Question about HP Pavilion dv6000z Notebook
Error Message: Ntkrnlmp.exe Could Not Be Loaded Error Code 7
I try to setup a new copy xp and i get the error
    Problem Solver:
  • 10 Answers
Replace the ram and check.
Also configure the bios to LOAD DEFAULT SETTINGS
Posted on Dec 07, 2014
    Scholar:
  • 86 Answers
You have a corrupted XP disk... Try pouring rubbing alcohol or vodka on it and letting it air dry...
Posted on Dec 11, 2008
How can i reinstall the ntoskrnl.exe when it is corrupt
Assuming a couple of things:
1. Your OS is Windows XP
2. This is the error message you are getting -
"Windows NT could not start because the following file is missing or corrupt:
Winnt_root\System32\Ntoskrnl.exe
Please re-install a copy of the above file."
To reinstall notskrnl.exe, do this:
  • Start the computer by using your Windows XP CD-ROM. Press any key to boot from the CD.
  • After the setup files are finished loading press R to repair using Recovery Console.
  • When you are in the recovery console, select the installation to log on to (usually number 1), and then press ENTER.
  • Login to the Administrator account by typing the password for this account, and then press ENTER.
  • At the recovery console command prompt, type the following command, and then press ENTER:
    For Uni-Processor systems: expand <cd-drive>:\i386\ntoskrnl.ex_ <hd-drive>:\Windows\system32\ntoskrnl.exe
    For Multi-Processor systems:expand <cd-drive>:\i386\ntkrnlmp.ex_ <hd-drive>:\Windows\system32\ntoskrnl.exe
    Note In these two commands, the <cd-drive> placeholder represents the drive letter of your CD drive, and the <hd-drive> placeholder represents the drive letter of the hard disk on which windows is installed.
  • If you receive a prompt to overwrite the file, press Y.
  • Type exit, and press ENTER at the command prompt.
  • You should now be able to boot up properly.
  • Oct 14, 2013 | Dell LATITUDE Computers & Internet
    How to fix file \i386\ntkrnlmp.exe error 7
    Depending on the cause of error, you need to either change your BIOS settings to default or replace the faulty RAM to resolve it.
    Change BIOS settings to default
    To apply default BIOS settings, enter your BIOS setup, select and save the default BIOS settings.
    Restart your computer
    During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
    this will vary depending on your computer and operating system
    Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimised defaults press escape then press f10 to save to cmos to restart
    Note: When your system loads, the text in the bottom part of the screen contains information on which key you need to press to enter the BIOS setup.
    Also, before changing your BIOS settings, note the current settings.
    This information will come in handy if you need to revert to your old settings later.
    Replace the faulty RAM
    If you find your BIOS settings were already set to default, the cause of the above errors could be faulty RAM.
    If you have only one RAM installed, then replace it with new RAM to fix the error. In case you have multiple RAM chips, then to identify the faulty RAM chip, take out all the RAM chips, insert them one by one and restart your computer each time.
    Discard or replace the RAM chip that generates the error after installing.
    Note: You can also use the help of a reliable memory diagnostic tool to identify the corrupt memory module.
    Besides incorrect BIOS settings or faulty hardware, another major cause of recurring exe errors is malware infection.
    Malware, such as worms and viruses deliberately change the reference points of exe files in the registry.
    As a result, exe errors, such as ntkrnlmp.exe errors occur every time an application tries to execute the infected file.
    To prevent malware from causing exe errors on your computer, we recommend you secure your PC by installing robust antimalware software, such as Antivirus Plus and StopZilla.
    Also, schedule regular malware scans of your entire PC and keep your antimalware software updated with the latest virus definitions and security updates.
    I prefer to try the free ones before committing to a puchase
    http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7
    Furthermore, ensure that your registry is clean and devoid of unwanted information.
    Oftentimes, registry issues are found to be the root cause of many system errors, including exe errors.
    Perform regular registry scans using efficient registry cleaning software,
    such as RegGenie,or http://download.cnet.com/ccleaner/
    registry cleaner its also free
    to eliminate any incorrect and corrupt entries from your registry.
    hope this helps
    Aug 22, 2012 | Acer FOXCONN 651 M03-G-6L SOCKET-478...
    Cant install windows 7? i put the cd in and go to auto boot but it gives me a code 5 error.
    To resolve Windows 7 Error Code 5, all you need to do is start the installer through a different installer. Either find an old Windows XP boot disk and then direct it over to the Windows 7 installation DVD and run Setup.exe. This should kick off the installer normally and allow you to install the operating system.
    Jan 10, 2010 | Asrock K7VM3 Motherboard
    Photoshop 7.0 installation fails with the error message: "An error occurred during the move data process : -106" Upon install process it makes it to about 1% then gives the following error code....
    one problem that could cause this error is lack of administrator rights,
    right button click the setup.exe or whatever it called and select run as administrator,
    Or if it's Vista try the compatiblity help , right button click the app, select properties and select run as XP service pack2 etc
    Regards
    gewiz.co.uk
    Nov 30, 2009 | Computers & Internet
    I have an eMachine T3410. When it boots, a screen
    your missing the biosinfo.inf. try reinstalling the system but backup everything you need first.
    Jun 09, 2009 | E-Machines eMonster 600 PC Desktop
    Black screen with an error code 7
    code 7 means the storage blocks have been damaged...the message is saying it cant locate the kernal map..
    use software to check hd for bad sectors if sectors ok insert os disk and repair os.
    Dec 16, 2008 | HP Pavilion dv1000 Notebook
    D:\setup.exe is not a valid win32 application
    I don't the problem in the drive, please try to copy the file to your desktop then run it again the same error appears, download the installer for your windows then try from the CD
    Dec 04, 2008 | Microsoft Windows XP Professional With...
    PROBLEM
    here are some link for the error codes hope this helps.
    ERROR CODE 7( NTKRNLMP.EXE) .http://support.microsoft.com/kb/812580
    ERROR CODE 4 ( SETUPDD.SYS) .http://support.microsoft.com/kb/330181
    Sep 18, 2008 | Toshiba Computers & Internet
    Problem starting windows
    Does the recovery CD give you the option to format your C drive? If not, you can try to get hold of a windows XP disk to do this.
    Otherwise you might need to swap your hard drive
    Mar 06, 2008 | Acer Ferrari 4002WLMi Notebook
    HP Pavilion dv6000z Notebook Logo
    372 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
