Question about Microsoft Windows Vista Ultimate Edition
Component'comdlg32.ocx'or one of its dependencies not correctly r
Sir when i try 2 open a instaled program in os win xp the above msg will appears so plz give a suggesion
    Scholar:
  • 135 Answers
Here is the fix :
http://windowsxp.mvps.org/comdlg32.htm
Posted on Dec 12, 2008
Comdlg32.ocx
You didn't provide a question, but I can offer this:
Re-Register the file:
You can Re-register this file it by typing "regsvr32 comctl32.ocx" from the command line in the system32 directory.
Perform the following steps to make the changes:
1. Click Start
2. In the Search bar type CMD
3. In the programs pane right click on cmd and "run as an Administrator"
4. Put in your credentials for UAC prompt
5. In the command prompt type in "regsvr32 comctl32.ocx" then press ENTER
Oct 22, 2013 | Burton Tsang Key Presser
Even though it says i have installed the moultrie plot stalker software, i am gettting this error message when i click to open - component comdlg32.ocx or one of itsb dependencies is not correctly...
Had the same problem. Right click the icon for plot stalker. Click on properties, which is at the bottom of the list that pops up. A window will then pop up with six tabs at the top. Click on compatibility. Down towards the bottom of the window click on the checkbox that says " Run this Program as an Administrator." Problem Solved!
Sep 20, 2011 | Moultrie Cameras
After downloading the software for the Puppy Grows and Knows your Name by Fisher Price is says "Library not Registered" I have no clue what to do now. Any suggestions?
Install it in compatibility mode, Win XP Service pack 2 with administrator turned on (Right Click, Properties. Click on "Compatibilty" tab. Select Run this program in copatibility mode for: WINXP SP2. Under Priviledge level, select "Run this program as administrator). Then after it installs, do the exact same thing for the shortcut.
Sep 14, 2010 | Fisher Price Puppy Grows & Knows Your Name
I downloaded this software yesterday but it didn't run on my PC. when i installed, this message appeared on the screen & stop the process of installation. " Error 1904. Module...
Well I would remove all software to that hardware being the TV card. Reboot the pc see if the error regenerates. If not then I would reload the newest version off the manufactures site. As well I would go into the msconfig and tell it not to run on bootup.
Aug 13, 2010 | Computers & Internet
I was trying to install a program for my college
Your program did not install properly. Based on the error message "Resize32.ocx" or something it needs to run did not install properly. Uninstall through control panel-add/remove programs and reinstall.
Jan 14, 2010 | Sony VAIO PCG-K33 Notebook
Software not instaling correctly
I am having the same problem I've look everywhere can't find anything.
please if you found the solution let us know.
thanks
Apr 10, 2009 | Coby CX-R190 Digital Voice Recorder
How to register ocx on vista
[Solution # 1]
Drag and drop it onto regsvr32.exe in Windows\system32 folder. Make a shortcut for regsvr32.exe in the same folder the OCX is in and drag and drop it that way
[Solution # 2] Just run cmd.exe as administrator and try again. This is the key.
Here, step by step:
1. find the folder of cmd: it is usually on C:\windows\system32\cmd.exe
2. Do right click over cmd.exe and click on "run as Administrator"
3. now just use regsvr32.exe as you used to do!
For example, to register most Blackd Proxy ocxs, you might need to type this in "Administrator" cmd:
regsvr32.exe c:\windows\system32\richtx32.ocx
regsvr32.exe c:\windows\system32\comdlg32.ocx
regsvr32.exe c:\windows\system32\mswinsck.ocx
regsvr32.exe c:\windows\system32\msflxgrd.ocx
regsvr32.exe c:\windows\system32\msinet.ocx
regsvr32.exe C:\windows\system32\comctl32.ocx
A side result for Visual Basic 6.0 users: this seems to be the way to use components in Windows Vista properly. Just register the components of your proyect with "Administrator" cmd before adding them to your proyect (or before opening a proyect that already had such components)
[Solution # 3]
use this in command line
REGSVR32 /V then ur ocx or dll name
ex:
REGSVR32 /V CRPAIG32.DLL
[Solution # 4]
right-clicking the batch file and selecting
'run as administrator'.
richtx32.ocx
comdlg32.ocx
mscomctl.ocx
dxtmeta2.dll
Good luck
Mar 03, 2009 | Microsoft Windows Vista Ultimate Edition
Unable to install game
Ur config looks gorgeous and fit to run the game. Maybe its the problem of the DVD's. Check for any scratches....try the same dvd's on a friends system if possible to see if they work and tell me..............
and next time add a comment here itself....
don't keep opening new problems...
i am having trouble finding them.
Good Luck
Aug 17, 2008 | Intel Motherboard
QV ver6 (Win 95/98/NT) compatible with Vista?
If you right click on the shortcut and go to the Compatibility tab you can check the Run this program as an Administrator option. This worked for me.
Jun 23, 2008 | Parsons QuickVerse 2005 Expanded Edition...
Error with Vista
If you are using any other operating system than Vista please see this article: http://www.rebrandsoftware.com/admin/supportEdit.asp?article_id=53
This error indicates that a file is not correctly installed on your system. In some cases it may be correctly installed for all standard users but not for the "Administrator" account, and you may only see this error when selecting "Run as Administrator".
The built in Administrator account is not intended to be used as a user account. It is very secure and will not allow program components to be registered. Instead you should create an account with administrative rights, and use it instead of the built in Administrative account. This will help solve runtime error 339/429 on our software, and lots of other software that you may install in the future. If you do not want to create a standard user account (not recommended) you can follow the instructions below:
If the problem started suddenly then a reinstall may fix it. If not, follow the directions below to register each file that is producing the error. You generally will only have to repeat the instructions 3 or 4 times:
Click start
In the search box type "cmd" without the quotes
When CMD.exe appears above the search box right click it and select "Run As Administrator". This will open a command prompt with admin rights.
Repeat the following for each file that is causing this error, replacing [filename] with the actual name of the file that is causing problems:
    -Type "regsvr32 [filename] /u" without the quotes
    -You will receive a prompt saying the file has been unregistered. Click OK.
    -Type "regsvr32 [filename]" (shortcut: press your UP ARROW and delete /u)
    -You will receive a prompt saying the file has been successfully registered.
    try this
    Go to Start
    click Run
type in cmd
press enter
type in the black screen
regsvr32 MSWINSCK.OCX
Press enter
it will come back the c: prompt
then
Restart your PC
Jun 02, 2008 | Microsoft Windows Vista Ultimate Edition
Microsoft Windows Vista Ultimate Edition Logo
1,835 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
