Question about Toshiba MW24FP1 24 in. TV/VCR/DVD Combo
Digital reception We have the MW24FP1 TV/VCR/DVD combo and love it. Do we need a converter box to receive digital channels starting in February? If not, what do I need to do to receive digital channels? I have tried everything I can find in the manual. Thank you. Bev
  • Toshiba Master
  • 5,138 Answers
If you do not have cable/satellite ,Yes
Posted on Dec 11, 2008
Have had digital installed and cannot get tv to work through digital. Any advice?
Hello
Thei Orion model Tv is not equipped with a digital tuner inside. There is only an analogue tuner fitted and only analogue channels can be received by this set. To get digital channels, you have to buy one settop box, which can convert digital signals to analogue signals. In short, a Digital to Analogue Converter should be bought, if you want to get digital channels. OK.
Dec 23, 2011 | Orion FTDV2004 20 in. TV/VCR/DVD Combo
Moved, no longer have cable and not getting any channels via attenna. Is it just bad reception or do I need a digital converter because of the change to digital stations?
Could be bad reception and or make sure the tv which was in the cable mode when you had cable now needs to be in air or antenna mode. IF you have another tv that works ok then you will know the channels just need to be reprogrammed for over the air signal. Go into the menu of tv and find program channels and switch to air or it might say antenna..
Oct 17, 2010 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
Hi just got a LG dvd/vcr Model RC897T. I have it hocked up right, but i can't get it to switch over so that it would be seen on the TV. can you help
If a cable box is not required for cable signal reception, connect the cable line to the ANT. IN connector on the recorder.
If a cable box is required for cable signal reception, connect the cable line to the IN connector of the cable box. Connect a coaxial cable from the OUT connector of the cable box to the ANT. IN connector of the recorder.
To view or record a CATV channel:
  1. Tune the TV to the Recorder output channel (CH 3 or 4).
  2. Set the Recorder channel selector to the cable output channel. (Example: CH3).
  3. Select a channel using the cable converter.
With this connection, you cannot record one program while viewing another.If you are using a cable box to tune channels, it is not necessary to do Auto Channel Set.
Oct 20, 2009 | LG RC897T DVD Recorder/VCR Combo
TV/DVD reception
The main aerial goes into the box then out of the box into the dvd then from the dvd into the tv,if the dvd is analog tuning the pic will not be as clear as the digital
Sep 28, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Is it possible to tune the LG VCR to receive digital signals through a converter box?
Yes,hook ur LG VCR to recieve the air signal than recycle it through the converter box.
Aug 26, 2009 | Televison & Video
Would like to record from my tv to my magnavox dvd/vcr combo box
If I understand your request right, You do not have cable or satellite box.
You can not record from your TV. You use the TV as a monitor from the dvd/vcr combo box. What the box receives is what shows on the TV. So you will have to have a digital convertor hooked to the (antenna in) dvd/vcr combo box, (antenna out to the tv antenna in) Depending on the antenna you are using that is on the other end of your cable-in coax connection this will hook to your antenna in on the digital convertor box. If your cable is hooked up and operating correctly and directly to the tv that is digital ready you probabbly have a good picture. When the vhf/uhf signal was transmitted you could go from the dvd/vcr to the tv with no problem. But now that the signal is digital and the tv is set for digital the dvd/vcr will not pass a digital signal to the tv. Best suggestion, you have to get a digital dvd/vcr receiver. If you have more question please contact me.
Mike
Jul 25, 2009 | Philips Magnavox DVD/VCR Dual Player
Connecting digital converter,Emerson VCR/DVD Combo,Sony SDTV
I think you may need an RF Modulator. This device will have connections for the DVD and TV and will have a channel 3/4 switch. Good luck to you.
May 15, 2009 | Emerson EWR20V4 DVD Recorder/VCR
How to record ditigally on old comb tv/vhs
If you have the box hooked up to your 1996 combo turn or tune on channel 3 if the converter box is selected to channel 3 you should get all your digital reception from the box to your tv/vcr. Select what you want to watch or tape on the box, what you see on your tv will record to your vcr when you select record.
Jan 14, 2009 | Televison & Video
Do I need a dtv digital converter box for my Symphonic SC313D 13 inch tv?
Pretty much a hoax on those diverter boxes. People ran out and bought them thinking that won't have reception. I have many years in maintenance and several years in nursing homes with different tv's in every room. Not once have I needed a box to pick up channels with or without cable. I myself get 16 channels with rabbit ears and thats enough for me. And I do own a combo as well and it has simple antenna and does me just fine. Depending on your location, the old tv antennas we use to put on our houses...they work amazing! Might be able to snag one on a freecycle or craigslist site. Good luck! :)
Jun 05, 2008 | Symphonic SC313D 13 in. TV/VCR Combo
Toshiba MW24FP1 24 in. TV/VCR/DVD Combo Logo
158 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
