Question about Soyo KT400 Dragon Ultra Motherboard
Buzzer on motherboard sounds
When I turn on the power the cpu fan comes on the the buzzer sounds and the fan stops. The buzzer keeps sounding till the power is shut off.
    President:
  • 2,110 Answers
Try to change RAM ...
Posted on Dec 11, 2008
The dryer buzzer keeps going off even when dryer is off
When the dryer stops can you advance the timer a little to turn off buzzer? Or when you open the door does the buzzer stop? I was trying to find a schematic for that model but I have had no luck. Power should come from the timer to the buzzer. If you know how to read a schematic. Unplug the unit and remove the back to the control panel. Check to make sure that all the wires to the timer are on the right connections. You may need an appliance repair service from your area to come out and diagnose it for you.
Apr 02, 2013 | Frigidaire Westinghouse Electrolux...
Buzzer sounds at random in 2004 Focus
LOL... the rear hatch needs to be realigned.. try moving the latch catch back a bit so it seals correctly!
Jul 30, 2012 | Ford Focus Cars & Trucks
The printer is not printing receipts and the error indicator is blinking on and off, what is the solution to this?
Flashing (approx. once every second): Out of paper
Flashing (approx. twice every second): Mechanical error (Buzzer sounds once.)
Most likely your paper feed is giving you the error. Remove the current feed, ensure there are no paper jam & insert fresh paper.
If
Mechanical Error :: Quick blinking Buzzer Sounds continuously for a pprox. 1 second :: Reset the Power
switch
Paper End Blinks.:: Buzzer Repeats a short 3-time sound twice at intervals of 0.5 second.:: Set a new paper roll.
Paper Near End Blinks.(Once a second) :: buzzer Repeats a short 3-time sound twice at intervals of 0.5 second.:: Set a new paper roll.
Mechanical Error : If the printer mechanism has a greater load due to a paper jam, etc., the buzzer will sound and the SEL/ERROR lamp will blink to stop the printer mechanism.
Paper End : If the printer has run out of paper, the paper sensor in the paper path near the print head will detect the end of the paper roll, turn on the buzzer, and blink the SEL/ERROR lamp to stop the printer mechanism. If the paper is inserted into the paper path, the paper will be loaded.
Paper Near End : If the paper is running out, the paper near end sensor will be activated to turn on
the buzzer and make the SEL/ERROR lamp blink. Even after the paper near end is detected, a command can be used to print by the specified number of lines. (See a description on the command for setting the number of print lines after paper near end detection)
Finally
Backup Data Clear : When the power is turned on, depending on the SEL switch operation, the
backup data in the input buffer will be cleared according to the flowchart on the next page.
To clear the input buffer, turn on the power while pressing the SEL switch.
The following messages will be printed.
"Clear Data in Buffer"
"Cleared Data in Buffer"
To print the data in the input buffer, simply turn the power on.
The following message is printed and the data in the input buffer is printed.
"Power Down(Data in Buffer)
Dec 13, 2010 | Citizen iDP-3550 Matrix Printer
I was running a virus check, asked what to do, I said fix, computer shut down and alarm buzzer came on. now I don't get a boot sound
soks3d,
With the system shut down, unplug the power cable from the power supply. Open you're case and pull the memory from the system wait a minute than reseat the memory. Re-connect the power cable to the power supply. Try booting the system and enter the bios menu. (Pulling the memory will clear any memory resident virus). This has nothing to do with the alarm buzzer sound you heard. Typically the alarm sound is generated by the CPU. It's an audible warning that the CPU is over-heating. The CPU will shut down you're system so as not to damage the motherboard and CPU. (Suggest you check the CPU fan for dust build-up. Use canned air to help remove any build-up. You can also use a clean paint brush to help remove any dust from under each CPU fan blade.
It's also possible that the CPU fan is running far too slow and may need to be replaced.
See page 3-23 in you're user manual.
3-8. PC Health Status.
Open the link provided below for a new heat-sink and fan assembly for a socket 462;
http://www.directron.com/a4004d.html
If the CPU fan and heat-sink assembly seems clean it is also possible that the thermal grease / thermal tape between the heat-sink and CPU is too old and needs to be replaced. (Save this check for last).
