Question about Canon PowerShot A95 Digital Camera
LCD and lens not working
Hello. I have a strange problem. When i try to switch on the camera with the LCD opened, the lens moves just a little bit. Then , when i close the lcd in a non-viewing position, the lens seem to be working but other than that it does nothing but 6 (or 5) beeps whenever i try to make a photo. The LCD doen't operate in both of the situations. Please be so kind to send me a suggestion. Thanks, Mihai
    Genius:
  • 2,985 Answers
This is a circuit board failure contact Canon customer support
Posted on Jul 29, 2007
When turning on the camera it makes strange noises (autofocus motor is trying to adjust) and the LCD-screen stays black. When turning off the camera the same noise sounds and ths LCD-screen says "lens...
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Aug 26, 2010 | Casio Exilim EX-Z77 Digital Camera
Lens won't open, & it says lens error, restart camera.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try
Jul 24, 2009 | Canon PowerShot A560 Digital Camera
Canon G7 lense does not extend fully but it is NOT e18
Maybe lens needs adjustment. The info on this page may help. Copy and paste this link for more info.
http://www.fixya.com/PostAnswer.aspx?thid=1841738&prdid=447928&ctgid=67
Mar 22, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
Camera Lens Cover won't open
Since Sony will not sell parts you have 2 choices here, replace the camera or send it in to Sony for repair.
Apr 17, 2017 | Sony Handycam DCR-DVD403 DVD Camcorder
Lens error
Press the power button on and hold it down while extending and twisting the zoom lens......
Oct 03, 2008 | Canon IXUS V2 Digital Camera
Kodak Easy Share Z1275 stuck lens
I have a Kodak 1275. Green light would go on the off and lens was stuck open. Now for solution that worked for me. Get a can of compressed air, like what you use for computer keyboards. Blow the compressed air all around your stuck open lens, not to fast and switch directions of where you blow air around stuck opened lens. Make sure batteries are fresh and fully charged. Tap your camera against the palm of your hand twice, not to hard or you may damage instead of jarring lens lose. Next lay your camera on a table lens facing up, push power button on so camera will try to auto focus and lens should reseat itself and lens should move freely. It doesn`t have to look dirty or dusty, little tiny particles can cause the lens to get stuck and shut off fast because it is a safety feature. If this does not work try plugging your camera into computer so the lcd screen does not try to go on , thus giving even more power to get your lens moving . Do not try to force it closed by pushing or twisting with your hand or you may cause damage that will cost as much as the camera to fix.
Jun 05, 2008 | Kodak EasyShare Z1275 Digital Camera
Lens error
Hello folks,
I hate to be the bearer or bad tidings but you have all suffered from what is probably the number one affliction of digital cameras - the deadly child drop :-(
In almost all cases the camera has to be sent in for service when this happens. Obstructions (by hands, restrictive pockets, or even pocketbooks with little extra space in them) are very common causes of lens errors as is drops, and all cause damage that needs to be repaired at the Service Center.
Even worse, this type of damage is not covered under your warranty even when you are still within your 12 month warranty period. Therefore there will be a charge.
The good news is that the charge is less than the cost of a new camera, and that for certain camera models below the A560, you may qualify to upgrade to this model for less than the repair cost. Call Canon at 1-800-828-4040 for your options. Good luck.
Hope this helps.
Sincerely,
HeavyDLB
Apr 28, 2008 | Canon PowerShot A570 IS Digital Camera
Black screen, loud beeping when opened, doesn't work
The following blog outlines some simple repair options for a lens error. But please first try the listed Fix #2. I heard that fix particularly works well for a camera who's battery had run down with the lens open. Please post back here with a follow up comment if any of the fixes work:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Dec 23, 2007 | Canon PowerShot S60 Digital Camera
The slide doesnt open
Contact this site as theres as well a toll free Tele # Good Luck http://www.nikoncamerarepair.com/
Apr 09, 2006 | Konica Minolta DiMAGE G400 Digital Camera
Canon PowerShot A95 Digital Camera Logo
46 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
