Question about HP Pavilion dv9000z Notebook
HP 17" 9000 laptop, replaced battery & charger, won't run on batt
I have a HP laptop, first the charger went bad then the battery, I have replaced both and now the computer will not run unless it is pluged in and even when it is pluged in it seens as if it is not charging at all
  • meeaton Dec 11, 2008
    It is a replacement charger from another company
  • TrytoFix01 May 11, 2010
    Is this a replacement charger from HP or a universal charger from another company?
    President:
  • 2,110 Answers
There might be some problem with the charger it self..
Posted on Dec 11, 2008
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 90 Answers
Some universal chargers will only power certain laptops, Targus adapters for example.  However, I have seen situations where you can contact them and get a different tip for the adapter that will both power and charge.
My battery won't charge even if I replaced it with new battery.
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test the charger:
1.Unplug the charger from the present laptop,
2.Connect it to another laptop to see if it will charge.
If it charges the laptop, then it means the charger is alright, and if it does not charge the laptop, then it means the charger is bad and need to be replaced.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
If it powers on, then it and charges, then it means the laptop is working fine, but if it does not charge, then it means the connection port of the laptop is bad.Hope this information was helpful.
http://www.chargerbuy.com/laptop-battery.html
Jan 14, 2013 | Computers & Internet
My hp 2000mt pro pc won't start up
The first thing to check is for proper power. Try connecting your charger with the battery removed and powering up the computer. If you are not successful with this, it may be that the charger is defective and not charging your battery.
Advise that you purchase/borrow a supported laptop charger. A local HP repair center should have a compatible charger that you could use to test.
If it is not the charger (the laptop should work without a battery), then you have motherboard problems. Memory or other issues would cause a power on but errors. No power up at all is going to require some sort of board replacement.
At that point, your choice is warranty repair service or, if out of warranty, best bet will be replacement of laptop.
Oct 21, 2012 | HP Pavilion 1137NR Notebook
Toshiba satellite battery won't charge
DID YOU NOTICE ANY OVER HEAT IN BOTH,THE PC OR CHARGER? IF SO THE CAN BE 2 ISSUES.
1-THE CHARGER
2-THE BAT
IF YOU TRY TO CONNECT THE CHARGER WITHOUT THE BATT,THE CHARGER GET HOT? (1) ,DO THE CHARGER IS OK (2)
Apr 26, 2012 | Toshiba Satellite A65-S126 Notebook
Gateway wont power up the batt has been failing ,if pluged in the charging light comes on for a while then goes out if you try to start it tries then shuts down. could a bad batt cause this
If your battery is more than 2 years old, then it is a distinct possibility. Every battery type has a certain number of charge cycles (drain->recharge->drain) or time period. Lithium batteries run about 2 to 3 (tops) years. NiMH run about 10,000 charge cycles (or it could be 50,000 cycles if you know what to do). But if you're NOT using the original Gateway charger, then plug it into your laptop and see if it works. The 3rd party charger may have burned out the internal power components over time. In the worst case, you'll have to replace either the motherboard (hope you still have the product key!) or the motherboard's power connector, inside the laptop. At best, you might have to continue using the original power adapter. It will probably turn out to be a worn down battery, which needs replacing.
Feb 19, 2011 | Amstron Gateway P170X Laptop AC Power...
My HP zt1170 Laptop's battery isn't charging; I bought it today (used) and he said that the battery did charge properly. I plug the AC Adaptor in, the batt. light turns amber for 1 minute then shuts off....
Sounds like the battery was on it's last legs to begin with. The charger appears to be working correctly. Try to reach some agreement with the seller over replacing the battery (not cheap!).
Dec 16, 2009 | HP Pavilion zt1170 Notebook
I was using my eeepc and it stopped running no lights no lcd nothing what do you think the problem is?
Often it is very likely your portable battery, or charger / charger cords went bad.
Try running your laptop with no battery installed that is the battery removed. If the battery is very bad your PC may not power up at all even when plugged in for safety.
If you do not get any lights at all (LCD screen or others) running only on your charger, please test your charger on another similar laptop or have it checked at a store/ or with a meter. It may be out. A cord or wire may be broken on it (common problem also) - physical parts and batteries wear first.
You may also try another battery if available. Look for any signs of or smells of burning or overheating on any parts for more clues.
Replace any bad battery or charger.
Oct 29, 2009 | ASUS Eee PC 4G Surf
I have a HP NC 6120 laptop.I have the batt in and the PS plugged in.All that happens is the Charge Light Blinks yellow 6 times then green 1 time,repeats.At the sametime the power light comes on for 6 sec...
It's probably a bad battery BUT I've noticed this problem pretty often from this model. I would check HP's site for a bios upgrade and I'd also check your warranty status because they just updated they're list of computers that they're extending the warranty on that have the same problem.
Feb 19, 2009 | HP Compaq nc6120 Notebook
Laptop not starting
will it run on ac only? meaning with the battery out. if so the new battery may have issues. remove the battery and see if it comes on with the ac adapter if it does take the battery back.
Aug 28, 2008 | HP Compaq Presario V6171CL Laptop
Have a gateway 3520, won't power up
you could have a bad power port...how do you know that the batt is charged?
if its not the power port then it could be a bad switch...or main board
what happens when you press the power button?
can you hear your cd drive fan or anything start up?
how advanced are you?
May 25, 2008 | Computers & Internet
HP Pavilion dv9000z Notebook Logo
276 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
