Question about Maytag MSD2734GE Side by Side Refrigerator
My freezer works fine, however my fridge is not cold. It seems as there is no air flow in the fridge. I have checked behind the crispers to ensure nothing is blocked. I have a Maytag msd2734ge, wide by side, and it is about 5 years old. I also blew out the coil in the back to check that off the list.
  • azwindshield May 05, 2009
    same problem but i have change my defros/thermastat. and the fan is still working but still no air to the fridge side
  • Louie  Role
    Louie Role May 11, 2010
    Hi and welcome to FixYa,
    It would seem that you posted twice.
    Initially, this normally would point
    to the fan not spinning. The function of the fan is to draw the cold
    air from the freezer and force it through the vents to the refrigerator
    area. Even having said this, the fan is activated by the logic
    controller based on the the thermostat setting of the refrigerator and
    condition of the door (it must be closed).
    Good luck and Thank you for using FixYa. Happy Holidays.
  • 3 Answers
Check in the freezer side and look at the back wall and see if there is any build up of frost, your coil may be block, so no air flowing through the coil, your unit may not defrosting, you need to check the defrost heater,the defrost timer or the defrost thermostat one of these part can be defective
Posted on Dec 11, 2008
Fridge cabinet set on medium but any vegetables I crisper section are freezing? Help please!
What is your fridge model number? Some models have independent air flow from freezer to the crisper section and a trick to test
APPLIANCE 911
Nov 29, 2015 | Refrigerators
Why are only drawers in fridge cold & not making ice?
Contact a professional. Sounds like either your damper door is not operating correctly and not letting enough cool air from the freezer enter, or there is an air leak that is making ice form .
Aug 12, 2012 | Frigidaire FRS3R5EMB Side by Side...
My Kenmore side by side is fine, except for freezing everything in the crisper drawers.
The coldest place in your fridge is in the crisper drawers, manufactures know this and they even put heaters under the floor of your fridge to try to heat it up a bit in there, if you set your freezer temperture to low there will be less cold air current that flows into your fridge but it will flow in over a longer period of time, that air is about -22C so it will be blowing on your items in your crisper for a long time and it will probably freeze them, all very confusing and complicated but it may help to turn your controles for your freezer to a warmer setting, on the other hand if you only open your fridge a few times a day the cold air being denser will settle in the bottom of the fridge and freeze the crisper area, not much you can do about this, except eat more food... :-)
Aug 26, 2011 | Kenmore Side by Side Refrigerator
Freezer is working fine. Bottom Control for Crispers working fine. Upper section of fridge not getting cold.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
May 26, 2011 | Frigidaire Refrigerators
I have a side by side double door fridge. My freezer is cold and working fine but my fridge side is not getting cold.
check yor damper door, it's the little door at the top and or bottom of the fridge insid near the top and or at the bottom behind the crisper drawer when working right they open to let cold air in from the freezer and warm air out. top one cold in, bottom one warm air out.they work on a sensor/relay when the freezer fan goes on they open when cold air is needed.
Mar 12, 2011 | Jenn-Air JCD2389G Side by Side...
GE Profile - Fridge Doesn't Cool But Freezer Works Fine
Had a similar problem with my Kenwood Fridge Freezer
If you're mechanically minded you could check if there's an opening and motorised flap (usually behind a cover) at the top of the fridge - Cold air from the freezer enters the fridge through this flap) The Sound you heard could have been the motor trying to open / close this flap. This flap can become frozen in the closed position - so cold air is unable to enter the fridge compartment) My fix was to thaw it with a hairdryer and reassemble. Another fix would be to empty the freezer and open the doors - it might take more than 24 hours but once completely defrosted if the flap is the issue it will have defrosted. Once plugged in again the door will open and cold air will start to flow into the fridge compartment. I had a quote for €195 for a call out / repair
I fixed it myself in an hour - Hope it works for you ...
Sep 20, 2017 | GE Profile PDS22MHR Bottom Freezer...
Fridge not cold...freezer is ok.
Initially, this normally would point to the fan not spinning. The function of the fan is to draw the cold air from the freezer and force it through the vents to the refrigerator area. Even having said this, the fan is activated by the logic controller based on the the thermostat setting of the refrigerator and condition of the door (it must be closed).
Dec 11, 2008 | Maytag MSD2734GE Side by Side Refrigerator
Fridge not cooling
sure is you nailed it, behind the lower crisper drawer is air retunr make sure nothing covering those. removing back panel of freezer will also show problem, id assume iceis building up on either side. remove ive and refrig is restored. make sure doors are sealong sounds like warm aire getting in somehow
Feb 07, 2008 | Amana ABB1927DE Bottom Freezer...
Crisper door/water line freeze problem
mar...you're box is set too cold. Use -17 C/38 F on the freezer side which is about 38F/4C on the fridge side. Use an outdoor thermometer and let it sit closed for at least a few hours. Adjust accordingly and this will work out. One adjustment is often the cold vents from the freezer into the fridge. If set too wide, too much cold air gets into the crisper and water lines.
Feb 01, 2008 | Maytag MFD2560HES Bottom Freezer French...
Jenn Air JCD2389GTW Refrigerator problem
change the adaptive defrost board located in the upper right corner of refrig under the panel. remove panel by pulling on panel towards you from the finger holes in the rear. remove two 1/4 inch screws and two phillips screws. defrost manually with hair dryer behind panel in freezer.
Jan 19, 2008 | Jenn-Air JCD2389G Side by Side...
Maytag MSD2734GE Side by Side Refrigerator Logo
197 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
