My dishwasher stopped and then flashing 7 times. ichecked everything possible.no luck.pls advise.thanks.
Hi... i had same problem with my dishwasher Model: ADP 4695/7 , it just started by flashing 7 times. Here is what i did...
1 - switch off machine on the ON/OFF switch
2 - press start program button and at the same time turn ON/OFF to ON but dont let go the start program button,whait till it flashes...
3 - after that just let go the start program button and just press it again
I believe the problem is solved now,it should go ok with the program, what u just did was to reset you mashine :D
Hope to be helpfull guys/ladys
From Portugal ACETUGA ... cumps
Although i dont have a lookup for your particular model number. if you remove the lower access panel you will find techsheet/troubleshooter. in it there will be section on "clen light blinking 7x" foplloe direction to put into test mode to clear the fault. belive its,,, heated dry/ sani rinse / heated dry/sani rinse. pushing htese buttons is what gets into test mode
