Question about Canon PowerShot SD500 / IXUS 700 Digital Camera
Canon ixus 70 flash problem
When my flash is enabled my camera did not shoot even if it is in manual mode.. but when i deisabled my flash, it shoot.. what could be the problem in my canon ixus 70.. pls help.. thanks
silly girl
  • 513 Answers
SOURCE: Black Screen and Scroll Problem
You're either having a spreading corrosion problem from the water, or it's not all dry in there and it's spreading, and the conductivity of the water is screwing up the circuits. Open the camera as much as you're willing to risk it, and you're going to have to take a chance either way - either you take it apart, expose the boards, and every separate part with some distilled(non conductive) water (if you just dip the whole thing you'll have water caught in places) then put in an airing cupboard to dry for a week, thus taking the chance of causing more damage by not being able to reassemble it properly, or by causing more water damage, or you have another option of just opening all compartments -cards, battery - taking everything out and leaving it to dry, hoping that it will be enough. The chance you're taking here is that it's really a corrosion problem and you'll be helping it set it. If you don't like both option take it to a repair shop. Good luck
Posted on Jun 05, 2006
t00nz
  • 4738 Answers
SOURCE: I need a Canon Ixus 70 User's Guide
Go to Canon and download it. Here ya go:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=224&modelid=14901#DownloadDetailAct
Posted on Jan 11, 2008
SOURCE: Web cam set up on Canon IXUS 400/POwershot 400
For any self respecting programmer/hacker, the instructions at http://users.utu.fi/paanni/camera.html maybe close to what you want.
Posted on Oct 22, 2008
parjee
  • 83 Answers
SOURCE: how to fix digital camera canon ixus 70 'lens
Would not recommend opening the camera as the chances are much greater for you causing greater damage. BUT would instead recommend that you try the seven sequential repair step outlined for a lens error in the below listed Related Link "Fixing a Lens Error on a Digital Camera". None of the steps outlined in this link involve opening the camera. and reportedly you should have close to a 50% chance of success with these techniques.
If you cannot repair the lens yourself with the first related link, then consider trying the two 'Digital camera repair" links below for two online digital camera repair businesses.
Posted on Sep 22, 2009
BillB-SA
  • 2761 Answers
SOURCE: how to restart Canon IXUS 70
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, chances are that your batteries need to be replaced because they are just too worn to properly power the camera. And then, of course, there's the possibility that your camera may have a problem that requires professional repair.
Posted on Sep 27, 2009
Hi there left my manualin nz n im in aus now.. just wondering where do i find my option for stitch assist on camera ixus 70
FUNC menu : Auto : Manual
REC menu : Stitch Assist
The IXUS 70 is called the SD1000 in some parts of the world. You can download manuals and more for the SD1000 from the manufacturer's web site at
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_sd_series/powershot_sd1000#BrochuresAndManuals
Full details are in the "Shooting Panoramic images" section of the Advanced User Guide (page 44 in my copy).
Sep 22, 2011 | Canon Cameras
DSC-55 camera flash doesn't work even though in Flash "Auto" setting in Easy or 'i' mode.
If the Forced flash setting is already enabled and the flash is still not working, then the issue may be due to another camera setting. Even if the Forced flash setting is enabled, the flash will still not work in the following circumstances:
  1. When shooting MPEG movies
  2. When shooting in the Twilight or Handheld Twilight mode
  3. If shooting with the Burst or Multi Burst mode
  4. Shooting with Sweep Panorama
  5. Shooting with the Fireworks or High Sensitivity mode.
  6. If an external flash is connected.
Please make sure that the Camera is not set to any of these modes. You can check the manual to get the information to change the setting..
  • If the issue persists, please reset the Camera and make sure that battery is fully charged.
  • If the issue persists after performing all the above-mentioned troubleshooting steps, service is required.
Thanks for understanding.
Mar 13, 2011 | Sony Cameras
My flash will not work on my canon a540 how can I fix it?
  • When shooting MPEG movies
  • When shooting in the Twilight or Handheld Twilight mode
  • If shooting with the Burst or Multi Burst mode
  • Shooting with Sweep Panorama
  • Shooting with the Fireworks or High Sensitivity mode.
  • If an external flash is connected.
If the issue persists after performing all the above mentioned troubleshooting steps, service is required.
If you feel that the above Troubleshooting steps, helped you. please rate my answer positively. Thanks for understanding.
Mar 06, 2011 | Canon Cameras
My flash simply will not work. I have a hard time getting a photo when the flash is needed because it won't allow me to shoot. I select 'no flash' and I get a photo but poor quality. Thank you!
When shooting MPEG movies When shooting in the Twilight or Handheld Twilight mode If shooting with the Burst or Multi Burst mode Shooting with Sweep Panorama mode Shooting with the Fireworks or High Sensitivity mode. If an external flash is connected. Please make sure that the Camera is not set to any of these modes. You can check the manual to get the information to change the setting..
If the issue persists, please reset the Camera and make sure that battery is fully charged. If the issue persists after performing all the above mentioned troubleshooting steps, service is required. If you feel that the above Troubleshooting steps, helped you. please rate my answer positively. Thanks for understanding.
Jan 18, 2011 | Canon PowerShot A560 Digital Camera
The flash won't work even though set correctly according to the manual
If you feel that the above Troubleshooting steps helped you. Please rate my answer positively.
Jan 09, 2011 | GE C1033 Digital Camera
Flash is not working
Dec 31, 2010 | Canon PowerShot SD550 / IXUS 750 Digital...
Canon Digital ixus 70 camera display
Sounds like you're in movie mode and it's shooting a movie.
Dec 24, 2009 | Cameras
How do you use the continuous shoot function on canon ixus 70?
These instructions are for the IXUS 70, even though the category is PowerShot SD500/IXUS 700.
1. Press the down arrow (bottom of main control button)
2. Press the up or down button until you see the icon for continuous shooting, which looks like three squares overlaid on each other.
3. Shoot your pictures. As long as you keep the shutter button depressed, the camera will continue to shoot until the memory card is full.
To return to single frame shooting, follow steps 1. and 2. but select the single square in step 2.
May 08, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
S500 Kept displaying pictures in shooting mode
Navigate the the rotating knob to manual or auto mode then shoot it then ok.
Dec 05, 2007 | Canon PowerShot SD500 / IXUS 700 Digital...
No image
No image in shooting mode on Canon S500. Flash operates and shutter clicks. Whats wrong?
Nov 12, 2007 | Canon PowerShot S500 IXUS 500 Digital...
Canon PowerShot SD500 / IXUS 700 Digital Camera Logo
317 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
