Question about Sharp R-930AK Convection/Microwave Oven
Microwave oven stoped worling
Completely dead. Could it be the fuse and where is it.
  • bill655 Jan 30, 2009
    I have a sharp model R930AW micro/convection oven. It simply stopped working one day - completely dead. I unplugged the unit and replugged into a outlet that I prechecked to confirm it was hot, still no life at all in the unit. Any thoughts? Fuse?
  • William Miller
    William Miller May 11, 2010
    Please reply back with your brand and model number so we can help you better.
    Is it dead, meaning no
    display, no light when you open the door and no beeps when you press a
    pad on the keypad?
    Is the outlet working?
    It
    may be the fuse, which is usually located behind the grille or on the
    floor of the oven behind the control panel or between the door switches.
    At
    our Web site, we have a video
    available showing how to remove a typical
    over the range control panel assembly in under 5 minutes.
    If
    the fuse is good, it may be an open thermostat or thermal cutout (TCO)
    / thermal fuse on or near the magnetron or on top of the cavity / body
    of the oven.
    If it goes dead for a
    while during or after cooking
    then comes back on, the magnetron is probably overheating and causing
    the magnetron thermostat to open.
    Then when it cools, it
    closes the circuit and allows power through again.
    When
    checking TCOs or thermostats, if it has a hood fan thermostat,
    that should read
    open, as opposed to the others, which should read closed.
    If the cavity thermostat
    needs to be checked or replaced you'll need to pull the oven from the
    wall.
    If it went dead almost
    immediately after pressing the Start pad, that's usually a shorted
    high-voltage capacitor.
    If it went dead a few
    seconds after pressing the Start pad, that's usually a failing
    high-voltage transformer.
    If
    it goes dead or blows the breaker (or GFI) when you plug it in or open
    or close
    the door, then there's a problem with a door switch or door switch
    mount.
    If it's intermittent or
    random, it may be a bad
    connection, usually on the control board or a loose fuse holder, or
    even an intermittent fuse.
    You should do a
    continuity test on
    the fuse while it's in the holder (with the microwave unplugged, of
    course) then turn the fuse by hand or take it out and put it back in,
    then test it again.
    If you remove the fuse,
    then press the meter
    leads against the ends, it can allow internal contact to be made and
    make a bad fuse appear to be good.
    If you or someone you
    know
    decide to look into it, we have critical safety information and
    disassembly information at our site, and our link is at our listing
    here on FixYa.
    In many brand,s there is a "mini-manual" hidden inside the unit behind the
    control panel or hidden on the left side behind the grille, which is
    very
    helpful
    when troubleshooting & testing.
    You can find
    helpful exploded view diagrams and order parts for many models by entering your full
    model number
    here.
  • 4 Answers
Maybee,but no.Most microvaves have that problem over a few years because of the heat stress over the fuse and it starts to ware.You can get it fixed by a handyman or a maytag repair man.But are better off buying one for around 60-110 dollars
glad to help
Posted on May 10, 2009
Unit is completely dead
please check the fuse - you will be able to locate it on panel. - replace it and the pcs is ok --
Feb 23, 2014 | Samsung SMH9187 Microwave Oven
My magtag over-the-range microwave (Mmv4205baq) is completely dead. It's not very old, can it be repaired?
It's probably the internal fuse.You will have to take the microwave down so you can remove the housing to get at the fuse.(I will probably install an accessable panel mounted fuse holder if this ever happens to mine-already did it on the little microwave I carry around on my work truck to heat up my lunch).
Dec 17, 2012 | Maytag MMV4205 Microwave Oven
Hi how r u?? my microwave just stoped working,there isnot light,there is not fan,,nothing ,,is dead so I would liket o know if this microwaves have a fuse??
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jun 07, 2011 | Magic Chef MCD990W Microwave Oven
Microwave has no power mmv4205aas was working just fine and then just stoped
This is most likely a dead magnetron (microwave production) or a dead transformer.
These are the most expensive bits of a microwave, so unless it is of sentimental value, a new unit is actually cheaper than a professional repair.
Feb 09, 2010 | Maytag MMV4205 Microwave Oven
My LG microwave went completely dead. I is only 3
under the outer cover,its either a 10-15-or 20 amp ceramic safety fuse avail at most hardware stores, the amp rating is on the side of the fuse, if the new one blows then either the H.V. diode/capacitor or the magnetron can be suspects
Oct 03, 2009 | LG LMV1630ST Microwave Oven
Microwave oven
Please reply back with your brand and model number so we can help you.
If there's a problem with the fuse, the unit will be totally dead.
Aug 03, 2008 | Microwave Ovens
My goldstar microwave stoped working. No display, its dead. Is their an internal fuse and where is it located. Thanks
You may have a blown internal fuse. You''ll need to unplug the unit, remove the outside cover and follow the line cord and you should find the fuse.
Replace it with the EXACT same value that was labeled on the original fuse. You'll probably be able to find a replacement at any Radio Shack store or hardware store.
Replace the cover and plug the unit back in. Hopefully nothing was damaged and the unit will play again.
Please let me know if I can be of further assistance to you.
- Jim
Feb 28, 2008 | Microwave Ovens
Dead Microwave Oven
Remove the top cover of oven, there should be tec screws on the bottem of unit to remove the cover, check for bad relays,fuses and fuseable links that could have finaly gone bad.
Jan 13, 2008 | Maytag MMV4205 Microwave Oven
Completely Dead
there is a fuse in the top right hand of the microwave it will burn out when the Capacitor goes bad it will burn it out replace the Capacitor diod and fuse
Jan 05, 2008 | Thermador MBBS Microwave Oven
Sharp R-4A56 microwave oven dead
Did you check your circuit breaker to be sure that it wasn't tripped?
Jul 23, 2007 | Sharp R-202EW Microwave Oven
Sharp R-930AK Convection/Microwave Oven Logo
154 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
