
If the thread is looping underneath, you're top tension may be too loose or the thread may not be in the take-up lever. If it's looping on top, double check that the thread is in the bobbin tension or that the bobbin tension isn't too loose.
Oct 02, 2009 | PfaFF Creative 7570
BOBBIN TREAD LOOPING UNDERNEATH
looping thread on the bobbin side means that the upper tension is too loose... make sure it's threaded correctly.
Jun 14, 2009 | Feiyue FS288
Thread getting caught in machine underneath
Try rethreading the top of the machine making sure you get it thru the tension wheel correctly.. General rule of thumb.
If it loops on the bottom, the problem in on the top.. Loops on the top, problem is with the bobbin.
Apr 14, 2009 | Sewing Machines
I have the Brother ls2125i and LOVE the machine...in the middle of sewing, it started making very big loops on the bottom stitch and they do not catch the thread from the needle. Is it the tension?...
Here are some things to try:
Big loops are actually easier to solve usually. 1st know this: Loops on bottom means the top is too loose or the bottom is too tight. With loops that big its probably the top is too loose. 1st look in tension disks, there is likely a chunk of thread in there. A toothpick is handy to dig it out (the flat kind) 2nd make sure that the thread is getting between the disks when threaded. 3rd Make sure the thread is in the take up lever (the thing that moves up and down in front and not the needle bar or any part of the needle bar.) If neither, then the bobbin case could have a burr on it and the thread is hanging on that burr. Also the bobbin case may be in wrong. I hope this helps
Tension:
If the thread is loose on the bottom of the fabric, it's actually the top thread is too loose. Think of 2 little elves playing tug of war in your machine, one on top and one underneath. If you have loops on bottom, the top needs to pull harder (tighten top tension
Thread test
Test your thread quality to start, thread your machine and LIFT the presser foot (this opens the tension disks). Pull your top thread straight back. If you feel no tension no matter how much thread you pull, your thread is good. If that your machine passes that test, we can go to step 2. If not, try different spool of thread, do the same test until you get a smooth pull (tip: always check your thread this way when you thread your machine)
Step 2:
Pull on your threaded bobbin thread while it’s in the machine. Does it pull smooth and even? If so, go to step 3. If not, try a new bobbin (bobbins get bent or distorted if wound too tight).
Clean thoroughly in the hook and bobbin case area and oil 1-2 drop is all.
Kent
Mar 22, 2009 | Brother LS-2125 Mechanical Sewing Machine
Looped bottom thread
Sorry I missed your problem, I have just signed up on here to help with problems like yours.
Thread looping underneath the cloth is a bobbin tension problem.
Folks in general are not aware that in addition to the top tension being set correctly so must the bobbin tension.
It is impossible to explain how to do this you need to be shown. However it should be explained how to do it in your manual.
Jan 29, 2008 | Janome Mini Compact
Sewing Machines Logo
909 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
