Question about Whirlpool Duet GHW9150P Front Load Washer
My washer keeps showing the codeF71 what does that mean ?
    President:
  • 373 Answers
Fault with motor driver circuit board.
Check out this site for info: www.2ndwave.co.uk/manual.html
Posted on Dec 11, 2008
Amana front loader washer Model# NFW7200TW. Keeps shutting down and shows the digital reading of E3.
It means there is a problem with electronics, Amana indications are to call the service
May 31, 2008 | Amana Washing Machines
Sears washer keep showing ul code ..why
That means that it has been overloaded. IF it is giving this error and there is nothing in the machine then it has a bad sensor. It could also be that the drum has broken loose from the shocks or springs that support it.
Mar 24, 2013 | Sears Washing Machines
GE Washer Model ## WPSB9220D0WW Data Code31704 Error Code E43 Drive System Excessive Brake Time My washer don't do anything but show this error
On GE Washer Machines, E43 error code means "excessive brake time". The brake and speed sensor will need to be checked. You can try resetting the machine by disconnecting the power for 20-30 minutes. Keep in mind that your right model number is WPRB9220D0WW.
You can eliminate if it's the speed sensor by entering the service model. To do this:
- Turn off the washer at the power pad
- Remove power by unplugging the cord for 15 or more seconds
- Plug back in and within 30 seconds simultaneously press and hold the POWER and START pads for 3 seconds
- Should now display the model codes
- There are a bunch of tests but we are interested in the spin fast portion, so press the custom 2 pad until the display shows SF ( Spin Fast )
- Hit START pad... it should start spinning and display the rpm's
If it does this the speed sensor is working and the problem is the brake which means the transmission has to be replaced. Parts replacement can be find in THIS LINK.
If you do not feel able to resolve it, we recommend you call the technician to do it. Now you know what the problem.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 10, 2011 | GE Washing Machines
It shows a LE code
Hello.
The code showing at the front of the screen of your washer means the below explanation.
The L means LOCK and while the
E means ERROR.
However what the washer is saying is that you need to lock up the door of the washer properly then the problem of the LE will be solve .
Thanks.
Nov 08, 2011 | Washing Machines
My Maytag Washer quiet seriouse keeps showing UL the last 11min of the spin cycle and I don't kno wats wrong
Hi
UL fault code indicates 'unbalanced load' which means the unbalance switch or control board may be faulty.
Sometimes it just means you have heavy items such as large towels or curtains in the wash but if it persists you will need to get it looked at.
Ash
Please rate this solution if you find it helpful
Dec 20, 2010 | Maytag Bravos MTW6600T Top Load Washer
My washer shows a HC in the panel. what does that
HC means that the Hot and Cold water lines are reversed. Make sure that the supply hoses are connected correctly. If they are, then there is a problem with the sensor or control board.
Apr 28, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Samsung front load washer keeps getting E7 and E3 what is this?
E3 - MICOM is attempting to drive the motor but is not getting any
response signals from the hall sensor. Visual check shows
motor is not running. (Locked, Defective Hall Sensor or
Overload)
Im not locating an E7 error. Did you mean 7E?
This information may or may not relate to your washer since you did not provide a model number.
Nov 25, 2009 | Samsung Washing Machines
E 20 showing on machine
it means u should trow the **** thing from a clip. e20 goes on my nervs
Oct 14, 2008 | Zanussi FJS1225W Front Load Washer
Kenmore elite front load washer
I HAVE A KENMORE ELITE WASHER AND IT STOPS IN THEN MIDDLE OF THE CYCLE AND DOESN'T RISNSE. THE DISPLAYS SHOWS F21. CAN YOU LET ME KNOW WHAT THIS MEANS?
Sep 22, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal De
