Question about Canon PIXMA MX310 All-In-One Printer
Scanning photos into computer at a large size?!
I am having major issues scanning pictures from my scanner onto my Mac in a large size.  I scan them in and the pictures appear small with a bunch of white around it.  How do I scan the photos in to appear at a larger size?  (so people don't have to squint to see the people in the pics and so it doesn't have all the white around the photo)??!!
  • random4jeni Dec 24, 2008
    Thanks Rookie2112, I'll have to try again when I am home.  Your answer sounds confusing as far as the 300-600 dpi.  I don't know what that is!  Except that it's a resolution?  I am SO illiterate when it comes to anything having to do with computers and printers, etc!  Sigh.  Thank you for your response!!
This sounds like you are trying to scan images at a larger size than they actually are?
I am not an expert-(but I have a Mac)-but from what I'm reading, scan your photos at a 300-600 dpi resolution, then use photo editing software to enlarge them. The higher the resolution, the more disk space and the more photo detail (i.e. cracks, dust, scratches, paper type) will be captured, and the more time it will take to scan. Also, for the white, does your scanner allow you to select the area/define borders during the pre-scan? Mine lets me drag borders to just the image area (but capture the image first, then do the cropping and editing to a copy later).
Rookie2112
Posted on Dec 22, 2008
Need to change font size larger when printing
Change the font on your document before printing
Jan 12, 2015 | Office Equipment & Supplies
B&w/gray Scanning Is Okay But Color Scanning Problem
Run ink head cleaner routine. If you cannot the list make and model of printer. Thanks.
Dec 25, 2014 | Office Equipment & Supplies
Scanner computer cant comunicate
What do you want Darrell?
Code reader or Professional scan tool?
I think your going to need a shop to work on it
Without wiring diagrams your done
You have to chase every wire from the under dash
connect to their ends, until you fix the issue & can
connect to the Bus & Data stream,we can't help with that
Jul 17, 2014 | Office Equipment & Supplies
Hp laserjet m1522f error 5 turn off and on
Hi, Error 5 is a Scanner error. When turning the printer on, have the lid up so you can watch the scanner movement. Does it move smoothly? It should go through a warm up and you should be able to watch the scanner movement. If there is a problem with the scanner, there isn't a lot you could do except. The service manual says the scanner assembly should be replaced. If it was my printer, I would try to take a closer look at the scanner assembly and check to see if the scanner unit is bound up somewhere, or maybe a drop of 3 in 1 oil on the scanner rails. Let us know what happens.
thanks
Oct 02, 2013 | Office Equipment & Supplies
Samsung SCX-3201G printer driver free download
Samsung SCX-3201G printer driver no download plzzzzz help me
Jun 21, 2012 | Office Equipment & Supplies
HP Laserjet 3330. Scanner bulb warming up doesn't go away. I have done the "solution 1" as discribte but nothing is happening. It goes like: - i put the power on, hewlett packard is flashing, the...
How does the bulb look? Is it bright or kind of dim. The bulb warming error is designed to halt use of the machine until the scanner bulb reaches the correct output level. As these are basically a flourescent tube, they will dim over time and at a certain point they will not generate enough light to enable proper scanning. If the bulb is dim, it will require replacement.
Mar 14, 2011 | Office Equipment & Supplies
Why does canon MP258 printer with scanner can't scan japanese yen paper bill amount 10,000. I tried it over 10 times but it stops,. And when i tried US paper bill, it works well. I need some explanation...
When you scan with any scanner it utilised the software with "Optical Character Recognition functions, usually abbreviated to OCR -> OCR is a field of research in pattern recognition, artificial intelligence and computer vision." to scan and record the scanned object, sometimes it does not or cannot recognise certain symbols or characters because of man made software & hardware have its limitations too.
Hope it helps.
Nov 12, 2010 | Office Equipment & Supplies
HP printer psc 2210 all in one
Chances are that you didn't lock down the scanner when you moved the unit. You can attempt to open the unit and move the scanner bar manually to reset it. HPs are very difficult beasts when it comes to their power up check out. It must be fully functional...including all cartridges...to work in most cases. Good luck.
Dec 20, 2007 | Office Equipment & Supplies
Canon PIXMA MX310 All-In-One Printer Logo
162 people viewed this question
old marine
old marine
Corne Viljoen
