Question about Polaroid FLM-3225 32 in. LCD Television
Setting Polaroid 32" HDTV for 1080i
I lost my manual for Polaroid 32" HDTV and don't know how to change the setting to program it to 1080i so i will be able to watch an HD picture
    Genius:
  • 1,199 Answers
You must hook up into the hdmi in on tv or use the red blue green video hook ups and it will work switch itself dont forget the red blue audio cables!
Posted on Dec 11, 2008
Panasonic hdtv 1080i picture bright
It could be your main board going bad.
Jun 01, 2013 | Televison & Video
What is the picture quality setting for a panasonic 1080i HDTV
Adjust the video output settings on the devices connected to your Panasonic HDTV. To view 1080p programming, enter into the service menu on your external device and change "Video Output" to the appropriate resolution. By default, the Panasonic TV is always displaying content in the resolution provided for it by the external device. If your cable box is set to output in "1080i," for example, your TV will display content in 1080i.
Let me know if this fixes the issue.
Regards,Suhail
May 11, 2012 | Vizio VO37LHDTV10A 37 in. LCD TV
Need to change resolution to 720 on Vega 55 LCD. Hate 1080i
U can't change any air tv programs show on over the air resolution.Resolution are set by the tv stations set their programs by airing itself like 480i,720i and 1080i.U get what u get,the only thing is the tv programs air resolution air,the tv u got can get that resolution,that it.
Jul 06, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
The tv reflects that it is showing in 480i whent he cable is at 1080i. i am using a hdmi cable, i know the tv is plug and play, but if that is not working can i manually switcht the tv to 1080.
There are several solution you can try. Go to your menu and manually set the TV to your own personal setting is the easiest step. The other is to change the source that generate the 1080 res. The HDTV is only capable of producing the signal it receives, not the other way around. If you have a reliable and true 1080 source, then your tuner is having some other issue or the HDMI port is bad. Try using the 5 component YCB plus sound to duplicate the problem. The Component port is capable of producing up to 1080i source. Let me know how this turn out.
Oct 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Tv went black but still get video game picture in ok
most of the time by selecting the customer menu and going into the input or source setting you are able to select the tuner/video settings. If you can select channel or tuner setting and you still don't get video, then it might need some tuner repair.
Jul 27, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Program the hd channels
The FLM-2601 is an 'HD Ready" TV but does not have an HDMI input or a digital tuner, it only has an analog tuner. You will need a cable box or other source to view HD. Using the component inputs (YPbPr) you can get up to 1080i.
Apr 21, 2009 | Polaroid FLM-2601 Television
Setting polaroid 32" HDTV to 1080i
Manuals for Polaroid LCD TV's are found on the Polaroid support site at http://www.polaroid.com/service/userGuides.jsp?FOLDER%3C%3Efolder_id=2534374302034967&bmUID=1229787329055&bmLocale=en_US
Dec 11, 2008 | Polaroid FLM-3225 32 in. LCD Television
Changing resolution settings
Change the resolution through your Cable / Satellite box - Go into the menu. Most of the Akai tv sets do not have an option to change the resolution.
Mar 24, 2008 | Akai PT5598HD 55" Rear Projection...
Setting ***.
You will have to change the dvd player resolution to 1080i (or change resolution for each individual disc), because:
a) there is no way to change the resolution manually on this television
b) this TV maxes at 1080i, hence negating most of the utility of using an hdmi cable (Of course, hdmi cables are much easier to hook up, less messy than component cables; so all is not lost)
Mar 19, 2008 | Philips 32PFL7332D 32 in. LCD HDTV
Polaroid FLM-3225 32 in. LCD Television Logo
106 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
