Question about Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System
My aqualink says heater off line - Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System
  • Anonymous Apr 27, 2009
    Message says heater offline
  • 22 Answers
What kind of heater? Is it a Jandy? Onb the digital board, there is a rubber button that needs set to pool or spa. It will say RS offline if this is the case.
Posted on Dec 21, 2008
Heater will not come on.
You need to put a volt meter on the wire that goes from the Aqualink to the heater and verify that it is telling the heater to turn on. Then we can determine if it an issue with the Aqualink or the heat pump. Make sure that the water temp sensor on the AL is reading actual temp. Sometimes they will read incorrectly and, for example, display that the water is 142 degrees. If the AL thinks the water is already at or above temperature it will not close the switch for the heater to start.
Mar 29, 2014 | Jandy AE3000T-R AE-Ti Heat Pump 137K BTU...
I have a Raypak Millivolt propane pool/spa heater that I would like to connect to my Jandy Aqualink. The Raypak millivolt heater only has a thermostat, pressure switch, flame roll-out switch, and high...
All you have to do is put your Aqualink in series with the heater's safety loop. Sometimes there is a terminal block, but regardless if you can find the pressure switch, cut one of the wires and connect the wires from the Aqualink to each side. (There are two ports on the top of the Aqualink power center board designated for this)
At that point the AL is in control of the heater. Make sure that the heater is powered up, turned on, and your thermostat is set to max.The AL will turn the heater on and off following your programmed temperature setting.
Feb 06, 2013 | Raypak Pool & Spa
Laars xl 400 heater off line
turn off aqualink then turn back on it should see it
Jan 25, 2013 | Jandy Laars LX Pool Heater / 400,000 BTU /...
I have an Aqualink system, spa set to 104, it will heat to 94 and stay there, temp sensor is working, took water sensor out of line, plugged line, assumed heater would just keep heating, it did heat a
The heater may be wired just fine. The aqualink uses its water temp sensor to call for heat based on what you've set the thermostat to on the aqualink. However, most heaters have built in thermostats that over-ride the aqualink. Those thermostats come factory defaulted not to go over 94. Check your heaters manual on how to adjust the thermostat on the heater. Your heater should have its thermostats set to 104 and the aqualink will control the actual temp of the water by calling for heat based on what you've set the thermostat on the aqualink for. Hope this helps.
Oct 16, 2012 | Jandy Aqualink Rs4 One Touch Control...
Aqualink reads " water temp short " . Is this a
This code menad that the water temperature sensor has gone bad. These will cost around $60-80 retail, unless you buy Jandy OEM, then you will be paying well over a $100.00. But you can also use a Jandy, Goldline, or Pentair sensor and it is a fairly simple repair.
Pentairs Part Number: Model # : 520272 Hayward Gold Line: Model # : GLX-PC-12-KIT Jandy: Model # : 5089
Dec 07, 2010 | Jandy Aqualink Rs4 One Touch Control...
Spa not heating up. Aqua link says Heater offline. How do we fix that?
turn off aqualink turn off heater then turn on aqualink then turn on heater it should recognize it also make sure red 4 pin connector is plugged in
Oct 11, 2010 | Jandy AQUALINK RS TELELINK KIT
My spa will not heat. The heater shows that it's working but it will not heat the water.
When you say that the heater shows that it is working is it the heater that shows this or the Aqualink. If it is the aqualink it could be a temp sensor, probally the water sensor that is in a pipe comeing from the pump. But the first thing Iwant to think of is your temp is set on the Aqualink but the temp is not turned up on the heater. If your heater is not compatiable with the link you need to keep the thermostat at max and set to pool or spa to have it work. If it is compatiable it could be in the wireing between the two or you just may need to be sure the Aqualink is set to read and override the heater. Your menu can walk you through this or your book on the unit. Let me know how you do and we can check for further problems in your heater. If so let me know brand and model of same. Good luck.
Oct 24, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
My Aqualink RS Wireless says Pool Heater Jandy Laars LX is offline. How do I get it online?
AT THE HEATER PRESS THE BOTTOM TO TURN THE HEATER ON LINE IF NOTHING HAPPEND THE HEATER MUST DE WIRE CHECK YOU MANUAL FOR THIS ONE
Jun 26, 2009 | Jandy AQUALINK RS TELELINK KIT
Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System Logo
690 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Bill Jordan
Craig Butler
Craig Butler
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
