Question about Honeywell HE220A1019 Whole House Humidifier Humidifier
Honeywell he220a waterflow
I have installed this humidifier and the water is constantly flowing through. is it not suppose to shut off when the unit is not running? Any ideas?
  • Stephen Evans May 11, 2010
    The water still runs with the furnace off? Is this correct? Steve
    Problem Solver:
  • 9 Answers
Sounds like you Connected the humid trans fromer directly to a main power source. It should be either on the EAC or HUM term on the board of the furnace.
Posted on Jan 19, 2009
  • subzero_hc Jan 22, 2009
    If it is using the power from the furnace it should not be running. The valve on the humd is stuck open. may be dirt but they usually have a filter screen before the valve inside. I would return the humd or get a warranty valve.
Solenoid valve switching continuously he220
I would think it would need to switch on & off to control the water flow through for correct humidity..
Dec 09, 2013 | Honeywell HE220A1019 Whole House...
I have just completed installing a Honeywell HE220A humidifier to a Carrier Weathermaker 8000vs that was installed in 2003. My problem is that all the identified circuits in previous posts on the circuit...
I believe that Carrier has a 24 volt setup for humidifier but am not sure. On the circuit board I think there is a terminal (HUM). If there is this terminal connect 1 wire to this and 1 wire to C terminal.
If not,pretty sure there is a 120 volt EAC terminal. This would only kick on when blower is on. If you have to use this you would have to install transformer to the EAC connections
Jan 28, 2011 | Honeywell HE220A1019 Whole House...
I hooked up a honeywell HE220A by-pass humidifier and the water is constantly running with the furnace on or off. I wired it the same way the diagram said using the transformer that plugs into an outlet,...
If you have very old furnace, does it have a blower with a belt. If it does it should only have 2 wires going to blower. If it has 2 you should be able to use the transformer you have plugged into wall and splice into 2 wires going to blower. If you have more than 2 wires to blower, you will need to find out which one is used for heat plus use the white one. If you have a voltage sensor you should be able to find it easily.
Jan 24, 2011 | Honeywell HE220A1019 Whole House...
I have a honeywell he220a humidifier . the water drips in but does not get the filter pad wet.
Open the waterline tap valve or may have to clean small orifice that is in line where 1/4" line meets humidifier. Need to shut water off and in screw nut holding copoet line to humidifier
Jan 22, 2011 | Honeywell HE265 Humidifier
Honeywell HE220A water not reaching humidifier
Replace the Valve on the unit. Check the small filter inside of it where the waterline attaches first. If its clear and you have lots of flow from the 1/4" line the replace the valve.
Jan 19, 2009 | Honeywell HE220A1019 Whole House...
Honeywell he220a install
thanks for your question,
you have to install the bypass humidifier on the supply side of your heating system, (hot side) and run a bypass pipe from the return side, (cold side), it does matter which side it goes on, you do not want water vapor going directly into your furnace, as this can damage it and shorten the life of it, your humidistat is installed on the return side of your duct work, this will allow proper operation of the unit as the humidistat senses the moisture in the air and brings on and shuts down the humidifier as needed. hope that helped to answer your question, please let us know what you think, again thanks, mr.grzz
Jan 17, 2009 | Honeywell HE220A1019 Whole House...
He220a honeywell humidifier water actuator valve broke
The screw does turn and will open the valve, take the hex nut off and turn the screw to see if water leaks between the valve portion and the hexnut housing. They used that same valve on many models, including the newer models. Make sure you are getting water to the valve.
Nov 26, 2008 | Honeywell HE220A1019 Whole House...
How does transformer hook up
if you just replace the unit and it is working, no your do not need the tranformer. The unit is getting power from the furnace. For reference though. The black and white wires are your 120 volts. Black hot, white common. the 2 screws are your 24 volts
Nov 25, 2008 | Honeywell HE260A1010 Whole House...
Continous ware flow on Honeywell HE220A Humidifier
I am having the same problem. I have had my humidifier for about 5 years now and I just started having the problem where the water continuously flows through the solenoid. I took apart the solenoid by removing the fittings from both sides. When I did that, I noticed that there was a hole in the metal that allowed me to see through to the other side. Apparently, it had corroded and and broken through, allowing the water to pass through the solenoid without really going through the valve within the solenoid. There are several sites that sell replacements for about $70, which is not cheap, but cheaper than buing a new humidifier for $120. Here is one site I found: http://www.iaqsource.com/product.php/honeywell/32001639-002/?product=112783&category=1142
Oct 18, 2008 | Honeywell HE220A1019 Whole House...
Water flow through humidifier
I installed this humidifier (and had a lot of trouble installing it!) and was surprised by the flow of water. Mine leaks out of the bottom of the unit so I haven't actually used it yet. I'll try to figure out why it's leaking this weekend. I thought there would be less water flowing through the pad. I suspect that the weight of the unit is causing it to not be plumb so some water is dripping off of the pad and past the drain tray.
Nov 30, 2007 | Honeywell HE360A1027 Whole House...
Honeywell HE220A1019 Whole House Humidifier Humidifier Logo
347 people viewed this question
Top Honeywell Humidifiers Experts
Dennis
Simon Benzekri
Level 1 Expert
jdthefixer
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
