Question about SanDisk Sansa c250 (2 GB) MP3 Player (SDMX7-2048)
Whenever i am putting my mp3 player to my computer it does not show the folder (drive).but it was showing that the instrument has been installed already. what may be the solution?
  • ljstocks Dec 12, 2008
    I have the same problem...I plug my Sansa c250 player into my two home computers and it does not show in my drives. I tried it on my work computer and it appeared so it seems the player can work. I want to learn what I need to do to get it working at home.
  • luckypitabab Dec 13, 2008
    I had the same issue with my player on the computer I use at work. I thought it might be the USB port, but after trying several other USB ports (at work and home), I think my problem is the connection between my player's USB connector slot and the the USB cord. If you are old enough to remember Atari game systems, it's similar to the frequent problem between the unit and the cartridge not getting a snug connection. I think in my case it's the cable (hoping it's not the mp3 player!!). Perhaps yours was a PC USB port issue?
  • 8,596 Answers
Connect the device to the PC in MSC Mode
View/c200: Turn on then press and hold the rewind button while plugging to the PC
-Tha Mp3 Doctor
Posted on Jan 01, 2009
FOLDERS WONT SHOW UP ON PC.
It appears you have selected to play when inserted.
Go to my computer, right click your device, select open as a portable device. (so it can see the folder)
When the window on your desk opens select open folder.
It should open in this format from now on and you should be able to see the contents of your device.
However you failed to mention what operating system you are running so these instructions may not apply.
Also; You may have to pull those files/songs out of the folder and install them directly to your device (just as the new material is installed) because no auto-play can read a folder. This is probably is the best solution if you want the music to start playing when plugged in...
Oct 01, 2017 | Nextar MA833A-BL MP3 Player
I cannot find the music that i put on the v touch from the computer but my library says all songs have been added but i cannot find them on the v touch SO WHAT AM I DOING WRONG THIS IS A V-TOUCH THAT HAS...
Putting Files on Your Player
  1. Plug in your official Visual Land mp3 player to your PC with the included USB cable.
  2. Locate your player on the PC by opening 'My Computer', it should show up as an extra drive. Open the player drive.
  3. Locate the directory where the files you want on the player are located on your PC, and open that folder.
  4. Click and hold on the desired file to transfer, and then "Drag" it over to the player's external drive folder, and unclick to 'drop' the file onto the player.
  5. Your Visual Land Player may support synching with Windows Media Player, but it is not guaranteed. Your Visual Land Player however will NOT support other synching software such as iTunes, MusicMatch, or any other programs. Simply use the process above to put files on your unit.
If your Songs Not Showing in Playlist
If your songs are not showing up in the playlist after updating it, try removing any subfolders within the MUSIC folder.
The V-Touch Player uses a directory structure for initial scan of usable files. Each mode goes to an appropriate default folder for its initial scan of playable files. Video files should be placed in the “VIDEO” folder. Audio files should be placed in the “AUDIO” folder. Image files should be placed in the “IMAGE” folder. If they are not placed in the appropriate folders, you will need to search through the player's directories to find them.
Apr 13, 2010 | Visual Land V-Touch Digital Media Player
MY SYLVANIA SMPK8854B wont show up on my computer!!!
you can add files to it by going to my computer and copying and pasting the files into the mp3 player drive.it works the same way as the wmp sync.if the mp3 player doesn't show up in my computer then you got a different problem
Sep 13, 2009 | Audio Players & Recorders
When i connect my gogear philips mp3 player to pc,it deosnt show?
1. When u connect ur mp3 to pc, try option for hidden folders. Enable show hidden folder option from the Tools --> Folder option --> show hidden folders.
2.If u want to delete the only folder, then open My computer. It will show drive with ur mp3 name, format that drive
Sep 10, 2009 | Apple iPod nano
My sansa e260 shows full memory in its screen
Connect Sansa to computer
Double-click "My Computer" icon
Double-click Sansa icon (shows up as "Removable Drive" on some computers)
Select Tools --> Folder Options --> View --> check "Show Hidden Files and Folders"
Double-click Music folder
You should see your music files - you can delete at will.
Or:
To delete files from your mp3 player using Windows Media Player 10:
http://www.microsoft.com/windows/windowsmedia/knowledgecenter/mediaadvice/0085.mspx#EDF
To delete files from your mp3 player using Windows Media Player 11:
My Directions:
1. Connect your mp3 player to the computer
2. Open Windows Media Player
3. Click on the icon of your Mp3 player on the left-hand side of the Library
4. Click on the Songs, Tracks, or other Music Folder
5. Find a song or songs that you want to delete
6. Left-click the song once to highlight it
7. Press the “Delete” button on your computer’s keyboard
Mar 17, 2009 | SanDisk Sansa e260 MP3 Player
Won't show up on my computer
When you open Windows Media Player, does it show an icon of your coby mp3 player? if so, just double-click the Coby icon, and bring up the song folders that way.
Feb 17, 2008 | Coby MP-C7082 Digital Media Player
Sansae250
connect to your pc using usb connection. sansa should be recognized as storage media drive. navigate to the drive. Drag and drop files to music/video folder. Enable show hidden files and folders in your windows folder settings. Tools>Folder Options>View. Some of the folders are hidden. You can delete the preloaded music also.Some of them are in the radio folder.
ThePlague...
Feb 02, 2008 | SanDisk Sansa e250 MP3 Player
Software is deleted
my mp3 players software is deleted when i was downloading songs.now when i put the player to my computer it doesnot show the folder(drive)which previously was present.after this happended my player shows written in it disc error whenever i try to play the mp3 player.but the fm radio is working .so if you coukd assist in solving this problem
I need to know the website address for my logik mp3 player and voice recorder so i can download and reinstall its software. i can't find it
Dec 10, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
I can't delete the songs and the computer says my mp3 is "full"
You need to be in MSC mode to do deletion in My Computer; put in MSC mode in the settings menu under USB, then plug in, go to My Computer and open it as a drive, go to Music folder and delete by rightclicking on songs and choosing delete. You can also format the player by rightclicking on the drive letter of the sansa and choosing format. If you are deleting from a program like Rhapsody (ugh) or windows media player, you will get a lot of issues and not all will delete. Stick with My Computer in MSC. Also as a side note, make sure you have all file folders showing including hidden files in the tools menu in My Computer
Oct 19, 2007 | SanDisk Sansa m240 MP3 Player
Hello, having trouble with my mp3 player SanDisk c140.
Solution is pretty simple.
Go to Settings on your device -> USB -> Change it to MSC.
When you connect it to your computer on Win2000 it will show as a drive. Open the drive you should see the folders. Drag and drop your mp3's into Music* folder. Or your videos into Video folder and your Photos to Photos folder.
Aug 04, 2007 | SanDisk Sansa c140 MP3 Player
SanDisk Sansa  c250 (2 GB) MP3 Player (SDMX7-2048) Logo
22 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
