Question about Dymo DateMark Date/Time Stamper
Dymo stamps doesn't see USB Dymo scale
Dymo stamps says scale not connected when scale is connected. Can't automatically weigh and print postage.
  • Anonymous Jan 04, 2009
    I purchased a 50# DigiWeigh scales from Ravenscalesonline in Ebay.  The weigh button always shows a 0 weight in Dymo Stamps even when the digital display on the scale shows a weight.  The Ebay seller will not respond to any questions.
    I have tried several types of packages and every option I can find in the software.
I connected my 10lb USB scale directly to the PC port bypassing a hub.
it worked fine!
Posted on Apr 21, 2009
    Problem Solver:
  • 4 Answers
You might try connecting the USB cable directly to one of the computer's USB ports.  My scale (DigiWeigh) showed as not connected when it was connected to a USB hub.  When it is connected directly to the computer, it shows the scale as connected.  Unfortunately, it still won't transfer weights to the Dymo Stamps software.
Posted on Jan 04, 2009
How much postage is required on a letter that weighs .9 oz.
hi Annette.
this is all i could find out.
Each additional ounce will cost an extra $0.21 (no change from 2016). Postcard rates will stay the same at $0.34. Use First-Class Mail if your mailpiece is less than 13 ounces and doesn't need overnight delivery or USPS Tracking™.22 Jan 2017
2017 usps® postage rate increase guide - Stamps.com
https://www.stamps.com/whitepapers/2017-usps-postage-rate-increase-guide.pdf
Nov 23, 2017 | Office Equipment & Supplies
HOW DO I buy a US postage stamp Printer?
You can print US postage stamps on a standard office printer to print postage by the sheet or using a specialty roll printer like the Brother QL-700.
http://www.pb.com/smb/online-postage-stamps/overview/print-stamp-sheets
This is one example from Staples.com:
http://www.staples.com/Brother-QL-700-Label-Printer/product_356066
Sep 10, 2014 | Office Equipment & Supplies
Paper "30252 address" is not supported
Here is the fix for Win7 provided by Dymo tech support:
1. goto Devices and Printers
2. select Dymo Label Writer
3. On the top where you see Print Server Properties, open it and find "30252 address"
4. delete "30252"
5. delete Dymo Label Writer printer
6. disconnect USB cable and then power to Dymo printer
7. connect power and then USB cable back to Dymo printer
8. reboot PC
9. try printing label again.
Jan 31, 2013 | Dymo LabelWriter Thermal Printer
How can i set up the printer to this computer?
depending on it's age, it could be a Parallel, a Serial, or a USB printer....
You will also need the drivers for it...Note: it is sometimes known as a Zebra printer. HOW you connect it to your PC depends on the connection. WHEN you install the drivers also depends on what connection type it is (USB: do not connect printer until the driver software tells you to, the others are OK to connect first...but NOT while the PC is ON....especially for a serial printer.)
UPS used to use those (they may still,) and might have drivers you can use....they wern't for USB when I used them, but they may have now...
Tallon41
Sep 13, 2012 | Dell OptiPlex GX520n PC Desktop
My Dymo Labelwriter Twin Turbo will not print from stamps.com, nor will it print regular mailing labels
Kathy,
Stamps.com supports this thermal printer. If you would like assistance, can you please email me at social(at)stamps.com?
Thanks!
Chuck
Stamps.com
Sep 27, 2010 | Dymo LabelWriter Thermal Printer
My Microboards PF2 does not print color properly.
The next to last cartridge I installed did not print properly. It seemed like all the colors were not there so I weighed it on a postage scale and it weighed less than another new one I had. I called Microboards. They said to send it to them and they replaced it. It may not be that, but weighing it should give some indication if it is.
Dec 07, 2009 | MicroBoards PF-2 Disc Printer
I cannot get my Dymo Twin Turbo printer to print stamps, although it will print labels
#1 you need the DYMO stamps application. #2 you need to make sure that the right printer is selcted in the DYMO stamps program.
Oct 01, 2008 | Dymo Office Equipment & Supplies
Dymo Twin Turbo Labelwriter not printing stamps
This is the response from dymo stamp. I did as they said and am now printing stamps again.
We have seen this cause problems with the .NET framework Microsoft uses and Dymo Stamp uses. Follow these steps to correct it Step 1: Download Microsoft Windows Installer CleanUp Utility
1. Visit:
http://download.microsoft.com/download/E/9/D/E9D80355-7AB4-45B8-80E8-983A48D5E1BD/msicuu2.exe
2. Save the file on the Desktop.
3. Please double click the msicuu2.exe file to install it on the computer.
Step 2: Remove .NET Framework
1. Click Start -> (All) Programs->Windows Installer Clean Up.
2. Please locate and remove Any .NET Framework 2.0 software.
After that, please perform the following suggestions to reinstall .NET
Framework 2.0 and its updates. Step 3: Reinstall .NET Framework Version 2.0 SP 1
Please download and install the following
Microsoft .NET Framework 2.0 Service Pack 1 (x86
http://download.microsoft.com/download/0/8/c/08c19fa4-4c4f-4ffb-9d6c-150906578c9e/NetFx20SP1_x86.exe
Note: When the "File Download" window appears, please click Save, and follow
the directions to save the file on the Desktop. After downloading all the
setup files, please double-click on each one to install them.
Apr 15, 2008 | Dymo LabelWriter Thermal Printer
Dymo LabelWriter 400 Turbo/Postage Issue
Yes, you are indeed doing something wrong. In terms of the "free" electronic postage offer, what you want to sign up for is the "DYMO Stamps" program, offered via endicia (this is different from endicia's other PAID programs...just be aware).
Simply put, just google "dymo stamps" and the first hit will bring you right to the sign-up location you want.
Just to clarify, unless you have a special program I'm not aware of, stamps.com is most definitely NOT free. They require a monthy fee (of course, they do have a free first month if that's what you're talking about). Regardless, stamps.com DOES work with the LabelWriter 400...but just not with the special "Dymo Stamp Labels" (these "stamps" only work with the free monthly servcie I mentioned earlier, "DYMO Stamps"). You can print up postage/labels via stamps.com just fine using the other size 2-part or 3-part labels sold via stamps.com or dymo.com's store.
good luck!
Mar 15, 2008 | Dymo LabelWriter 400 Turbo Thermal Printer
900 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Jax Planet
Jax Planet
jdthefixer
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
