Question about SanDisk Sansa e200 MP3 Player
Do all the Sansa E200 series MP3 players use the same size LCD screen?
    Problem Solver:
  • 6 Answers
Yes, the only difference between the e250, e260, etc. is the internal memory capacity.
Posted on Jun 02, 2009
I need a free downloadable manual for a sansa sandisk e260
You may download a copy of the E200-series manual here. The only difference among the E200-series is the amount of internal memory.
Jan 09, 2013 | SanDisk Sansa e200 MP3 Player
Tip
For Version 2 Sansa E200 Series and Version 2 Sansa C200 Series
As you have notice, these version of player will not have the USB Mode / Mode ( FOr Rhapsody Players ) and / USB for sansa C200 series. If you want to have your player detected by the computer as a removable disc drive or as a MSC drive you can perform this easy steps.
For Sansa E200 Players and C200 version 2 Players.
1. Enable the Hold Switched for it to show a red color.
2. Press and Hold the Rewind button the " << " then connect to the computer.
3. Connect the player to the computer and dont let go of the Rewind Button " << " , you will notice that the player would be detected as a removable drsc drive in the My Computer Window.
*For Load Main Image Failed Problems and player Freezing on the Refresh Database Screen will be post later*
on Dec 08, 2007 | SanDisk Sansa e250 MP3 Player
How to use sansa mp3 player
Download the manual from http://www.sansa.com
Click "Support" then search for "e200 manual". You can then proceed to download the appropriate manual (all the e200 series work the same way, so you're going for one of the e200 manuals).
May 11, 2010 | SanDisk Sansa e250 MP3 Player
Sansa 40gb e260 dont know how to put music on it . dont have manuel
For the Sansa e260 4 GB there are 2 versions for the e200 series players:
version 1 manual
version 2 manual
Check the version of your Sansa e200 series:
go to Settings > Info.
SD card compatibility:
For 01.xx.xx firmware (e200 version 1) - up to 2GB microSD cards
For 03.xx.xx firmware (e200 version 2) - up to 16GB microSDHC cards
NOTE: Firmware is not interchangeable.
Dec 09, 2009 | SanDisk Sansa e260 MP3 Player
How to operate sansa and creating data base
Sansa support for e200 series:
http://www.sansa.com/support/sansa_e200/faqs
user manual e200
For making videos appropriate for your player use:
sansa media converter
When a total reinstall for the player is required perform:
sansa firmware updater
Remember: running a firmware update will erase all data on the player !
For transferring files from the computer towards the player you can use
Windows Media Player 11. A short guide in how to make transfers:
1. Have WMP11 always on top for "drag and drop" usage
Right click in the head of the WMP11 page:
in Tools > Options... > Player : select "Keep the player on top ..."
Restore Down the size of the WMP11 screen and adjust the size on the
edge(s) as you require for your screen.
2. in [Library] mode: under Playlists "Create Playlist" e.g. "My Playlist"
and Enter: "My Playlist" is added on the right screen side.
3. Open your data maps and ad files by drag and drop method
onto the right saying "Drag items here"
4. when ready adding files in [Library] mode: "Save Playlist"
5. in [Sync] mode drag e.g. "My Playlist" under the connected device
and "Start Sync": wait until al files have synchronized: a message
will show up when you can disconnect the player.
Sep 13, 2009 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e200 cracked LCD screen
The LCD screens on the Sansa e200 series are soldered to the motherboard and are therefore beyond the skill level of most end users. Most repair shops also will not be interested in or capable of doing the repair. If you have the inclination to try and repair the screen, you first need to find a donor e200 series mp3 player that has some problem other than the screen, as you will most likely be unable to source the LCD any other way.
The best solution is to simply buy a new one - unless you enjoy soldering small traces.
Nov 20, 2008 | SanDisk Audio Players & Recorders
SanDisk Sansa m200 series and my macbook pro
It is complicate,
it works on Mac OS only if you downgrade firmware for sandisk.
Here is how to do it.
If system crashes while you install the firmware you will damage the sansa, Mac OX is solid , but be careful with the USB cable.
Here is the procedure: How to use your SanDisk Sansa e200 Series .mp3 player with OS X ...
Here you can also download software
Sep 13, 2008 | SanDisk Sansa e200 MP3 Player
Sansa e200 series 4 GB player
Unfortunately the lcd's are affected by heat and direct sunlight. I've had to replace lcd screens in cell phones because of this, a customer left his phone in his car and the temperature in the car reached about 135 degrees Fahrenheit.
Mar 04, 2008 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
23 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
