CHAGING PROBLEM
SOURCE: i have some liebert ups 6kva i have problem in
Hi, Thanks for contacting fixya. There could be many reasons.
1. The battery is old and completed its charge-discharge cycle.
2. The step down transformer (220/110V to 12/24V) coils got shorted inside.
3. For a trickle charger, the SCR might have gone bad.
Solution for 1. Take out the battery and charge it by another charger. You can use laptop charger, cell phone charger or any charger. You might have to do a little bit circuitry. Then after 2-3 hrs of charging see if the battery voltage goes to its peak. Use a voltmeter or multimeter to measure that. If the voltage does not goes to its peak then battery is faulty. And the charger circuit has no problem.
Solution for 2. Some times step down transformer goes wrong. Measure the output voltage by a multimeter and see if it is giving the voltage what it should be. If not then change the transformer.
Solution for 3. I don't know how to determine if an SCR is wrong. The easiest way to check is to replace it and see if the battery is changing.
