Question about Aqua Flo Aquaflo Flo Master Xp2 Spa Pump 1.5 Hp Two Speed
Hot tub pump will not run. Pump makes a click noise and hums but will not run, could this be a start capacitor gone bad
  • Psiman Dec 13, 2008
    I have exactly the same problem and was wondering the same thing about the capacitor. Do you know if the capacitor is to start the pump or is it just for interferance?
  • 3 Answers
This can be one of three issues.
1.  Starting capacitor as you have suggested.  You can take the capacitor to a motor shop and have it tested or test it yourself if you have a meter that will check capacitance. 2.  Low/High voltage.  If the voltage is not at the proper levels (10% up or down) then the unit may have a hard time starting. 3.  Something might be binding up the impeller.  Disconnect the power and carefully check to see if the shaft of the motor spins freely. 4.  A short in the windings.  If none of these seem to be the problem, then you will probably need to replace the motor.
Posted on Jan 12, 2009
Ive got power, hot and cold to my existing pump and shower, but the pump doesn't start, just makes a whirring noise.
Above Ground Pool Pump Won't Start or is Humming & How ...
? 6:16
https://www.youtube.com/watch?v=RH78q36liks
Apr 15, 2014 - Uploaded by Above Ground Pros
Above Ground Pool Pump Won't Start or is Humming & How to Fix It ... Pool Motor - Humming-Loud Noise ...
How to fix your pool pump from humming - YouTube
? 2:43
https://www.youtube.com/watch?v=3v2v6aDDq9A
Mar 25, 2013 - Uploaded by James Hayward
Do you have a pool pump not priming (pumping water) andmaking a humming noise ... not only give a ...
pool pump makes humming noise and does not pump - Trouble F
Dec 08, 2015 | Home
My Calypso washer at the start I hear water filling tub. Then it stops filling and hear a moderate humming noise. I replaced water pump but still doing the same. Please help. Thanks
The problem is not the pump. IT appears that the water control valve is bad or the voltage that controls it is changing and then the valve stops working.
Dec 24, 2014 | Whirlpool Calypso GVW9959K Top Load Washer
Pump makes a humming sound but will not run
Don't run it hot or it will stop working.
Sounds like start capacitor has gone bad.
Copy following link for motor troubleshoot resources:
http://waterheatertimer.org/Color-codewire.html#motor
Add a comment
May 27, 2013 | AO Smith Centurion 1081 2 Hp Standard...
Pinnacle high performance one hp have a reset button
if humming and not running bad start up capacitor or bad motor replace pump be safe
Apr 20, 2012 | Pentair 1HP Pinnacle High Performance...
I have an aqua flow master 3.8 hp xp2 pump in my hot tub, it sounds like it is receiving power as it is clicking on but it will not start. have i fried the motor? the shaft turns ok but nothing is...
Many of these pump motors have a capacitor and start & run windings. I had a pump motor a week ago that was free to rotate, but only hummed. I looked inside the back end, everything looked good, I bought a capacitor online for $7 + $15 shipping, installed it and it worked. The capacitor will have voltage & rating on the side.
BE CAREFUL, CAPACITORS KEEP VOLTAGE EVEN WHEN NOT PLUGGED IN. If you don't know how to handle them, take the motor to a local motor repair shop.
Gary
Aug 02, 2011 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
I have a CSC compacitor 50UF /- 6% 370VAC 50/60HZ, thinks it bad, my hot tub motor just hums but will turn free by hand
The capacitor on top of the motor is the run capacitor. The reason the motor is just humming is more likely the start sw located behind the end bell housing. There is a spring loaded clutch mechanism that may be stuck so the switch is not being activated. A simple fix at any motor shop.
Oct 23, 2010 | Waterway Spa Pump Executive 56 Frame 4hp...
My pump won't run it just makes a humming noise and gets hot. the impeller spins freely by hand.
If the pump is fairly new it could be the starting capacitor,
But if the pump get really hot quick its the motor who is damage and need to be rebuild or replace,
how old is your pump and wich model do you have?
Aug 13, 2010 | Tsurumi Pump s Submersible Trash Pump -...
I have a St. Maarten tub and the #1 pump does will
the problem with the pump #1 sounds like a capacitor, unless the bearings have seized, it's the start/run capacitor or possibly the inner switch but that is not as common. Humming and then turning off is textbook sign of a bad capacitor or seized bearings, if the pump has not been running loud or whining, it definitely the cap.
Jan 31, 2010 | Qca Spas Majestic Series Aruba Xl Hot Tub
Kenmore elite not washing dishes
Sounds like the motor is stuck. If your careful you can unplug the dishwasher or turn the breaker off, take the bottom panel off and reach in with your finger and spin the motor assembly.
Nov 12, 2009 | Dishwashers
Pump makes clicking noise when powered up ?
Clicking?... not knowing which clicking noise you are hearing, I will run down the most likely on a new pump.
1. When wiring the motor you may have left a wire in close proximity to the centrifical start capacitor switch. It spins at high RPMs and can be hitting a wire not properly tucked in
2. Most pool pumps are dual voltage. If you wired motor for wrong voltage than that being delivered, the motors can sometimes make noises. Clicking isn't most common, but the vibrating hum of incorrect voltage might be interpreted as a clicking noise.
3.check to make sure no wire ties, or plastic stringy tag holding devices were left in the pump intake basket.
Aug 23, 2009 | Hayward 1 Hp Max - Flo Swimming Pool Pump
Aqua Flo Aquaflo Flo Master Xp2 Spa Pump 1.5 Hp Two Speed  Logo
1,158 people viewed this question
Top Aqua Flo Pool & Spa Experts
Jay Finke
Jay Finke
Gene Haynes
David Spradling
David Spradling
Are you an Aqua Flo Pool and Spa Expert? Answer questions, earn points and help others