Below is the link for you're motherboard;
http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=KV7-V&fMTYPE=Socket+A
Cheers'
Mike
Feb 20, 2010 | Abit KV7-V Motherboard
Ultra m923 mid-tower case won't stop beeping
The problem is the board on the case's display. It has temp alarms for your components(video card, hdd, cpu), there are temp probes for you to set so you can monitor these temps. However the board that controls these functions, or at least mine and many others I have read about, is defective. It will change display constantly and sometimes have garbage display. It is setting its own limits for what is considered a hi temperature. The limit it has set for one of your components is < room temperature so it thinks you are having an overheating problem. You can manually set the limit for overheat and it will fix it for a while, but it will prob happen again.
Jul 03, 2009 | Ultra Products Ultra M923 Full Tower ATX...
I have a kt400 Dragon motherboard I am hooking up. When I turn the power on the cpu fan comes on the the buzzer on the motherboard sounds and the fan stops and nothing works.
This is a Soyo motherboard which was discontinued some time ago. Soyo does provide some support, though, with drivers and the manual located here:
http://www.soyo.com/content/Downloads/155/&c=37&p=146&l=English
The buzzer you are hearing is the ABR Buzzer. ABR stands for Anti-Burn Regulator. Circuitry on the MB monitors the internal CPU temperature, and when it rises above a certain level, the buzzer sounds and the system will shut down, to prevent the CPU from being fried.
In my experience, this is typically due to a malfunctioning CPU fan. You said yours is spinning at boot, so it might not be the fan. It may also be that you are trying to use a CPU that is not fully compatible with the motherboard (especially one that is 6 years old). If this is the case, the ABR software may be mis-reading the data from the CPU, thinking it is overheating, and then shutting it down.
The manual is one of the best I've seen as for detail and explanations, so I'd give it a look. This is the direct link for it:
http://www.soyo.com/uploads/downloads/manuals/k7/mk7vx4b12.pdf
Also, if you are trying to overclock the CPU, that can cause overheating in a hurry, and result in a shutdown. You might want to reset the motherboard to factory defaults (remove the CMOS battery, wait a bit, re-install it), in case a previous owner had been using overclocking.
Cheers
Nick
Dec 11, 2008 | Computers & Internet
Buzzer sound from intel d101ggc motherboard
Check the fans in your pc, it sounds like at least one of them isent working properly and your pc gets overheated. When a pc going to warm it gets really slow and hangs.
My guess is that the CPU-fan dosent work properly and your CPU gets overheated, but check all the fans to be sure. The CPU fan runs cantantly, check so it dosent stop now and then.
Good luck
Nov 21, 2008 | Intel D101GGC Motherboard
Buzzer sound from motherboard spkr
Hi kuldeep11203, your Intel D101GGC board uses the Award bios. http://www.bioscentral.com/beepcodes/awardbeep.htm
Though the descriptions vary, I suggest you check your CPU heat-sink & fan assembly. Clean assembly from excessive dust build up. Remove CPU fan if possible & clean the heat-sink. Check the CPU fan, it may be turning too slowly & may need to be replaced. The average CPU fan runs between 2000 Rpm & 3000Rpm. Blow out your power supply with canned air. Disconnect & than re-connect the Main power connector (2x12) on the board. Item No# K, found on page 11 in your manual. Try these first. See if the buzz sound stops after a good cleaning.
If not replace the Heat-sink assemble with a new one. Check this link for a new assembly for LGA775 socket;
http://www.google.com/search?hl=en&q=heatsink+and+fan+for+LGA775+socket&btnG=Google+Search&aq=f&oq=heatsink+and+fan+for+
Good luck kuldeep11203!
Mike
Kenmore Series 70 Dryer Buzzer won't stop buzzing - Model 110.96573220
  • the buzzer is located under the control panel.
  • you can unplug it.
  • unplug the dryer or turn the breaker off first
  • then take out the 2 screws on both sides of the control panel
  • bull it forward toward you and unhook it from the case
  • you should see the buzzer with two wires going to it
  • only need to disconnect one.
  •  just make sure you wrap the bare wire connector with electrical tape to keep it from touching metal.
Jun 28, 2008 | Kenmore 60172 Electric Commercial Dryer
Soyo KT400 Dragon Ultra Motherboard Logo
250 people viewed this question
Top Soyo Computers & Internet Experts
Roy May
Matson Kurian
Matson Kurian
Are you a Soyo Computer and Internet Expert? Answer questions, earn points and help others
