Question about RCA P61939 61" Rear Projection Television
Bad color,looks of picture etc...............
Loks like a hour glass, color is way off. PLEASE HELP!!!!!
  • 905 Answers
This is the convergence IC's that will need replacing and some resistors will also need to be tested for low values in resistance
Posted on Dec 11, 2008
Westinghouse SK26H240S - Sound works but no picture?
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 27, 2009 | Westinghouse SK-26H240S Television
Picture goes into an hour glass shape. red/orange color on one edge of the hour glass and green/blue color on the other edge.
You have a bad cap or two in the horizontal deflection [Pincushion problem] and you may have to look for a burned resistor. Use your vision to inspect burned areas on the board, this will most likely tell you where the problem may be. Area should be between the Vertical and Horizontal deflection. Look for the flyback transformer that is the board you are looking for! Hope this will you a good start. Thanks for asking!!
Oct 11, 2009 | Zenith IQB60M92W 60" Rear Projection...
Picture is curved like an hour glass
that a pincushion problem likely caused by a failed capacitor
Mar 26, 2009 | RCA Televison & Video
Nec projector vt 660
could be bad bulb is it setting in right is coler wheel freeley moving
Oct 06, 2008 | NEC VT47 Multimedia Projector
Hourglass shape picture
This is no easy fix it yourself job you need to take it to a repair shop.Ill bet you have a bad cap 16v220uf .its located on deflection board.Also these sets have poor solder connections. ThankYou for using FixYa . Have a Nice Day.
Feb 17, 2008 | RCA P52921 52" Rear Projection Television
HCN4727 hour glass picture and colors off
all of you are having the same problem with your convergence boards they need to ne replaced. about 250.00 in a shop
Oct 23, 2007 | Samsung HCN4727W 47" Rear Projection...
Shrinking picture
picture is starting to curve in from the sides like the shape of an hour glass. Is the tube shot? NO. is it something less costly? YES YOUR PROBLEM is in pincushion correction circuit.call skilled tech to fix it. it will not take much time. good luck.
Sep 22, 2007 | Televison & Video
The picture is convexed,or hour glass.
Sounds like problem in B+ voltage line to horizontal output transistor. Possible bad filter capacitor or leaky diode in power supply.
Dec 22, 2006 | RCA F32672SB 32" TV
RCA P61939 61" Rear Projection Television Logo
146 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
