When i print online, copier counter does not give me print count as per 'Department Code'. I want to setup on-line printing with individual 'department codes'. THIS MACHINE IS CONNECTED WITH WINDOWS VISTA network. Please help me.
  • kaohongrat Feb 03, 2009
    i also having problem with page count Kyocera FS 1020D printer . I dont know which setting should I take out page count list.
    Pls help me
  • 168 Answers
If you have the codes in the copiers allready you need to turn job accounting on in the print driver settings find copier under your pronters and faxes right click on it select properties then i believe under the device settings you have to check job accounting then enter the id code
Posted on Dec 11, 2008
How do I get my Canon Pixma ip7220 printer to stop printing blurred lines?
Hello, my name is Steve.
This is an early sign of print head failure.
Soon it will give you an error code on display or ill be observed on your computer. The print head nozzles are not firing correctly. The only way to remedy this is to:
1. Have the printer serviced and cleaned ( the cost of the new print head and a cleaning and servicing of the printer
2. Order the print head online and install it yourself. The wonders of the internet can find an give you a video of how to do this.
The part number is: Canon QY6-0082-000 Printhead (Canon QY60082000 Printhead) I hope this helps, Steve
Jul 29, 2015 | Canon PIXMA iP7220 Premium Wireless Inkjet...
How do i find the w&b numbers to input for my monthly meter reading?
User tools button then counter then select print counter that will give black and white total count use that number
May 31, 2014 | Ricoh Aficio MP-201 Copier w/ Duplex...
How do you get the total counter to print? When I log in under Administrator, I can print out department codes, but the total counter will not print. It will only show on the screen.
There is a counter button on the panel that brings up 4 squares. One of them is print out total counter. One button on the panel and one touch on the screen. Hope that helps.
Feb 22, 2011 | Toshiba E-STUDIO 850 Copier
How do I print the total amount on my ticker tape of what I've added? I pressed the equals sign but that didn't work.
"OFF": Power OFF
"•": Power ON. Set to the non print mode.
"P": Power ON. Set to the print mode.
"P•IC": Power ON. Set to the print and item count mode.
1) For addition or subtraction, each time is pressed, 1 is added to the item
counter, and each time is pressed, 1 is subtracted.
• The count is printed when the calculated result is obtained.
• Pressing of , clears the counter.
2) When the grand total/rate setting mode selector is in the ON position (GT), the
counter will count the number of times that the calculation results have been
stored in the grand total memory. To print and clear the count, press the key.
3) The memory item counter will count the number of times that the key has
been pressed in the addition.
Note: • Each time the key is used in the subtraction, 1 will be subtracted from
the count.
• The count is printed when the memory is recalled.
• Pressing of the key clears the counter.
Note: The counter has a maximum capacity of 3 digits (up to ±999). If the count exceeds
the maximum, the counter will recount from zero.
Dec 17, 2010 | Sharp EL-1801P Calculator
Is there a counter for pages printed on my 1320n
No, the page count is not on the test page. You need the configuration page. Press the GO button and hold for 5 seconds. The yellow light will come on and you can release.
Apr 05, 2010 | HP LaserJet 1320n Printer
80 maintenance infoprint 1125
You need to replace your Maintenance kit and reset the fuser count.
This counter is reset by the servicer after a “80 Scheduled
Maintenance” message displays (300K copies) and a maintenance
kit is installed.
To view the Maintenance Page Count:
1. Select Maintenance Count Value from the Diagnostic menu.
2. Press Return to go to the previous menu.
To reset the Maintenance Page Count to zero:
Select Reset Maintenance Count. Pressing Select resets the
maintenance page counter to zero. Reset Maintenance Count
Saved displays momentarily. When the reset operation is complete,
the menu returns to the Printer Setup Reset Maintenance Count
To enter the Diagnostic Mode:
1. Turn the printer off.
2. Press and hold the Go and Return buttons.
3. Turn the printer on.
4. Release the buttons when "Performing Self Test" displays on
the operator panel.
The tests display on the operator panel in the order shown:
• Print Registration
• Print Tests
• Hardware Tests
• Duplex Tests (If installed)
• Input Tray Tests
• Output Bin Tests
• Base Sensor Test
• Printer Setup
• Error Log
• EP Factory Defaults
Sorry English only.... hope you can read English or google translate it...
Feb 24, 2010 | IBM Infoprint 1125 Laser Printer
Okipage 8w print drum
Reset the Drum Count:
Open the Status Monitor.
Click Printer Setup tab.
Click on Printer Menu button
Click the Maintenance tab
Click on the Drum Counter Reset button.
May 15, 2009 | OKIPAGE 6w Led Printer
Changed drum but it is still saying 'change drum'!
On some printers after you change the drum, you have to reset the counter so the printer knows the drum has been changed. How to reset the counter is as follows:
1. press the ONLINE button to return the printer to off line status.
2. press the MENU button repeatedly until the MAINTENANCE MENU is desplayed, then press the SELECT button.
3. Press the item button until DRUM COUNT RESET is displayed.
4. Press the SELECT button and the Drum Counter is reset.
Hope this helps.
Nov 10, 2008 | OKI B4350 Laser Printer
Printing to copier
ah, probably it means that the department ID is activated on your copier.
go to the printing preferences on of the panasonic dp-4530 on your pc, the click the job type tab.
on the space provided you may type in the code that you use during copying or ask the person incharge on your company re department code.
Aug 18, 2008 | Panasonic Workio DP-4530 Copier
176 people viewed this question
