Question about Polaroid FLM-3225 32 in. LCD Television
Setting polaroid 32" HDTV to 1080i
I lost my manual for my polaroid 32" HDTV and dont know how to change settings so it's on 1080i in order to watch an HD picture
  • 3 Answers
Manuals for Polaroid LCD TV's are found on the Polaroid support site at http://www.polaroid.com/service/userGuides.jsp?FOLDER%3C%3Efolder_id=2534374302034967&bmUID=1229787329055&bmLocale=en_US
Posted on Dec 20, 2008
I have a problem with using the HDMI
Please make sure that your receiver can display high definition signal, such as 720P, 1080P. As you know your HDTV is high definition source, it can only be displayed on the display machine that have ability to display high definition HDTV signal.
This will help. Thanks, please keep updated. please do rate the solution positively .thank you for using fixya
Dec 21, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
How to change a sony bravia resolution from 480i to 1080i
U can't not,only resolution can get,it the show u watching give u the resolutions.Want more HD 1080i must order a HD package from the cable,satalite or telicom companies.
Nov 05, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Tv went black but still get video game picture in ok
most of the time by selecting the customer menu and going into the input or source setting you are able to select the tuner/video settings. If you can select channel or tuner setting and you still don't get video, then it might need some tuner repair.
Jul 27, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Dont know the contrast ratio of this tv
Specifications
Panel Type: 32" Diagonal (31.5" Viewable), 16:9 Wide Screen, Color TFT Active Matrix LCD
Panel Specifications: Anti-Static and hard coated surface
Pixel/Dot Pitch: 0.507mm (H) x 0.5107mm (V)
Display Compatibility: HDTV (1080i)
Signal Compatibility: 80i (SDTV), 480P (EDTV), 720P (HDTV), 1080i (HDTV)
Response Time: 8 ms (typical)
Colors: 8 bit 16.77 Million colors
Brightness: 500 cd/m2
Contrast Ratio: 5500:1 Dynamic Contrast Ratio
Viewable Angle: 178° (horizontal and vertical)
May 23, 2009 | Vizio VW32L 32 in. LCD HDTV
Setting Polaroid 32" HDTV for 1080i
You must hook up into the hdmi in on tv or use the red blue green video hook ups and it will work switch itself dont forget the red blue audio cables!
Dec 11, 2008 | Polaroid FLM-3225 32 in. LCD Television
Changing resolution settings
Change the resolution through your Cable / Satellite box - Go into the menu. Most of the Akai tv sets do not have an option to change the resolution.
Mar 24, 2008 | Akai PT5598HD 55" Rear Projection...
Setting ***.
You will have to change the dvd player resolution to 1080i (or change resolution for each individual disc), because:
a) there is no way to change the resolution manually on this television
b) this TV maxes at 1080i, hence negating most of the utility of using an hdmi cable (Of course, hdmi cables are much easier to hook up, less messy than component cables; so all is not lost)
Mar 19, 2008 | Philips 32PFL7332D 32 in. LCD HDTV
Screen flicker when watching 1080i
Component video has a max resolution of 720p. in order to use 1080i or p you have to use hdmi or dvi connections. That is why you get the flicker.
Dec 08, 2007 | Onkyo TX-SR304 Receiver
HDTV Cable box conflict
This set does not support 480I in the DTV mode, only 480P and 1080I is supported. Try setting the analog setting in the cable box to 480p and that should take care of watching the set in DTV. Most cable boxes have a setting for format changes in the customer menu, depending on the type of box. If you are able to change the format, then the other inputs will not work since they need a 480I signal, as well as VCRs. Another setup could be to use the S-Video cable or Video input jacks to get a better picture in 480I instead of using the cable input. However, when changing from HD to Analog, you will have to change to the correct input on the set as well. Hope this helps.
Dec 24, 2006 | Samsung HCJ655W TV
Polaroid FLM-3225 32 in. LCD Television Logo
344 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
