Question about Philips HD-5661
Espresso machine My Philips HD5661 hasn't been used for some months and i can't open the water reservoir. There was a little water in it so i don't think it "melted down".
    New Friend:
Hi, where can i find a steam tube (plastic) for my philips hd-5661 machine?
Posted on Mar 07, 2015
  • 944 Answers
Sometimes the rubber seals on these can be very "stuck" after not being opened for a while - about the best way to free them is to pour a little hot (near boiling) water around the outside of the lid to soften up the seal, make sure you are trying to turn it the right way (anti-clockwise) and give it a little force. You can help prevent this in future by lightly greasing the seal with a tiny bit of vegetable oil - sunflower oil works fine but most should do the job. if the rubber seal looks very distorted or cracked then take it to a hardware store and see if they can find something the right size or try philips support from the same link below. get the user manual here (sorry not available in english, but is available in most other main languages) http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?slg=AEN&cat=KAP_COFFEEMAKERSANDKETTLES_CA&sct=CK_ESPRESSOMACHINES_SU&session=20070307124515_83.54.34.75&grp=KITCHEN_APPLIANCES_GR&ctn=HD5661/90&mid=Link_UserManuals&hlt=Link_UserManuals Hope this helps :)
Posted on Mar 07, 2007
I need filter for Philips espresso duo HD5661/00, please let me know if you know where to purchase it. thnx in advance.
You are going to struggle finding one of those; where I live here in New Zealand that model has been obsolete for over a decade. You may be better off finding someone who repairs multiple brands of coffeemakers and see if one can be matched up. It is very possible that machines very similar are still being made, just not for Philips.
Apr 07, 2015 | Philips Coffee Makers & Espresso Machines
How do I operate this Gaggia Fantastico II Espresso machine?
http://kitchen.manualsonline.com/manuals/mfg/gaggia/gaggia_espresso_maker_product_list.html
Sep 06, 2012 | Coffee Makers & Espresso Machines
Pump machine does not feed water from the reservoir and it's brand knew, it was offered steell has the seals. I don't have the warranty. Is it broken?
Feed some water with some pressure from the water reservoir hole. You have an air bubble. I followed all the solution ideas but no one worked for me until I designed my own idea. I attached a hose to the hole, opened the faucet and then put the nesspreso pump on and instantly the water come out. Solved problem
Sep 05, 2012 | Nespresso Essenza C100 Espresso...
Ok...I got heat. Hot water from wand. Steam from wand. Machine is cleaned 2 times a year with decalcifier. Screen cleaned every other month. Now...espresso come straight thru like there is no pressure...
The pressure is from zero to the opening pressure of the OPV. This should be about 10 bar when the OPV is cold. When the OPV is hot, the OPV spring is hot and a little more flexible. The OPV opens at about 8.5 bar when hot.
When the wand valve is open, you can get a lot of steam or water with not a lot of pressure in the boiler.
Take the lid off the reservoir and watch the hose from the OPV. It's the short hose.
Pull a shot with less than usual coffee in the basket.
If you see water flowing from the hose, the OPV opened.
If it did not open and there is little extract in your cup, buy a new pump.
Oct 15, 2010 | Rancilio Silvia Espresso Machine
Hello, Hope you guys can help me on this one: My philips senseo coffee machine blinks constantly when I turn it on as if there is no water. However, there is enough water in the tank. If I hold the tank...
Either the little magnet in the reservoir is stuck (does it float when you slowly fill up the reservoir?), or the corresponding Reed relais doesn't properly respond to the magnets presence. The latter most likely requires technical attention.
Aug 22, 2010 | Philips Senseo HD-7810 Coffee Maker
Starbucks Sirena espresso flashing blue light & does not heat up
Gary,
I have the same exact problem with mine starting today, did you get this figured out? I'd love to know if it's fixable or not as I was planning on selling my previous machine. If it's an expensive repair, I'll just have to ditch this one and go back to my previous one.
Jan 04, 2010 | Saeco Starbucks Sirena Espresso Machine
Empty light on espresso machine won't turn off and tank is full
I have the same machine. I just went on the coffee geeks website and it is easily solved. Just add a few grains of salt to the reservoir - the sensor cant detect water that is purified - strange but true as four grains and it fired up just like that.
Apr 13, 2009 | Nuova Simonelli Oscar Coffee Maker,...
Salton Model # 17
I think I've figured my yard sale EX 80 out. First, the way I think it works... in the tightly sealed boiler the water is heated to boiling, it must have a pressure release valve that sends the water/steam through the coffee and into the carafe. So dangerously hot and under pressure. Before opening the big round cap at the top (reservoir) relieve pressure at the steam tube valve (right side)
Here's how I made my first batch:
When opening reservoir always turn unit off, let reservoir cool a little between batches or you may get a cloud of steam in your face when pouring in water, might not be good for the heating element to shock it with sudden drastic temperature changes either.
Cleaned by running a couple of jugs of water through, cold water (4 on the supplied jug) into the reservoir all parts installed. I read somewhere online (not specific to any machine) not lukewarm water, if it's online it must be true... right?
Put coffee into filter basket/basket holder, matching amount of water in reservoir, 2 or 4 (markings on filter and jug). Espresso coffee should be very finely ground
Install all covers and the coffee basket/filter basket, close steam tube valve, install carafe and turn on the machine. Should get blast of espresso after a couple of minutes.
The steam tube (operated by the valve) seems a little cheesy on first try but I'll get better with practice. There's no steam to the tube until the reservoir starts to send steam to the coffee, the coffee kinda restricts the steam enough to send it to the tube. I was thrown a little because I didn't get steam when I was cleaning the thing, but I think that was because there was no coffee to block the flow. So I opened the valve at the start of the brew, steamed the milk, closed the valve and then the steam blasts through the coffee, tasted good.
Great $1 find.
Hope this helps.
Apr 27, 2008 | Salton EX80 Espresso Machine
Reservoir empty tank lights up but tank is half full of water
in the water tank you have a little magnet that magnet need to move up and down shake the water container to see that magnet move .thanks for using fixya
pierre
Feb 26, 2008 | Saeco Magic De Luxe Espresso Machine
Senseo 7818
My husband found in ours that the little float was stuck over the sensor (the little patch) down in the reservoir. The float could not rise with the water, thus, the machine did not know that there was enough water available and it would not stop blinking. He took the dry reservoir out, turned it upside down and shook it! This worked for him, as it unstuck the float. He said that if that doesn't work, the thing is really stuck and you might as well return it.
Jan 13, 2008 | Philips Senseo HD-7810 Coffee Maker
Philips HD-5661 Logo
320 people viewed this question
Top Philips Coffee Makers & Espresso Machines Experts
Kolbrun...
Lisa
Lisa
just-ice
Are you a Philips Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
