Question about Canon PIXMA MP530 All-In-One InkJet Printer
MP530 - Check Printer - 6A00 error
Anyone been able to solve this. I originally got the 5100 error, and now I get 6A00 every time i turn it on. Tried taking out and putting back in the print cartridge, unplugged it, etc ...
Thanks, Gus
  • 4,041 Answers
Hi
Hope it will work for you
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 10, 2010
My Canon MP530 is giving 6A00 error message and alarm light is flashing along with copy button. i have replaced empty ink cartridges with new ones. Can anyone help, please?
Error code 6A00 indicates an error occurred in the AP motor during purging operation. You need to replace sheet feed unit, logic board assy and purge unit to fix it. Before replacement of the logic board assy, check the waste ink amount (by service test print or EEPROM information print). If the waste ink amount is 7% or more, also replace the ink absorber kit when replacing the logic board assy.
Feb 09, 2011 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA MP530 All-In-One InkJet Printer Canon mp530 error 6a00
The 6A00 is a Canon generic code for paper path jam. Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.
Clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like
Dec 15, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Says Check printer 6A00. Any ideas?
[6A00] or Light blinking 12 times = AP position error. It's mean there is an error occurred in the AP motor during purging operation. You may need to replace Sheet feed unit, logic board or purge unit. Thank you
May 28, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Message: Check Printer 6A00 and message Service Error 5C10. I have rebooted, turned printer on and off, hit reset and reinstalled software.
Hello there
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Oct 08, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Check printer and 6A00 flashing
6A00 indicates that "an error occurred in the AP motor
during purging operation". This is a service call error and requires that the printer be brought into a canon authorized service facility for repair. The service facility would be able to fully diagnose the problem and properly repair it.
May 21, 2009 | Canon PIXMA MP530 All-In-One InkJet...
MP530 alarm and 6A00 error
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Dec 11, 2008 | Canon PIXMA MP530 All-In-One InkJet...
MP530
The alarm light is blinking. It says Error 5200? What is that?
Email me at : eunice@idig.net
Sep 09, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Error 5100 for canon mp530
I would do all of the following and see if yo can clear this code. It is not on any Canon list of possible codes, so I have no idea what it means., but let's do this:
Turn off the printer and unplug it.
Remove the print cartridges. Look at them, are they leak free? Look into the cartridge holders. Are they clean?. Dried ink or blobs should be cleaned off with a little alcohol and a qtip.
Are the little wire holders bent or broken? Do they look exactly the same?
Turn the printer back on reinstall the cartridges.Check in your printer preferences/services and clean your cartridges.
Now turn it off again and unplug it. Open the paper jam door and gently push the paper roller forward until it clicks. At the same time, look for even the tiniest scrap of anything in there.
Close the paper jam door and plug your printer back in. Restart your computer.
If the problem is not solved. You may need to reinstall the printer. Do You have your original disc? Be sure to do a clean install. ( Turn off all running programs in the lower right corner including your virus control. Also go to Toolbar>tools>internet options>general>and delete all you cookies and temporary internet files.) Turn off and unplug your printer.
Reinstall the software. When it is finished if it has not told you to plug your print back in do so now. Restart your computer and turn your printer on.
I hope this helps. Good luck to you.
Aug 24, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Error Codes 6A00 and 5C10
I tried everything suggested on other posts (cleaning paper feeds and making sure rollers were free, moving carriage back and forth manually, etc)., but nothing worked. With it still plugged in, I turned the whole thing upside down and shook it. It hummed and buzzed, and moved the carriage a couple of times. Viola, problem solved. Go figure.
May 03, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
621 people viewed this question
old marine
old marine
