Question about Syntax SVX400 (SYSVX400) Motherboard
MonitorProblem I am having trouble with my computer well im putting it together and i had it going and everything but then i had to turn it off cuz i realized that i didnt have the cd with me. i was seeing the bios and everything it was working and everything i didnt change anything the next day i went to plug the power cords back in cuz i had the cd the monitor was no longer being read by my computer it say check the cable or something i have plugged in three seperate monitors and they are all having the same problem can someone please cuz i really want to get this going and i know im almost there please help.
    Sergeant:
  • 310 Answers
Hey Mate, the fault is caused by the base unit not sending a signal to the monitor. most likely cause Graphics Card or Memory. if you remove one at a time and replace them back in the motherboard usually fixes the problem. All the best John
Posted on Mar 04, 2007
SOURCE:
90 nissan sentra distributor diagram
Hi,Miguel Barrios
You are so cool. I am agree with you.
My Page : Onsite Training
Sep 10, 2012 | 1990 Nissan Sentra
Hey Im the one that was asking about featherlite weedeater starting problem and you suggested a carb kit. How easy is that to put together? Im a novice woman do you think I could do it?
Welcome to fixya!
I'm a woman too and I learned by trying. Don't let anyone tell you you can't do something. Borrow some tools if you don't have any and go for it.
Carbs come with instructions on how to put them together.
If you have trouble, come back here and someone will help you out.
Go for it!
Handie Andie
Jul 16, 2011 | Garden
I took apart my PS3 Dual shock 3 controller and painted up. When i put everything back together and I tried turning on the PS#3 but it wouldn't turn on. When i was putting it back together it kept turning...
i would suggest reversing the steps you took and look for anything you missed or improperly placed components because you said it kept turning on so something got pressed together improperly and is giving you the negative results your having im sure you will figure it out
Dec 30, 2010 | Sony Dual Shock 3 Controller for...
I worked on the 1998 plymouth voyager 3.0L i did a worked on the cylinder head but accidently i forgot to drain the coolant out of the engine so when i lossen the intake manifold the coolant went in was...
ok. first off, if you dont have any of the spark plugs in and you turn the engine over to crank, its not going to sound the same as when it does with them in. If indeed you do see the cam shaft turning, then the engine is cranking over because the starter goes to the flywheel/flexplate, to the crank, and the crank goes to the camshaft so if you have everything put back together exactly the way it came off, you should be alright. Individually check each cylinder for compression with a compression tester. What kind of work did you do to the head? If you removed it to work on it did you have it resurfaced before re-installing it? Did you thoroughly clean and prep the gasket areas? Let me know how this turns out.
Jan 04, 2010 | 1998 Plymouth Voyager
LG monitorproblem
The fuse has probally blown
OR
There is a lose connection to the moiniter.
Hope this helps!
Jul 13, 2009 | LG L1915S 19" LCD Monitor
Music on my sidekick 08?
Maybe, she had a different phone, or your phone need a higher stander input
Jan 11, 2009 | T-Mobile Sidekick
Phillips Go gear trouble
sorry dominik i cant help you. im trying to fix it right now but it wont do anything.
Sorry Bud, PIotR
Apr 12, 2008 | Philips GoGear HDD6330 MP3 Player
Can't delete songs
heres what you can do;
once plugged into computer, click on "my computer" icon.
Find the sandisk sansa product, and look through all the music files,
once found the files, delete any of the files as you wish
if that dosent work, im afriad that your going have to delete everything and start fresh again.
Feb 11, 2008 | SanDisk Sansa e270 MP3 Player
Help
dont waste your time is not the video card, Idont know what you put together but if you change the motherboard you have to give some info to it, and thas a technical job look for a tech....good luck
Aug 04, 2006 | Albatron PX865PE Pro Motherboard
Syntax SVX400 (SYSVX400) Motherboard Logo
59 people viewed this question
Top Syntax Computers & Internet Experts
Alun Cox
k24674
Are you a Syntax Computer and Internet Expert? Answer questions, earn points and help others
